Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
GE 52" will not power up - green light flashes 3 times
We are experiencing the same issue as many of the others here. Our GE 52" rear projection television started having problems powering up about a month ago - the green light would come on and then off three times; after a few cycles of this the tv would power up. It seemed to get worse each time we turned the tv off, so we started leaving it on. Last weekend we turned it off overnight and now it refuses to come on at all. The green light comes on for a few seconds and there is a click/squeal sound like the tv is trying to power up; then the light goes off. After about 10-20 seconds this repeats, and again one more time. I would like to know if this tv can be fixed and if it is worth fixing! Thanks all -
atk305
  • t_r_a_d_o Feb 14, 2009
    I have the same problem with the light blinking. I also have ordered the caps and was wondering am I going to be able to see where they go and how to do it?
  • imdevo May 11, 2010
    will the instructions come with the capacitors, or do they need to be ordered seperately?
  • GE Master
  • 8,617 Answers
Replace CP150 and CP114 and CP120/ You can get the caps with instructions at the following link. They do have a minimum order amount of 10.00 so you may need to order an extra capacitor to total 10.00 but shipping is free. The parts are listed under the RCA parts category,
http://servicemanuals.vstore.ca/
Posted on Feb 08, 2009
I emailed the place with the capacitors and yes instructions come with and they offer free tech support.
Posted on Feb 14, 2009
ON our GE D52GW12 52" AFTER TURNING TV ON IT
Try resoldering the flyback transformers connections on the board. Its very common for the flyback pins to develope cracks around the pins which can cause that issue. I would check that first with that model.
Jun 13, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
Ge d52gw12 green power light flashes three times wont power on
sounds like the cP150, CP120 and CP114 capacitors need replacement. You can get the CP150, CP120 and CP114 repair kit from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.Its listed under the RCA repair kits as RCA makes the GE models.
Feb 24, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
I have a RCA D52W17 rear projection T.V. When I turned the power on the green light flashed 3 times then shut off and now it won't go on at all.
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | RCA D52W19 52" Rear Projection Television
Tv green light flashes on and off 3 times. Never comes on.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
check the components as given above and if necessary replace the components to solve the issue.
This will help. Thanks .please do rate the solution positively .thank you for using fixya.
Mar 17, 2010 | RCA D52W19 52" Rear Projection Television
My ge 52' hd rear projection tv wont turn on.
replace the flyback you can get a replacement at the following link leave a email with your model number and they will respond quickly with which flyback you need they also provide free instructions with pictures on how to do the repair.
Mar 14, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Does not turn on
when the green light flashes.. this mean the processor in the set is shuting the set down. for some saftey issue. it doesnt want to cause a fire or damage the set further. it can be one of many issues. techninicans have speacial equipment to read the set to determine the errors. this is pretty standard with this set
Dec 17, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
320 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
