2001 maytag neptune front loading washer will not spin out fast
It will not spin out fast and the clothes come out wet. Anyone know what the problem could be? Thanks
  • sarashertzer Feb 22, 2009
    I have the same problem with my front loading frigidaire washer. Should I try and get it repaired or should I purchase a new washer?
  • 640 Answers
Motor control and motor defective,,,theses parts are under warranty..onthejob call maytag for parts,,and if you need help installing them post me at onthejob
Posted on Feb 07, 2009
My neptune front loading washing machine will not spin on the spin cycle. Clothes are soaking wet.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Hi, my neptune washer will not spin clothes dry they come out sopping wet. can you help? thanks
if there is water standing in your washer your pump is clogged clear it out and will correct the problem ; if there is no water in the machine when you complete the cycle but the clothes are wet it did not spin more than likely your door switch is probably bad replace it
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Epic washer doesn't spin fast. spins, but slowly. clothes coming out wet, very wet. it started after i washed a heavy wool sweater.
Check the filter, make sure rinse hold is not on, check the drain hose is not blocked, lastly check the brushes, remmember unplug first.
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
My clothes are wet at end on my maytag neptune washer machine
If you are spinning them on the highest setting try to put it on medium. Sometimes the highest setting is too fast and it will bang around and not spin properly. A lower setting will work better and the clothes will still come our dryer.
Sep 14, 2009 | Maytag Neptune MAH6500A Front Load Washer
Maytag neptune frot load will not reach full spin speed.
It will not spin while washing, it's more of a rocking back and forth. As far as the spin cycle. If it's not reaching full speed I bet you'll notice that it's not doing the full cycle because the load is bouncing around and cause the washer to shut off. take some of the clothes out and watch it spin the water out.
Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Clothes still wet on Maytag Neptune Front load - only light load
any front loader should be operated with more than on piece of clothing in it. otherwise it is unable to balance the load.
Mar 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytage neptune front load washer not spinning
sp is the pump not running remove the hoses and clean out the pump the pump is in the back the dran hose goes to it
Nov 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front load
sounds like possible blocked internal filter or partial pump blockage
Dec 07, 2007 | Maytag Neptune MAH5500B Front Load Washer
Clothes still wet washing on Maytag neptune
Your pump, or the hose between the pump and drum, might be clogged.  Could be spare change from unemptied pockets.
Oct 17, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
