Question about Philips Kitchen Appliances - Others
Phillips KB5520 Waffle iron wont turn off at High temp.
I think that it is the click thermostat (electrovac z42/43 T 250C) that toast. How do I get a new one. Electrovac will only sell if I buy $5000 worth. There must be a distributor some where.
SOURCE: Salton Belgium Waffle Maker
I, too, was searching for that wonderful Belgian Waffle recipe and thought, no problem, I'll just look on-line. I couldn't believe it when Salton didn't have it posted on their site (if they did, I couldn't find it) and was taken to your requests for the recipe. So, I went the whole mile, or should I say traveled over mountains of files, and couldn't believe that my filing system still works after all of these years, the Salton Belgian Waffle Maker & Recipe Guide for Model No. WM-4 was right where it was supposed to be. (And my husband, and prior bosses I should add, have laughed at how I save and file everything. I'm glad I can share this with you all now...
Basic Belgian Waffle Recipe
1 cup all purpose flour
1 tsp. baking powder
1/2 tsp salt
1 tsp sugar
1 cup milk
1 egg, separated
1/2 tbl butter, melted
-Sift dry ingredients together in a bowl
-Add egg yolk and milk to the dry ingredients and beat together thoroughly.
-Beat egg white until stiff, stir 1/4 into batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated waffle mold. The light should be off. When batter is added, the light will go on. When the light goes off again, the waffle is done.
-Makes about 6 waffles.
Chocolate Waffles ("which make great ice cream sandwiches," says the recipe book.)
1 tsp baking powder
1/4 tsp salt
2 tsp sugar
2/3 cup milk
1 egg, separated
2 Tbl melted butter
1 1/2 squares semi-sweet chocolate (1 1/2 ounces)
3/4 tsp vanilla
-Add milk, egg yolk, and vanilla to dry ingredients and beat until well blended.
-Melt butter and chocolate together in microwave or double boiler. Stir chocolate mixture into batter.
-Beat egg white until stiff, stir 1/4 into the batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated heart waffle mold. (Hmm, the WM-4 isn't shaped into a heart??? Oh well, moving onward...)
Serve sprinkled with powdered sugar or cinnamon or topped with vanilla ice cream and chocolate sauce.
Posted on Feb 09, 2008
Jerseybob
  • 18 Answers
SOURCE: Waffle Iron Handle Broken - Need Replacement
Go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
Posted on Apr 02, 2008
cactus bob
  • 267 Answers
SOURCE: I have an older model
THAT IS A FUSE you should be able yo get one from someone on line GOOGLE high temp fuse 185c and see what come up . we have them here , but we are a service center . so if i can get one so can you, somewhere .
Posted on Jan 26, 2009
SOURCE: waffle iron gets to hot -waffles stick
before you make your 1st waffle, spray it really good on top and bottom plate with PAM spray, once at the beginning is all it should take- good luck!
Posted on Mar 21, 2009
jennable
  • 24 Answers
SOURCE: what is the best way to clean a waffle iron
3M makes a product called Griddle Cleaner and it works a lot better (IMO) and is not caustic (which means you won't burn the **** out of yourself using it!)
Posted on Aug 24, 2009
Waring Belgium Waffle maker shorted out and blew house breaker.
The wire near the fuse is shorting out on the metal under the lower grill. Mine did that when I replaced the fuse and turned it on. If not under warranty, it is easier to replace it for $39.95 from Costco than the hassle of taking it apart and trying to replace the fuse, which involves the time to take it apart, buying a fuse and either the crimper and connectors or a soldering iron and high temp solder, since the regular solder melts shortly after it begins heating.
Nov 12, 2011 | Waring WMK300 Professional Belgian Waffle...
Vitantonio waffle maker
have you open your waffle? if you already open it, check if theres a cut to the wires of you your waffle or check if there is a lost tread on something. thanks!
May 05, 2008 | The Home Marketplace 70047 Waffle Maker
My Waring Mod# 150 Waffle maker went out in the middle of cooking a waffle and stopped cooking. The red light is on ,but the green light wont come on.
there is a thermostat in the waffle maker if its got over heated the thermosts will have cut out,, or burnt out?
