Question about Canon PIXMA MP150 All-In-One InkJet Printer
Error code E5 / BLACK INK
THE BLACK INK RAN OUT AND I REPLACED IT AND GOT A CODE E5 WITH THE BLACK INK LIGHT BLINKING. SO I REPLACED AGAIN THINK THERE MAY BE A PROBLEM WITH THE INK CARTRIGE, SO I REPLACED IT AND HAD SAMETHING HAPPEN AGAIN. E5 / BLACK INK LIGHT BLINKING.
WHAT CAN I DO AND WHAT DOES THIS MEAN?
HELP PLEASE
  • 1 more comment
  • bambulta Feb 12, 2009
    I have refilled the same cartridge, it used to work. before inserting the cartridge i had to fiddle with the black cartridge, pushing it a few times. could that be the problem? or it might be the refilling? and anyone knows how many cc it should take? perhaps i overfilled...
  • dariomejia67 Feb 19, 2009
    no imprime ,no da senar de nada
  • rams reddy Feb 25, 2009
    after refilling black ink light keeps blinking and it says u ran out of ink
    Novelist:
  • 103 Answers
Do a search for resetting ink cartridges after refilling! Hope this helps - fotobean
Posted on Feb 21, 2009
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
Nov 25, 2011 | Canon Pixma iP2700 InkJet Photo Printer
How to error e5 how to go to service mode
Hum....e5 error.
The truth is...there is no solution for e5 error.
U may see some solutions through web, however, non of them works..
The only way you can get out of e5 error, replace with new cartridge..
or...
prevent it...before you face it!!
How?
Whenever you take out the cartridge from printer, make sure unplug the power code first..
and then take and refill or whatever...
And then when you put it back....do it when power code is unplugged as well.
Personally, I refilled and used CL831 more than 8 times..
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 19, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I changed my catrige but its showing the error E5
I use refilled cartridges. Okay, the printer says ink low, but it does that all the time. I ignore it. However, yesterday it printed not a problem, today it gives me code 5. Does anyone have a real solution or should I throw the printer away?
Jun 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Installed new cartridge and it says low on ink why? also what does the red light mean when it comes on and why?it will not go off.
I have the same problem. I replaced the black and both lights blinking now. Then the red light came on the power switch indicator and an error code 3802 and 3808 message that says "call support". No answer at their phones.
I think I need to change brands.
May 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
E5 light
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 25, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My MP160 has an error code E5 and nothing I do will move it
I think you may have answered your own question.
Here is a list of error codes for your printer, as you can see the code E5, means the cartridge is not installed properly or un-supported.
I would remove cartridge, check slot for debris, clean contacts on cartridge, re-seat cartridge and then try again. If all fails then try a new cartridge, as the other one could be faulty.
If you still have no joy, you probably have a faulty print head unit.
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Feb 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Can not print
replace your cartridges clean the ink splatter sponge and make sure the cartridges are set in correctly and the printer is aligned this is crutial this will be in program specs
Jun 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Ink Cartridge Refill Error E5
First take a smooth cloth or cotton
take a cleaning liquid like spirit, thinner etc., (note - not cleaners)
clean the golden chip with out giving much presser
in the same way clean the other side of the printer also
now test it
90% Problem will solve
Thanku
Take care
Bye
Apr 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Error code E5
hi dear
hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
full
Direct Printing
E22 Carriage error
E29 EEPROM error
try this methode
Methode 1
service mode. (Waiting formenu selection)
button pressing
procedures below.
procedures below.
that's all
maybe it can fix your problem
thanks
cropp
Mar 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
456 people viewed this question
old marine
old marine
