Model 405000x8c
SOURCE: lawn tractor shuts off after 20 minutes of running
How old is your ? Sounds like ignition problem,If your engine is older you would have points when the points are bad they can stick together and will result in shutdown after unit cools a little it will restart !
SOURCE: 19.5 HP Craftsman Lawn Tractor won't start...any ideas?
Does the motor even turn over. Have you checked the carb. for gunk or gas trash.
SOURCE: Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
SOURCE: Stalling Craftsman LT 1000 Lawn Tractor
I have a Craftsman 21 HP Twin riding lawn mower and have replaced both spark plugs, filter and battery. New gas. New Oil....still will not start?? HELP!!!
SOURCE: John Deere 115 lawn tractor - won't start.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Check the Blade Safety Switch. Also check if the Carburettor requires a good cleaning and overhaul or not. After that check if there is any air leak or air in the fuel line.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