Oct 17, 2010 | Waring WW150 Waffle Maker
How long to cook and at what temp
There is not exactly a specific time. It all depends on how you want your waffles. I have been making waffles for years. set the temp to about 3 quarters as high as it will go. A lot of it just takes practice. Put the batter in and give it a few minutes. Check on it very quickly.It will most likely not be golden-brown yet so give it as much time as you think it needs. be careful not to open it more than 2 times or they will not turn out right. I have a great recipe for waffles too if you want it. Hope this helps.
Oct 09, 2010 | VillaWare V31201 Waffle Maker
Waring Waffle Maker no heat
Remove 4 Black Phillips Screws 2 on the front near the handle that flips Use a Good fitting Screwdriver These screws have a thread locker on them. They will strip the heads out if proper care is not used when removing them.Then remove the two screws at the rear of the Iron Just rear of the cooking surface. This will remove the chrome cover on the bottom of the cooking surface exposing the wiring. The thermal fuse is located under a section of insulation under a clamp held in by another Phillips screw.Do not cut or Damage the insulation. Gently pull it back exposing the fuse. After replacing the fuse, insulation ,Clamp and screws check to be sure the iron heats and cycles on and off and the ready light works properly. If it does not cycle the new fuse will blow . Good luck
Sep 22, 2009 | Waring WMK300 Professional Belgian Waffle...
Dead krups waffle iron
That is probably a thermal fuse. It is designed to open and stop heaters from working incase of over heat condition.
Meaning if you did not leave the appliance on too long with nothiung in it, the thermostat may be not opening at correct temp or the fuse was in a place where it got over heated or the fuse was weak.
You can replace it 1 time see if it worked ok but if it goes out again and you didn't see anything this time best replace it. Especially if under $50.00. Thermostat will probably run 1/2 of that. Thermal fuse 3 to 10. Try a heating AC parts store and take the old party with you.
If this helps you please help me by rating me as high as you can. Thanks for using fix ya.
May 06, 2009 | Krups 65475 WaffleChef Waffle Maker
Waffle iron gets to hot -waffles stick
Mar 21, 2009 | Gold Medal 5020 Waffle Maker
Older waffle maker is not heating up
thats a high temp fuse you can jump it out to test the rest of the waffle maker but dont leave it jumped out , its not safe that way . that fuse is hard to find try google "fuse high temp 185 c " please rate this answer , i need it to "get my wings" thanks
Jan 12, 2009 | Toastmaster Kitchen Appliances - Others
Over heating
I would try a new thermostat. I have seen these go defective. Callt he manufacture rep for any spare parts information.
Jerry G.
Jun 22, 2008 | Salton WM5ABLK Waffle Maker
Nordic ware Belgiam Waffler maker
This is how I use the nordic ware...
1.Heat pan on medium heat on one side until temp gauge is in the middle. Dont turn pan at all when pre-heating
2. Open pan and coat bottom with a little butter.
3. Flip pan over and add butter to bottom side that has no butter.
4. Add batter quickly so butter doent burn. Add semi-thick batter in pan and only let batter run so there is about 1 inch of space left on the edge.(This space will fill with batter when you close the cover)
5. Temperature gauge should stay near the middle at all times.
6. Do not open the pan to check the batter waffle color or your crispy waffle will turn soft
7. Let waffle cook on first side until the steam that comes out from the side slows down to about half of the amount of steam that came out when battle was first put in. (Should be about 2 minutes)
8. Turn waffle pan over and DON’T open the pan.(you haven’t opened the pan once to look)
9. Let cook until steam reduces (Takes about 2 minutes)
10. Keep an eye on the temp gauge
11.Remember the first waffle always takes longer to cook than the second and third waffle.
12. If you have the urge to open the pan. Open the cover slowly. If it doesn’t open up easily then it is still rare and wait one minute to open. If you need to look, you should only open the pan after you turned it over. Once you open the pan, leave it open. If you close it the cripy top will turn soft.
13. Remember trial and error
Mar 16, 2008 | Nordic Ware 15040 Belgian Waffle Maker
Kitchen Appliances - Others Logo
339 people viewed this question
Top Philips Kitchen Appliances - Others Experts
Dennis Maeder
Thomas Perkins
Thomas Perkins
Robert Kilpin
Robert Kilpin
Are you a Philips Kitchen Appliances - Other Expert? Answer questions, earn points and help others
