Question about Pride New Mobility Victory XL 4 Wheel Scooter
Scooter is running slow
MY SCOOTER IS RUNNING SLOW AND THE CHARGER IS LIGHTING UP AT THE TOP AND BOTTOM LIGHTS BUT THE MIDDLE LIGHT S ARE NOT LIT UP CAN YOU HELP THANKS
  • 103 Answers
Have the batteries tested with a load tester. Usually when it starts to move slow it means the batteries are going.
Posted on Mar 09, 2009
My victory xl has new batterys an was running well until yesterday now the machine wont move and the batterys are up to charge
Posted on Jul 26, 2010
I have a Taotao electric scooter not a mobility scooter the scooter is fully charged the lights and horn work fine but when you turn the throttle nothing happens it makes a kind of clicking sound
Not familiar with your particular scooter - but I am well versed with electricity. The issue you're seeing is likely a result of a poor connection somewhere. The amount of power (current in amps) required to operate the horn or lights is a small fraction of that needed to run the motor.
You should trace larger sized wires/cables from the motor back as far as you can - ideally to the battery if possible. Remove, thoroughly clean and reconnect each of these cables under each terminal screw - one at a time. This way you'll know any unconnected cable goes on the only terminal that is removed.
At this point, you should have 100% good connections for all high current loads - including the motor and will probably be able to use the scooter. Placing the battery on a slow trickle charger overnight will help ensure that the battery is fully charged - not just enough to operate the horn or lights.
May 11, 2015 | Electric Health & Beauty
Why is my scooter running slow?
Hope its this. Batteries fully charged. You should take to dealer. I bent my go lever. I bent it back alittle. There is little switches under the cover, they can moved. Lever is not make proper contact
Sep 28, 2014 | Pride Revo 4 Wheel Scooter
My wheeltech mobility scooter running slow on top speed
Hi, sounds like it's due a service , that should involve the brushes being inspected and replaced if required and making sure the brake is releasing okay...
Need more info then contact via my website...
Regards
Rob
www.gewizrepairs.co.uk
Nov 22, 2013 | Electric Health & Beauty
Battery .the charged light is on but no power
Ross I'm a little confused by your problem what charged light? Do you mean the battery level lights are all lit and it won't move. Or is the charger light on the charger and it won't move?
If you have charged the scooter and the battery lights show full charge then check to make sure that you are not in freewheel. If you are not in freewheel then the problem could be the throttlepot or speed control pot or the cable running to the rear from the console. It is difficult to tell you exactly what the problem is because it could be one or multiple problems. I suggest you contact your provider (where you got the scooter) and see if they can check it for you. Now if Medicare purchased your scooter for you you can call a service company to get it repaired. Repair Xpress @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 hope this helps Sorry I couldn't give you a definite fix
Sep 08, 2010 | Health & Beauty
PRIDE CELEBRITY DX RUNNING SLOW
Hi
Please Check your Potientiometer also known as a Pot, This is your Speed Control and it may be on the way out after 4 Years ,
My Own Pot Packed up after 11 Months, Try to get a Second hand one as they are Expensive to buy,
Good Luck, Gerry.
Jul 19, 2010 | Pride Celebrity X 4-Wheel Electric Scooter...
Scooter runs then stops I turn offf the key and then it runs again and then will stop again also the scooter seems to have lost speed over time
the batteries are worn and problably need replaced , the computer will stop running the scooter at threshold voltage, older batteries and will hit this threshold voltage and slow the scooter
Jul 09, 2010 | Electric Mobility Mobility Electric Power...
Scooter dash lights flash up and down .were normaly they come on and stay at top .they just constantly run up and down ..batteries show on charger in boot .that its fully charged
Hi. Some scooters will show a pattern like this while the charger is operating, but when the charger is turned off it should stop. Some internal chargers have a relay that is activated while the charger is on to disable the scooter. Does the scooter operate properly after the charger is turned off? If not, then unplug the charger where it connects to the batteries inside the scooter and see if this helps. If this helps, you might need a new charger.
Good luck. Neil.
May 14, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
Mar 23, 2009 | Golden Technologies Companion II Travel...
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Dec 07, 2008 | Razor E200/300 Electric Scooter Battery
Pride New Mobility Victory XL 4 Wheel Scooter Logo
831 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
