Question about GE WBSR3140DW Top Load Washer
Washer Overflows Fills with water, but never switches to agitating mode. It overflows.
    Scholar:
  • 99 Answers
This is joyce
Go to Ge.com and download the manal to the washer you have put in your model # and download the paperwork, it sounds like the switch that controls the cycles. you have to remove the back to get to this switch but you may want to inquire about this from some one that has done this before. you can get this part from a part store that sells part in your are that works on washers and dryers.
if you need any help finding help let me know
thanks
joyce
Posted on Feb 07, 2009
Washer continuously fills
Not sure if you mean that it fills all the time and overflows or you mean that it just always fills and never has enough water.
The first problem would refer to a faulty water level switch - need to replace.
The second would be that the washer drains as it fills - if the drain hose is lower than the washer, inspect the anti-siphon valve.
Apr 10, 2014 | Maytag PAV2300 Top Load Washer
Washer overflows
Washer fills with water and overflows:
The water pressure level switch is a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
Feb 13, 2014 | Frigidaire FGZ831A Top Load Stacked Washer...
The washer fills and begins agitation, but continues filling and overflows the tub after agitation starts. Does not fill when unplugged.Both hot and cold fills are affected.
There is a pressure switch which stops the fill cycle, It is attached to the drum by a clear
tube. as the water comes up in the tank, pressure builds inside a cup that is molded on
the side of the tank, if the inlet to the pressure switch becomes plugged with lint, it
will cause this symptom. The switch is located behind the control panel. Unplug washer
and remove two philips head screws at bottom corners of the panel. It will usually hinge back. Inside is the float switch. Try removing the tube and blow into it, this will
clear the end, then see if it corrects the problem, if not then the switch has failed.
Hope this is of help to you.
Mar 10, 2011 | Kenmore Washing Machines
When washer fills it won't cut off. Also it won't agitate either.
Hi, I'm assuming the washer fills and overflows. If so, the part we call the pressure switch has gone bad. There is no fix for this. You will need a new part. You will need your make and model number to take to your nearest appliance parts house. Hope this helps.
Jan 20, 2011 | Whirlpool Washing Machines
Washing machine keeps filling and will not go into cycle
if it overflows and dosent agitate check your pressure switch and hose.if it overflows and agitates you have a bad fill valve. if it fills and pumps at the same time check your drain hose. it should be higher than the water level of the machine or it will siphon out.
Jan 23, 2010 | Maytag Washing Machines
Washer overflows water when filling
The water level switch is either bad or the tube connected to it is plugged. Tube goes from bottom of tube to switch. Take this off of switch and blow it out. Should solve problem, if not replace water level switch.
Jun 15, 2009 | GE Washing Machines
Fills up with water and wont stop
if it still fills , with power off, the valve is letting by water and has become faulty,if water stops with power off,check for smudged powder at the lower part of the pressure switch pipe giving a false read to pressure switch,other than that the pressure switch has become faulty,look at the pressure switch pipe first for blockage,hope this helps
May 07, 2009 | Whirlpool WTW5200S Top Load Washer
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Washer fills continuously until it has overflown
I found this answer on Repairclinic.com. Hope it helps...
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Oct 22, 2007 | GE Hotpoint Super 3.2 cu. ft. Washer
GE WBSR3140DW Top Load Washer Logo
55 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
