Question about RCA M4204 MP3 Player
Cannot install itunes on windows vista pc - win install error
I download the vista version of itunes and when i click on install I get the message "Windows Installer Service could not be accessed"
  • Marty Haas Feb 07, 2009
    ignore this, i do not have an RCA MP3 player. Not sure why this is here. I posted my real problem.
    Problem Solver:
  • 6 Answers
VerY simple FIX yet hard to find. This will solve your problem in moments. You will be able to Install your Itunes.
1) Go to help and open your registry editor.
2) click HKEY_LOCAL_MACHINE
3) Click SYSTEM
4) Click CurrentControlSet
5) Click Services
6) Click MSIServer
OK now go down the list and look at for the word ,
WOW64 REG_DWORD 0x00000000 (1)
Change the (1) to a (0) instead.
Your done!! Easy, takes just a few seconds! The will FIX the Windows Installer issue and those of you who have problems installing Itunes on VISTA.
It has caused no further issues on my Vista Computer. Everything works fine.
Posted on Jul 13, 2009
The problem is from ownership of the files. Go to control panel.then programs, then remove the programs in the following order: itunes quicktime apple software update apple mobile bonjour apple application support. Now comes the tricky bit. Go to each of the folders in the program directory in turn starting with itunes. Right click the folder and click delete. If it will not let you delete the folder then right click and go down to properties. Go to the security tab. Highlight yourself and give yourself full control. If it will not let you do this then go to advanced then owner and highlight yourself. Click on edit, highlight yourself.The important bit is to put a tick in replace owner on all subcontainers and objects. Click ok ok close all the windows and go back to the folder again. Right click and go down to properties and highlight yourself and give yourself full rights. apply ok. then when you right click on the folder you will be able to delete it. if not go to the subdirectories and do the above. Do this with all the apple related folders mentioned above in the program file folder and also the program data folder . clear all contents in the temp directories of program and program data folders. This takes some time but it does work. Restart your computer and reinstall itunes and itunes and quicktime will work . solved
Posted on Sep 27, 2010
I have a new dell laptop with vista and cannot install itunes - it freezes and comes up with an error message.
What does the error message say? Post the exact contents here.
Just in case, check to see if your computer is 32-bit or 64-bit by going to computer properties. Make sure you got the correct version of iTunes for your computer.
Check this Apple support page for more information.
May 05, 2011 | Apple iTunes
Downloaded itunes onto PC which has Vista. Can't open itunes; get message: Apple Application Support was not found. Uninstalled & reinstalled twice with same results.
Itunes has two version for windows vista, may be you are using the incorrect version.
Check you windows version : right click in COMPUTER then click in PROPERTIES and see if you
have a Windows Vista 32 bits or Windows Vista 64 bits.
Go to http://www.apple.com/itunes/download/
If you click on the big blue button, you are downloading the 32 bits version.
if you go down a little bit more, you can see in blue letters "64-bit installer".
Take the correct version and that's it.
Good luck. Remember to rate my answer, please.
Feb 17, 2011 | Apple iTunes
I have windows vista and when i try to run itunes i get this message. 'the version of this file is not compatible with the version of windows you're running. Check you're computer's system information to...
Hi, you can check which version of Windows you have by clicking on the Start button (the Vista orb) and from the Start menu, right click on Computer. Choose Properties from the menu that appears, and you'll see a lot of information about your computer. There should be a line that says whether you have a 32-bit version of Vista or a 64-bit version. Depending on which version you have, you'll need to download the compatible version of iTunes. You can download both versions here:
For the 32-bit version, click the Download Now button; for the 64-bit version, scroll down to where you see the link for 64-bit installer on the left hand side and click it.
Hope that helps!
Nov 20, 2010 | Dell Inspiron 1525 Laptop
Hi I am Farah, and as I wanted to download java , it came thet" " is not valid win 32 application'. What shoudl I do? Thx
It is possible that you are attempting to install a 64-bit version of Java when you have a 32-bit operating system. Check your operating and confirm this. In Vista you can find this using Start > Control Panel > System. This is similar if you have Windows 7. Here is what it looks like:
If after that you, you follow these instructions from Sun (Java) to locate and install the 32-bit version.
