I have a sony digital frame and the timer is set at 3 second interval however it continues to do the interval at 10 seconds . It is my understanding that the default setting from the factory is 10 seconds . I have gone into the menu and changed it to 3 seconds without success. Any suggestion ?
  • 5 more comments
  • drdalebrown Feb 07, 2009
    Have no option for custom settings except going to the menu and changing the time interval which i did without getting any results. Have done this several times .
    I have done that and it shows the 3 second interval however when I view the images it continues to do the 10 second interval . On the menu choices I have even selected up to 1 minute and then gone back to the 3 second interval but it still returns to the 10 second interval when being viewed.
    I would assume it is being saved since when I go to the menu settings it is showing the 3 second interval highlighted without me doing anything.
    The model number is DPF-V700 and I received no sony software with this product.
    no luck
    I agree with your conclusion. I have rechecked everything and have already taken it to the local mail station to be returned. It is too bad when things occur but they are THINGS and that will happen. Thank you again for your comments.
  • Michael Masters
    Michael Masters May 11, 2010
    Hi there. unfortunately, this device is defective. these digital frames are quite new and, the on board software can only be reset. if the on board software becomes corrupt, the only option is to return it to the manufacture for a rebuild. you can also return it back to the retail outfit that you bought it from if its not to late.
  • 19,396 Answers
Nice to know the problem is fixed.
Thanks for using Fixya.
Posted on Feb 08, 2009
  • 470 Answers
The easiest method is polling, where the data input is under application (software) control. Generally, the application reads the analog-to-digital converter output when a delay loop ends. However, the time elapsed depends on the the PC’s internal processor clock. Therefore, polling typically isn’t used when precise sampling is required. Here, the polling technique is adapted to achieve stable platform-independent programmable sampling.
Two special purpose ICs are in the PC’s chip set. One of them, in addition to providing control of several common system functions, includes two 8254 programmable interval timer ICs, offering six 16-bit programmable timers. All of the timers can work as a counter, with a master clock (1.19317 MHz) common to all. This frequency and the programming register addresses don’t vary among different platforms, assuring compatibility. Three timers are available to the user, allowing time generation from 0.8381 µs (1/1.19317 MHz) up to 55 ms (0.8381 µs × 65535). In this adaptation, timer 2, commonly used by the PC speaker for alarms or signaling, generates the time between samples. The timer, an 8254, is independent of the processor clock
see  the link of the diagram below http://electronicdesign.com/Files/29/6175/Figure_01.gif
Posted on Feb 07, 2009
    President:
  • 2,110 Answers
You cant set interval to custom..only u can change the pattern ..there are 10 patterns in ur model..
    President:
  • 2,559 Answers
Here is a link to the manual if that would help.
    Sergeant:
    Champion:
  • 289 Answers
Hi..the reason is your factory settings
could have got changed.Make sure
that u have entered the timer settings
correctly to 3 seconds.This could
be the reason to your problem.
try it out..
thank u..
  • 6,784 Answers
Unfortunately, this digital frame cannot be repaired in house. you are experiencing on board software failure. this happen with new age products at times. if you purchased a warranty, i would suggest using it to get this defective unit replaced or, you can sen dto the manufacture fo rfree repair. you will have to pay for shipping and handleing of course. hope that helps ya amd thanks for using fixya:)
  • Michael Masters
    Michael Masters Feb 07, 2009
    This product is defective. it will have to be exchanged. the timer module is malfunctioning.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
When a setting is changed from factory default to user preferred, it is required that said new settings be saved before exiting the configurations menu.
Good luck and thank you for using FixYa.
    Scholar:
  • 99 Answers
This is joyce
Make sure that when you do go in and change this setting you accept the change. dont just exit out. or it will just go back to default setting. try this and let me know how it works. it is set up just like a clock on a comp.
thanks
joyce
  • 679 Answers
Reinstall your sony frame software. and let me know
  • 3 more comments
  • rockfixya
    rockfixya Feb 07, 2009
    sorry for previous solution...
    please tell me the model number of your Sony Frame.
