Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
LOSING SUCTION IT APPEARS WHEN IN UPRIGHT POSITION, ALTHOUGH SUCKING (TO SOME DEGREE) IT THROWS BACK SMALL PIECES TO THE BACK OF THE VACUUM OPNTO THE CARPET BEHIND, AND THE CONTAINER HOLDING THE STUFF ISNT WHIRLING AROUND THE CONTAINER. I WONDER IF THE PASSAGE TO THE WIND TUNNEL IS BLOCKED, AND OF COURSE THAT IS THE PART I CANNOT GET TO, AS IT NEEDS A SPECIAL TOOL TO UNSCREW THE BACK OF THE VACUUM.
  • 22 Answers
Is brushes moving, if so it is clogged , usually takes a star bit to take apart to clean
Posted on Feb 09, 2009
How do I fix the suction on my Dyson vacuum?
check the pipe is saying that is clogged with something who knows lots clock that pipe make sure all pipes from your vacuum is is unstuck are clogged.
Nov 29, 2014 | Dyson DC65 Animal Complete Bagless Upright...
My Dyson DC 28 works great, until I remove the bag to empty it. I reattach it, clicking it carefully in place, but then I release the "tilt" thing to vacuum carpet, and NO SUCTION! I have to keep taking...
On the back of the Hoover is a couple of parts you can remove, one is a u bend which will trap heavier parts which resist the suction so get stuck in the bottom of this, and the other part is usually on the right at the bottom which is an acces point to the very art which you hear click. In the upright position it directs the vacuum suction up the extendable pipe, but when you pull the handle back, it should gently glide from one direction over to direct vacuum suction to the bottom plate. It's tha part which is getting stuck in the handle sucking direction. I'd check to see if it is physically damaged in any way or if something is tapped in it like a coin or something. Good luck
Nov 25, 2013 | Dyson DC28 Animal Airmuscle Vacuum 00247
Not sucking up water off carpet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fgqwe
Apr 03, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Dyson D17 won't work while upright.
check and make sure you have the gasket installed correctly that goes on the center of the cyclone and seals against the canister trap door. If this is backwards, you can lose a lot of suction and it will plug your permanent filter quickly.
Sep 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kirby Sentria shampooer
HERE is the shampooer manual. There is no suction involved picking up the water. It simply scrubs the solution off the rug and throws it in the tray in front of the Kirby vacuum.
Jul 19, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Brushes will not spin
There is a motor for the brushes, it may be bad. If no suction, there is a gasket on top of the back cover that may be missing leaving a gap and losing suction.
Apr 18, 2008 | Bissell 1699 ProHeat Clear View Upright...
Will not pick up
I had the same problem: the hose at the base is cracked or broken, hence there is no suction. The tube needs to be replaced. I only noticed it when the cleaner was at a 45 degree angle. In the upright position it appears to be intact
Aug 27, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
90 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
