Question about Kenmore 62602 Electric Dryer
Dryer will not turn on
Checked circiut breaker ok, open front door light comes on
  • 979 Answers
Turn off the circuit breakers and then back on. One pole could be tripped and the other OK and it not show. Check the wiring from the receptacle to the plug and into the back of the dryer. Look to see if all wiring is secure. If it still doesn't work, take the top off the dryer and locate the thermal overload switch next to or near the drum. Bypass it and see if it comes on. If it does, then replace it for only about 15 dollars. My guess is that it is here. Let me know how it does.
Posted on Feb 07, 2009
Dryer light bulb burned out
follow this steps and fix it. God bless you
Light Socket
The light socket can get corroded or a wire connection can come loose. You will need to remove the front panel to access the housing on most dryers.
Door Switch
If your dryer has an interior light, it probably uses a standard 40-watt appliance bulb, but check your owner's manual to be sure. If the bulb is good but the light won't come on, check the door switch, which serves two functions: When the door is closed, it turns off the light and allows the dryer to start. When the door is open, it turns on the light and prevents the dryer from starting. To check the door switch check for continuity. You should have some when the door is closed and none when the door is opened.If not replace the door switch by removing the front panel.
It blows fuses or trips the circuit breaker
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. Loose connections on the power cord cause failures and or fires. This can be checked with the dryer unplugged and removing the service cover and visually check for burning and mechanically check for tightness.
If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jul 09, 2013 | GE Profile Harmony DPGT750EC Electric...
I have a Maytag LDE9304ACM dryer. It suddently quit today. When I press the start button, the start button light "lights up", but there is not sound and no rotation. I can hear the timer. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 04, 2011 | Maytag Dryers
Dryer not turning on
YOU NEED TO CHECK THE BREAKER SEE THAT YOU ARE GETTING 110 ON EACH LEG OF THE BREAKER TO THE DRYER PLUG, OR JUST MAKE SURE YOUR BREAKER IS ON GOOD, AND SEE IF YOU HAVE 220 ACROSS AND 110 ON EACH SIDE OF DRYER RECEPTACLE, LET ME KNOE NEE TO DO THIS FIRST.
Jul 12, 2010 | Kenmore 63942 Dryer
Dryer suddenly stopped working while drying clothes. There is power because the light comes on when the door is opened.
Try turning the dryer breaker pair in the house electrical panel off then on. Try the dryer again. If still won't work, measure the voltage at the power socket across the two slanted slots--it should read ~230 volt AC. If ok, there are internal problems in the dryer--bad controller, motor not running, or the heater element is bad. If you don't measure ~230 volts, one of the breaker pair is bad or there is a loose wire between the breaker and the power socket. Have an electrician check that out.
Oct 08, 2009 | Dryers
Kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
kenmore elite won't start, Solve kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on... (More) kenmore elite won't start, I checked the house breaker box and breaker is okay. no light come on when you open the front dryer door either
Jul 03, 2009 | Kenmore 63942 Dryer
Dryer light comes on but unit will not power up or turn on
Check & reset breaker in breaker box.
Your problem may be you have lost one side of your voltage coming in. Light in dryer comes on but circuit to start motor is off.
Msg back if that does not work& we will go further.
Mar 11, 2009 | LG DLEX0001TM Dryer
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Duet Dryer
check the front door switch and make sure the outlet have power.
Apr 21, 2008 | Dryers
Kenmore 62602 Electric Dryer Logo
52 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