    Thanks
  • rockfixya
    take a try:
    remove battery from back side and reinsert after 1 min.
    it will reset your Frame.
    Thanks
  • rockfixya
    Yes, there is. Please execute Reset from Various settings in the menu. Various items that can be set on the menu return to the factory default.
    Note: make sure, factory reset delete all the data from frame.
  • rockfixya
    Do you have warranty for that?
  • rockfixya
    here is sony e-support site>>
    http://esupport.sony.com/perl/support-co...
    Thanks for using FixYa.
    Brigadier General:
  • 3,614 Answers
Try doing and setting it into a custom settings
  • micromaster
    micromaster Feb 07, 2009
    after selecting desired time intervals.
    you must press START to view slideshow.
  • micromaster
    better to reset the unit.
    push the reset switch on the rear side of the unit using a a thin object such as pin or a paper clip.
    Top Expert:
  • Computers & ... Master
  • 77,544 Answers
Remove the batteries for 5 minutes and then try to reset display time again, this is a cold restart and may take care of the problem
How to use the self timer?
In most cases you have a ring that lets you select 4 things when shooting photos. Top: Flash, Left: Clock (Timer), Right: +/- and Bottom: Flower. What you want to do is select TIMER AND the number of seconds you need. Please understand this setting is not STICKY. You have to set it EACH time you want to take a timer controlled photo. Meaning if you set it for 10 seconds and it take a photo after 10 seconds then you push the button again it will take a photo right away.
Aug 18, 2014 | Nikon COOLPIX Cameras
How do I turn on the self timer? I turn it on to 10 seconds, but its not taking any photos.
After setting it to 10 seconds, frame the photo the way you want it and press the shutter button...you have 10 seconds to get in the picture.
Jul 29, 2011 | Cameras
My Sony digital still camera F707 works very quick self timer (cca.2 sec.) May I readjust for original 10 seconds? Thanx for help!
There is no setting to change self timer, default time is 10 seconds. However you can reset camera to restore default settings by pressing reset button located under battery compartment, try it as it might correct self timer problem.
Thanks.
Jan 05, 2011 | Sony Cyber-Shot DSC-F707 Digital Camera
I have sony DSC-S500 digital camera i want to know how to take a photograph using self timer thank you Regards Sailaja
For capturing the images using Self Timer, press the Down Arrow control button continuously to select the desired mode. You can set the timer for 10 seconds and 2 seconds by pressing the continuously, If we press the button again the Self Timer will be turned off.
Press the Shutter button, the self-timer lamp flashes and a beep sounds until the shutter operates. To cancel the self-timer, press the down arrow button again. You can redice the risk of blur by using the 2-second delay self-timer.
Good Luck!
KenSolutions
Oct 30, 2010 | Sony Cyber-Shot DSC-S500 Digital Camera
How do i turn on the auto timer?
Hi, Follow these steps:
1. In any Still mode, tap Settings to open the Settings panel.
2. Tap Self-Timer/Burst repeatedly, until the desired Self-timer icon appears at the bottom of the LCD: 10 seconds—A picture is taken after a 10-second delay (so you have time to get into the scene). 2 seconds—A picture is taken after a 2-second delay (for a steady, auto-shutter release on a tripod). 2 shot—The first picture is taken after a 10-second delay. A second picture is taken 8 seconds later.
3. Compose the scene. Press the Shutter button halfway, then completely down. The camera takes the picture/pictures
Apr 13, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
I want a programmable timer that can, eg, switch on a single phase electric motor for 10 seconds every hour. It may be 9 secs or 11 secs.
You need a programmable interval timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Intermatic and Tork make digital timers with interval settings that can be set for specific short-duration with 1 minute minimum.
(Or set to pulse bell ringing with 1-127 seconds.
10 minutes is 600 seconds)
For example ET70115 single-channel timer.
