Question about HP Photosmart 4180 All-in-One Printer
HP F4180 won't turn off
We've tried resetting to factory defaults without success. We can't get the machine to turn off at all. All the lights are on!
Any suggestions are much appreciated.
Thanks!
    Problem Solver:
  • 3 Answers
I had this problem for quite a while you have to tap they power button a couple times at first it takes a few times to figure out the correct timing but then you will be able to do it with just two correctly timed taps. I know it sounds silly BUT IT WORKS!!
Posted on Feb 24, 2009
Was givin a used unit and want to reset it to factory default
To reset BIOS to factory default settings, press "F10" during the POST section and then press "F5" to reinstall factory BIOS settings, Save the new settings and reboot.
To recover to a clean install of the Operating System you will need a set of Recovery Disks. If you do not have them, and the machine will load Windows successfully then you should be able to create them from the "HP Backup & Recovery Manager" although whether this will return to factory default or simply create disks for recovery to its current state I am not sure. Alternatively I understand you can get Recovery Disks from HP, although whether still available for this model - I don't know. Hope this helps.
Feb 16, 2014 | HP Compaq dx2400 Microtower - KR601UTABA ...
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
All the lights are blinking! I cant turn it off
To resolve the issue, follow the below steps:
Step 1: Follow the weblink
Rather that sending you steps in text, i will refer u to the weblink. Where all the info is explained with graphics.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00867129&cc=us&lc=en&dlc=en&product=3177566
click on the weblink and follow the steps.
Step 2: Power cycle
Follow the steps below to power cycle your all-in-one:
Verify that the unit is switched on. Disconnect the USB/Ethernet cable from the All-in-One and also disconnect power cable from All-in-One and also from wall outlet.
Wait 20 seconds.
Plug in the power cable to All-in-One and also to wall outlet.
Step 3: Semi full reset
Note: A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models.
1) When the printer is turned ON, Disconnect and then reconnect the power cord.
2) When the lights begin to flash, press ON and CANCEL buttons simultaneously.
3) When the printer turns OFF, release the buttons.
4) Now turn ON the printer
Jun 22, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
I changed my ink, but the printer will not print in color. It only prints in B&W. It is a f4180. i have windows home vista. i need to print a school project by tommorrow - help!
Try unplugging the printer for five minutes and than plug it in back in and turn it back on. By doing this we are resetting the printer to the Factory Defaults, (settings that were set when it left the factory) Hope fully this will help you.
Jun 03, 2010 | HP Deskjet F4100 All-In-One InkJet Printer
Want to reset to Factory Default
with HP the recovery console activation should just be F11 without the CTRL.
If your recovery partition does not work, or is corrupt/missing then your best bet is to either order the recovery discs or take it to a local tech that may have access to OEM discs that can be used with the license key on the machine to reinstall the operating system.
May 01, 2009 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
Cannot turn printer on
might as well do a reset:
for partial reset:
1.unplug the power cord wthout turning the printer off
2.while the cord is unplugges, press # and number 3 simultaneously
3.hold the 2 button for 10 seconds while inserting the plug back
4.release the 2 buttons when the printer reinitialized.
for semi-full reset:
follow same steps but press # and number 6
semi full means the printer is set back to factory settings or default settings.
Mar 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
Reset to factory default
The router's admin page is http://192.168.1.1 or http://192.168.0.1 and the default password should be either "admin" or "password" without quotes. There should be a choice under "Setup" called "Factory Reset". That will erase the settings and reset it like new.
Alternatively, you can follow the procedure as given below on all the brands I've tried (Belkin, D-Link, Linksys)
1. hold the reset button for 30 seconds (don't release)
2. unplug the power (still holding reset) for 10 seconds
3. plug power back in (still holding reset)
4. hold reset for another 30 seconds - the lights will usually begin flashing in some odd pattern
5. release the reset button
6. wait 1 full minute or until the lights stop flashing
7. unplug the power for 10 seconds, just to do a reboot
8. verify the settings (e.g. SSID) are back to the defaults
Get instant online Linksys router/wireless router support at http://www.vtechsquad.com/linksys-router-support/ to fix Linksys router/wireless router problems.
Oct 25, 2008 | Linksys Wireless-G WRT54G Router
Factory Default Reset Procedure
Hold the reset button in for 10-15 seconds... Now its defaulted back to factory and the user name and pass will both be admin
May 07, 2008 | Linksys Wireless-G Broadband Router
HP Photosmart 4180 All-in-One Printer Logo
345 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
