Back to:
Tags:
ASUS ATI 9800XT  Graphic Card
P4C800 Promise 378 and ICH5 - BIOS settings???
By Riddle - usenet poster
if this is obvious then i apologize but cannot make this board
work!!@#$
currently running Promise 378 SATA1 and SATA2 on RAID 0 no
problem...but system will not recognize any drives attached to SATA1
or SATA2 on the ICH chipset SATA controller!@# I have tried various
BIOS settings...run the Intel Chipset Utility...to no avail!!
Power..connections..jumpers all checked and rechecked...how do you get
SATA drives on the ICH to be recognized???? Help!!
kit
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 14, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Not going to look up which is which but one controller runs ide and one runs sata (bleh,I looked it up in the manual.ICH5 runs sata and promise378 runs sata and ide on the primary raid channel)
both drivers need to be copied from the install cd onto floppy and loaded during install of windows-instructions are in chapter 5 pg 23-25
Ive got a p4c800e running raid0 on both contollers at the same time
I believe Ive got 6 drives in raid0 in that box
I doubt anyone uses this board anymore that hasnt already figgered it out but there ya go
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on P4C800 Promise 378 and ICH5 - BIOS settings???:
I don't want to Accept this solution
Solution #2
posted on Aug 01, 2007
Not Rated (0)
Beresford
Rating: 0%, 0 votes
Since you can't use the on board Promise Controller and the Intel on
board controller as they ARE mutually exclusive, I guesss that means
that I can't use my 4 SATA drives and my 2 ATA 133 HDD. right? I have
a SATA 160G Barracuda on "SATA 1" & "SATA 2". These are tho only
drives my board (Asus P4C800E-Dlx) recognizes. I have the other MB
ports labeled "SATA RAID 1" and "SATA RAID 2" connected to 2 SATA HDD
(same kind), and I have the PPromise ATA 133 80 ribbon (40 pin)
conne3ctor hooked to 2 Samsung ATA 133 EIDE 160G HDD's (one master -
one slave). The BIOS won't recognize them either. Does anyone know
what the maximum RAID 0+1 array is availble on the MB, and what the
compastable hardware connections are? I've spend $3,400 and only 2 of
my 6 HDD's are being seen!#@#!!
Thank You!
Solution #3
Not Rated (0)
Lizzy
Rating: 0%, 0 votes
: recognized
: that
: : in
: : : Do you mean that "press F6" message early in the installation?
: It requires a floppy with a particular file--oemtxt. or something.
: Where do you come up with that?
Pay no attention to the fool behind the curtain!
Thank You!
Solution #4
Not Rated (0)
Reynolds
Rating: 0%, 0 votes
J.Asling
Practice random acts of intelligence and
senseless acts of self-control.
Thank You!
Solution #5
Not Rated (0)
pandamama
Rating: 0%, 0 votes
Go into IDE configuration and set to Enhanced mode.
This will omly work with 2000/XP, if you running
ME or 98 you have to use compatible mode.
In compatible you can run any 4 drives. 1 IDE +
2 ATA or just the 2 IDE
See page 4-11 in the manual.
Jim Manning
Thank You!
Solution #6
Not Rated (0)
Cato
Rating: 0%, 0 votes
Did you say you're running the Promise controller and you want to the run
the Intel too? It's either one or the other. No two ways about it.
What board are you using??
Thank You!
Solution #7
Not Rated (0)
jessie25
Rating: 0%, 0 votes
Did you load the Promise Drivers yet? The controller will not be recognized
anywhere until you load the drivers. It took me a while to figure out that
you do this when installing Windows XP.
If you need instructions on how exactly to do it I'll post back. Nothing in
the manual about this. It's aggravating.
: if this is obvious then i apologize but cannot make this board
: work!!@#$
: currently running Promise 378 SATA1 and SATA2 on RAID 0 no
: problem...but system will not recognize any drives attached to SATA1
: or SATA2 on the ICH chipset SATA controller!@# I have tried various
: BIOS settings...run the Intel Chipset Utility...to no avail!!
: Power..connections..jumpers all checked and rechecked...how do you get
: SATA drives on the ICH to be recognized???? Help!!
: kit
Thank You!
Can you Help with these Graphics Cards problems?
Graphics Cards
HI, I have a intel DG31PR mainboard, 2.2ghz core2duo, 2gig...
Graphics Cards
Is there a way to make a Matrox Millenium G450 Dual Head...
Graphics Cards
the unit of my lop top is dyna satellite...plz. help me...
Graphics Cards
Hello, I need to get my tv tuner working on vista home...
Graphics Cards
hi I installed a GeForce6200 256Mb(64bit) AGP on a compaq...
Loading problems.
Repair Service
Find Graphics Card Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