The timer would be set for 24-hour operation, and then programmed for Pulse, and then set timer with 24 programs, with 1 program for each hour.
Mechanical cycle timers from Intermatic:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
1) Talento 1 hour cycle timer/ each tripper represents 1.25 minutes
2) Model C8835/ each tripper represents 15 seconds.
To operate these timers certain hours of the day, add another timer in-line.
The in-line timer could be digital, but remember digital timers are not protected from power surge and tend to have more problems, and do not have replaceable clock motors and trippers.
Apr 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
How to use the timer on a sony cyber shot 7.2mp digital camera
On your Cyber-shot DSC-W55 locate the control button:
32864f9.jpg Using the self-timer
Press cd9ebdc.jpg on the control button repeatedly until the desired mode is selected.
Conditions of the self-timer lamp:
(No indicator): Not using the self-timer
fc274e6.jpg: Setting the 10-second delay self-timer (picture is taken after 10 seconds)
996d00d.jpg: Setting the 2-second delay self-timer (picture is taken after 2 seconds)
Press the shutter button, the self-timer lamp flashes, and a beep sounds until the shutter operates.
Hope this helps.
Thank you.
Oct 16, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Using self timer on my digital camera
1 In any Still mode, tap Settings to open the Settings
panel.
2 Tap Self-Timer/Burst repeatedly, until the desired
tripod).
3 Compose the scene. Press the Shutter button halfway, then completely down.
The camera takes the picture/pictures after the delay.
Apr 29, 2009 | Kodak EasyShare V1073 Digital Camera
How to use selftimer on Samsung S630
Hey hpnotiq_babe,
Directions on how to set the self timer on this camera are on page 27 of your camera manual. I have included a link to a PDF download of your camera manual in case you need it. I have copied the instructions on how to set the self timer on your camera below. I hope this helps!
● Selecting the self-timer
1. Rotate the MODE DIAL to select a RECORDING
mode with the exception of VOICE RECORDING
mode.
2. Press the SELF-TIMER button until the desired
mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon
appears on the LCD monitor. In Movie Clip mode,
only the 10-second self-timer will work.
•2SEC self-timer ( )
: Pressing the shutter button will allow an
interval of 2 seconds before the image is
taken.
•10SEC self-timer ( )
interval of 10 seconds before the image is taken.
•Double self-timer ( )
: A picture will be taken after about 10 seconds and 2 seconds later a
second picture will be taken. When using the flash, the 2-second self-timer
may be delayed for longer than 2 seconds depending on the flash charge
time.
3. When you press the SHUTTER button, the picture will be taken after the
specified time has elapsed.
http://www.samsungcamera.com/customer/cus_main.asp?cat_uid=11
Sincerely,
Allan
Go Ahead. Use Us.
Jul 24, 2008 | Samsung Digimax S630 Digital Camera
Setting the camera timer
by the way in setting the timer for your camera here is what you are going to do...
-turn the camera on
-set the camera in recording
-press the Right Button beside the menu button (the incomplete circle)
-and then you will see that there will an icon showing in the left side part of the screen of the camera.
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of VOICE RECORDING mode.
2. Press the SELF-TIMER button until the desired mode indicator displays on the LCD monitor.
A 10 second, 2 second or double self-timer icon appears on the LCD monitor. In Movie Clip mode, only the 10-second self-timer will work.
•2SEC self-timer (icon of incomplete circle with 2S)
: Pressing the shutter button will allow an interval of 2 seconds before the image is
taken.
•10SEC self-timer (incomplete circle)
: Pressing the shutter button will allow an interval of 10 seconds before the image is taken.
•Double self-timer (double incomplete circle)
: A picture will be taken after about 10 seconds and 2 seconds later a second picture will be taken. When using the flash, the 2-second self-timer may be delayed for longer than 2 seconds depending on the flash charge time.
Nov 26, 2007 | Samsung Digimax S730 Digital Camera
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