Error: x64.exe not a valid Win32 application This article applies to:
  • Platform(s): Windows 7, Vista, Windows XP, Windows 2000, Windows 2003
  • Browser(s): Internet Explorer, Firefox, Mozilla 1.4+
  • Java version(s): 6.0
SYMPTOMS
While trying to install Java a user gets an error message similar to:
' ... x64.exe not a valid Win32 application'
CAUSE
The error message is a result of trying to install a 64-bit version of Java on a 32-bit operating system.
SOLUTION
User needs to install a 32-bit version of Java software, since a 64-bit version is not compatible with their 32-bit operating system.
Follow these steps to download 32-bit Java
  1. Go to Manual download
  2. Click Windows XP/Vista/2000/2003/2008 Online.
  3. The File Download dialog box appears.
  4. Choose the folder location.
  5. (Save the file to a known location on your computer, for example, to your desktop).
  6. Click Save.
  7. Close all applications including the browser.
  8. Double-click on the saved file icon to start the installation process.
Nov 07, 2010 | Computers & Internet
Cannot download itunes since a recent firmware upgrade for ipod touch, went to apple forum site and told to delete apple,quicktime, apple mobile device support and now i can`t get itunes to download onto...
Make sure VBScript is installed, turn off script blocking in anti-virus and personal firewall software, reregister VBScript, and then install iTunes." Resolution Download and install the latest version of iTunes.
Install the latest VBScript engine from Microsoft for your Windows OS platform Windows 2000 Download and install VBScript version 5.6 for Windows 2000 from Microsoft, and then try installing iTunes or QuickTime again. Windows XP Download and install VBScript version 5.7 for Windows XP from Microsoft, and then try installing iTunes or QuickTime again. Windows Vista No download necessary. The latest VBScripting engine (version 5.7) is already included with Vista. Follow the steps below to register the VBSScript again if you still have this issue in Vista.
Register the VBScript engine again If the latest VBScript engine is already installed, register it again. Note that you must be logged in as administrator or logged in as a user with administrator privileges for the computer to execute these steps.
For Windows 2000 or Windows XP: 1. On the Start menu, click Run.
2. In the "Open" field dialog box, enter the following command and click OK:
regsvr32 vbscript.dll
3. A message should appear stating that the "DllRegisterServer in vbscript.dll succeeded."
4. Click OK and try installing iTunes or QuickTime again.
Oct 19, 2009 | Apple iTunes
Cannot download itunes8 message problem with windows installer
You may need Windows Installer Version 3.1 or higher to install iTunes (and most other programs).
May 16, 2009 | Acer Aspire 5050-3242 Notebook
Problems downloading software online on new computer (Vista)
i m download this game GTA vice city but this is not download my computer why?
Mar 21, 2009 | Compaq Presario 5000 PC Desktop
Problem to set up java with windows vista
there is a possibility that the file was not downloaded properly, so try downloading it again fully and retry installing.
Make sure that you have the matching bit version. If your windows is a 32 bit version one,, make sure you din download the windows x64 package of java ..
Apr 12, 2008 | Computers & Internet
Error Message 2738 ipod shuffle install
Symptoms In some instances, the iTunes and QuickTime Installers may unexpectedly quit during the "Preparing to Install" stage of the installation with the following message:
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2738. In some cases, the error message may read
"iTunes could not be installed because Visual Basic Script (VBScript) is not installed or has been disabled. Make sure VBScript is installed, turn off script blocking in anti-virus and personal firewall software, reregister VBScript, and then install iTunes." Products Affected iTunes 7 for Windows, QuickTime 7 (Windows), Microsoft Windows 2000, Windows XP, Windows Vista
Resolution Windows XP or Windows Vista
Download and install iTunes 7.6 or later.
Dec 26, 2007 | Apple iPod shuffle Second Gen. Silver (1...
RCA M4204  MP3 Player Logo
629 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
