Question about NetGear DG834 Router
Can only connect 1 computer to router
I have a netgear dg834 router, it's been working fine for the last year or so. I have tried connecting an old laptop I have but I cant seem to do it. My desktop is connected wirelessly and is on Vista with no problems. The laptop is old, and has windows 2000. I can get onto the router fine with the laptop on ethernet cable but that's as far as I can go. It will recognise the network on wireless too but I can't get it to connect to the 'net.
  • Ved Pradhan May 11, 2010
    ok...
    what happens when you try connecting to the wireless network any errors or something like that....let me kno then i wil be able to suggest you some steps...because out here there can be 2 option eihter the network is not connecting at all or there is some setting issues
    vedhick
  • Sacraty
    Sacraty May 11, 2010
    you mean you cant surf through your browser by using your old laptop? does it says in your connection in windows 2000 limited connectivity? or its acting as if it has an internet but you cant just surf on it?
    Master:
  • 441 Answers
You might need to check if your laptop is able to get a valid IP address when connected wirelessly to the router. You can go to the Control Panel then click on network connections and look for wireless network connection. Right click the wireless network connection then click properties. Click the support tab and there you will see the IP address. You should not be getting 169.254.x.x. Where X represents numbers.
An IP address is very important. Make sure you're getting a correct IP address and it should be the IP address provided by your router. Without a valid IP address, you won't be able to get onlinwe. Your wireless connection can tell you that its connected eventhough its not getting a valid IP address.
Posted on Feb 08, 2009
Using Netgear DG834 ADSL Modem, want to add a netgear WNDR3700 Wireless Router to act as an assess point
The simplest way to add more ethernet ports is to use a network hub and connect it to the Netgear DG834 instead of the Netgear WNDR3700. This does not require any configuration.
Mar 08, 2012 | Apple MacBook Pro Laptop Computer with...
I've got a DG834 connected to my computer - this has been working ok for several years. I now am trying to add a Canon Pixma MX870 to the network. But i can't get the network to recognise that I've added...
If you can connect it directly using an ethernet cable first, ensure it works OK, then do it wirelessly, it should start connecting correctly.
If not, remove the security settings for wireless connection. Go through the procedure of connecting wirelessly, once connected, enter in security settings for wireless connection again.
Jan 08, 2011 | NetGear DG834G Router
The dsl light keeps flashing green or yellow on my netgear dg834 v5 router n i cant get on internet but it works with my netgear dg834 dg834 v2
The fact that it works ok with the dg834 v2 means you have a DSL enabled line and also connection to the internet
You also have all the configuration details within the V2 Router - you will need to know your ISP account password
Now on the V5 router - do a factory reset - theres a small hole at the back of the router 1. Press and hold the Default Reset button until the Test LED turns on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot.
Mar 19, 2010 | Computers & Internet
Tried to install Netgear DG834 router ~ no internet light
Try changing your router to BELKIN which has life time free warrenty and free replacement if it does not work
Jan 13, 2010 | NetGear DG834 Router
Cannot remember my WEP 128 number. How do I find it please?
hi,
it should be
http://192.168.0.1
http://www.netgear.com/Products/RoutersandGateways/WiredRouters/DG834.aspx
  • Username = admin
  • Password = password
    • For older devices, password = 1234
  • Regards
    Gewiz,
    Dec 26, 2009 | NetGear DG834 Router
    My home pc crashed last night. Having recovered from that I am now unable to connect to my Netgear DG834pn wireless router. My laptop is still connected fine. My ISP is Virgin.
    You'll have to unplug the router, plug it back in after a minute or so, then hold down the reset button until the lights go off and come back on again. This will reset all the information and you can relogin and set everything up the way you had it before. Remember your new login and password will be: admin
    Nov 06, 2009 | NetGear DG834 Router
    Can only connect 1 computer to 'net on router
    rourke, you shouldn't be entering the same settings on both router and desktop. I should only be on the router. It seems like something with DHCP is misconfigured on your router. Make sure it (DHCP) is enabled.
    Feb 07, 2009 | NetGear DG834 Router
    PROBLEM CONNECTING
    check on netgear's website but if i remember correctly your router, wgt624v2, isn't compatible with vista. i had to buy a new updated router, wtg624v3, last year for that reason.
    hope this helps...
    Sep 23, 2008 | NetGear WGT624 Wireless Router
    Netgear dg834gt
    I experienced a similar problem with a Vista laptop a few weeks ago. There were no apparent problems, so I uninstalled the wireless network adapter from the Windows "device manager" and then let it automatically reinstall the wireless adapter when it rebooted. The local wireless network appeared about 5 minutes after the reboot and has been working ever since. Hope this idea helps!
    Jan 09, 2008 | NetGear DG834 Router
    DG834 and DHCP
    Both your pc and your router should be set to obtain IP addresses automatically in the DHCP settingss, if you are using the wizard on the cd this should do it for you. Try not to use windows repair connection as it sets it to the wrong ip address, as your system has to match the routers, eg router address 192.168.2.1 and your pc addresss 192.168.2.2.
    Nov 07, 2006 | NetGear DG834 Router
    NetGear DG834 Router Logo
    111 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
