Question about GE WBSE2090A Top Load Washer
Need to reinstall Clutch Clip
How do you reinstall the clutch clip?
  • 640 Answers
Hold the cluch up on shaft,,put clip into grove on buttom of shaft hold clutch up with clip pressure now your hands are free ,,but clutch clip is not on all the way yet ..now here is where the problem lies,,get a nut driver and a small hammer ..hit the back of the clip sharp and straight ..your not going to get it the first time but i know you will get it on..the trick is to push the clip on with your hand first to hold clutch and free your hands to knock the clip on..onthejob
Posted on Feb 07, 2009
How do you remove a throw out bearing on a 1997 harley
Step 1: Remove the magnetic drain plug with a wrench. (The drain plug is underneath the outer primary chain case on the left side of the motorcycle). Drain the fluid into a drain pan.
Step 2: Remove all of the screws on the clutch release cover with an Allen wrench. & also remove the clutch release cover. Discard the gasket that's located right on the inside of the clutch release cover.
Step 3: Loosen the clutch cable adjuster with a wrench to allow it to slack a bit in the clutch cable.
Step 4: Remove the retaining clip of the pushrod assembly with a pick tool. This should also release the two thrust washers located just behind the retaining clip.
Step 5: Remove the throw out bearing & Insert a new one into the same slot.
Step 6: Reinstall the two thrust washers and the retaining clip you previously removed.
Step 7: Tighten the clutch cable adjuster with a wrench.
Step 8: Replace the clutch release cover gasket and reinstall the cover by inserting and tightening the screws that you previously removed.
Aug 14, 2015 | Cars & Trucks
GE PROFILE CLUTCH CLIP PLACEMENT
to install the clutch clip, A.K.A. Clutch assembly and retaining clip...
you have to...check this image and look for the probable screws for you to open and install the clutch clip.
be very careful and always remember what your doing...
for a larger diagram go to this link
hope this helps!
thanks for using fixya
Apr 02, 2008 | GE WBSR3140DW Top Load Washer
Clutch cable sportster
Look on the underside of the clutch perch (mount).
There's an "E" clip on the end of the pivot pin.
http://lackof.org/taggart/hacking/supermicro-fan/e-clip.jpg
Remove this clip, and you can push pivot pin up and out of the clutch lever/mounting.
Apr 12, 2014 | 2000 Harley Davidson XL Sportster 883
Grand am clutch pedal
try opening the bleed nipple on the slave cylinder so that you are not trying to press against the pressure plate when you push the rod into the master cylinder.
Dec 14, 2013 | Cars & Trucks
2002 1.3 Kia Rio. Pushed in clutch pedal, heard metallic pop, half a piece of a metal ring + half a clip sitting in driver's footwell. Pedal will depress and release but clutch wont engage
I had this same problem the cable is fine its a clip on outer cable to stop it mooving when you press clutch mine poped when I tightened the clutch cable still don't have solution though waiting to payday to take it to garage
Mar 22, 2012 | 2002 Kia Rio
P0734 and P0761 codes related to 4th gear ratio and solenoid c shift problem
Its more than you think. 1. Inspect for a broken retaining clip by removing the valve body and then the valve body separator plate. Inspect the forward clutch control valve, spring, retaining clip, and valve body casting for damage (Figure 1).
2. If the clip is broken and the forward clutch control valve and/or valve body casting is damaged, replace the main control. The retaining clip has just been revised to prevent the chance of breakage. The revised Retaining Clip (F8DZ-7F194-AA) has circular cutouts on the side of the clip in place of the square cutouts on the previous design level clip (Figure 2).
3. Inspect the new main control (if required) before installing it and replace this retaining clip for the forward clutch control valve and spring if it's not the new design (Figure 2).
4. Any time service is required on any AX4N transaxle main control, inspect the retaining clip for the forward clutch control valve to be sure it is the latest design level, and replace the retaining clip if it is not. The revised clip is larger and will remain centered in the valve body casting groove. too repair estimate..400-800 dollars...Hope this help..Big shops will hurt yo pockets
Dec 16, 2009 | 1996 Ford Taurus
Problem with clip that holds clutch cable on to pedal
where is the clip at on the car? do you have a clutch cable or is it hydraulic? If it is a cable and the clip is on the outside the passenger compartment replace the clip and adjust the play in the cable there should be about a 1/4" play. If it is and self adjusting when you need to replace the cable.
Feb 24, 2009 | 2001 Volkswagen Golf
Cannot remove clutch from gearcase
there is a spring clip under the washer and C clip slid screwdriver under it to remove it no clutch does not come with gearcase..clutch pt #285785
Nov 17, 2008 | Kenmore 24032\24036 Top Load Washer
Can the clutch on a ge s4200B1WW be replaced and how do you do it ? Is the clutch attached to the motor in a way that I can remove the clutch from the motor? Do I need to purchase the complete motor and...
Hi thanks for the question ,YEs i can tell you how to remove the clutch Remove front panel .Motor is held in place wiyh 4 3/8 nuts underneath the motor remove the motor .The clutch is held in place with a spring clip at the end of motor . Remove clip Now the clutch should come off thanks for the question
Sep 11, 2008 | GE WHRE5260E Top Load Washer
GE WBSE2090A Top Load Washer Logo
75 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
