Question about Electronics - Others
Phillips photoframe won't read my SD card
My Phillips digital frame (model 7FFI) won't read either of my new 4 gig SanDisk SD cards. It has no problem with my old SimpleTech 512M card. Any ideas?
  • mstryhrs06 Feb 18, 2009
    SO ANNOYING! It wont even register it as being in there. No idea what the problem is.
  • Anonymous May 06, 2009
    I have the same issue, it won't even recognise any type of card that I put in.
    Not found a solution yet though!
  • 26 Answers
SOURCE: Garmin Nuvi 200W SD card Problem
The problem is that the US 2008NT map takes up about 900MB, the update itself will push that up to 947MB. The Nuvi 200w has an internal memory of 1GB, the Help folder takes about 35MB and the text and speech files for all those other languages that you don't use or understand takes up about 30MB. So if you add all those up you come up with more than 1GB, and the SD card cannot be used for the US mapset (preloaded). It can only be used for additional map sets that you want to add like Europe, Mexico, Australia etc etc. So how do you update? Well you are going to have to decide if you really need all those extra voice and text languages such as Aafrikans, German, Spanish etc etc. If not, get rid of them. Also consider getting rid of the Help Folder since it's actually pretty useless, but I leave that up to you to decide.
Now for 3-belmont-E, your friends and yourself should have realized that the Garmin units read SD, not SD-HC which are different. When you got the 1GB SD card, it should come up as another drive. It will not show up as a folder on the Garmin unit itself, for example....
Your main drive is C: and your CD/DVD is D:, when you plug in the Garmin it becomes E: but if you have an SD card that will become F: so in reality your Garmin device will now be E and F, with F being the SD card. This is of course if the SD reader in the unit did not get damaged by you guys putting in the SD-HC card into it.
Posted on Jun 12, 2008
pauman
  • 248 Answers
SOURCE: Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector. Navigate to the \DCIM\100Frame directory and delete all the Phillips advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
(Look for Image Resizer in the right column). After installing it, "Select All" pictures in the directory you created, then right click and select "Resize Pictures" from the context menu. Choose the 640x400 radio button. Sort by size and copy all the small ones into the "\DCIM\100Frame" directory on the frame drive (Called Removable Disk on my PC).
Posted on Jun 20, 2008
aminic
  • 61 Answers
SOURCE: Micro SD 2 GB just stopped working
The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
Posted on Sep 21, 2008
  • 7 Answers
SOURCE: card read error
Put the card back into the camera and off load/take off your pictures (Put them on the computer). Then, put the card back into the camera and go to your options menu. Find the format feature, and format the card. Take some new pictures and then try putting the card back into the picture frame. Does it work? If so, transfer the images from your computer back to the card. If it continues to work, then Great! If not, more than likely there is an improper or corrupt file among your photos.
Good Luck!
Posted on Dec 12, 2008
  • 119 Answers
SOURCE: problem with reading Sandisk 4gig hc micro sd card in my computer and laptop
The problem is that a 4 GB micro sd card is HC (High Capacity). You will need to buy a card reader that can read HC micro sd cards (cost +/- € 8).
Very important: check if your mobile phone works with high capacity micro sd cards because a lot of phones don't work with HC micro SD cards.
Don't forget to rate, thks
Posted on Jan 08, 2009
SDHC Card 4 GB SanDisk will not format. get
The Z740 uses SD cards, not SDHC cards. SDHC cards will physically fit into the card slot but are not compatible. It's a hardware incompatibility, not updatable in firmware. You'll have to stay with 2GB and smaller SD cards.
Feb 06, 2010 | Kodak EasyShare Z740 Digital Camera
Hiya, I have a philips photo frame 9FF2
It seems that SD cards bigger than 2 GB are not supported by this photo frame... I have the same problem tsssss...
Jan 03, 2010 | Philips PhotoFrame -10 Digital Picture...
Digital frame won't read memory cards
Did you format the card before trying to use it?
Dec 30, 2009 | Polaroid T831 Digital Camera
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
E250 doesn't read the new 4 gb card I got to put more songs on
your phone may not read SDHC cards... try getting one without SDHC (High Capacity) on it... you may have a 2Gb max size.
Jun 25, 2009 | SanDisk Sansa e250 MP3 Player
Downloading photos from computer to phillips 8ff2fpb photoframe
Your PhotoFrame does not have internal memory acording to the Phillips data sheet, therefore you need to load your pictures directly onto a memory card (one from your camera will proabably work.) If that isn't convenient, you can generally get a good price on a SD memory card which is supported by your PhotoFrame.
If you wnat to transfer pictures from your PC to the memory card and have a card reader, you can transfer the pictures in Windows Explorier from your PC to the memory card and then plug the card into your PhotoFrame. If you do not have a card reader, plug the memory card into the PhotoFrame and connect it to your PC using a USB cable (you may have to buy one as acording to the Phillips data sheet it is not supplied.) When the PhotoFrame is pluged in it will appear in Windows Explorier as a new hard drive, and you can copy your pictures to it.
I hope this helps,
Mike
Jan 03, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Phillips Photo Frame does not recognize SanDisk 1 BG SD card
I used a format program from http://www.sdcard.org/consumers/formatter/eula/
Nether Sandisk nor Phillips tells you the card needs to be formatted FIRST if it is
new and out of the package. It works fine now.......... in the Phillips Photo Frame model 8FF2FPB
If you do not format it first - your PC software WILL NOT even know it is inserted into your device!!
I need no further help on this
Thanks
JohninTexas
Dec 29, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
IPAQ 6515 doesn't recognize new HP 8Gig SD card
Your 8 Gig card is a SDHC (HC=High Capacity) Card. All HC cards use a different format, which the 6515 can't use...
The biggest capacity the 6515 can use is 4 gig on the SD and 2 gig on the mini SD.
My 4g Transcend card and 2g Sandisk cards have been faultless for about 2 years now.
Sorry, but the 8 gig card is a wonderfull card, but is useless in a 6515
Dec 13, 2008 | HP iPAQ hw6515 Pocket PC
RCA TH1101A, after inserting micro sd card "Please wait"
It will support earlier Sandisk 1GB and 2GB micro SD cards
Dec 11, 2008 | RCA TH1101 MP3 Player
4GB micro sd card.
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
Electronics - Others Logo
476 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
