Question about Denon Audio Players & Recorders
Denon DTR-2000 DAT recorder play problem
My DENON DTR-2000 DAT tape recorder not play but record!
All recording tape possible play other DAT players.
What is problem?
Thanks
4 Suggested Answers
robotek
  • 1512 Answers
SOURCE: Luxman DAT Recording problems
If the tapes you are using are "tight" it may be causing both the drop out and rew problems. Always a good idea when you buy fresh recording media to ff then threw it through to ensure that the tape is layered flat. they can tighten up in transit sometimes in shipping from manufacture. The unit will need some service work done also. A head clean could also help with the drop out. Use a Chamois tipped head cleaning tool to do thisusing iso alchol only AND A VERY GENTLE APPROACH. The drum heads themselves are very small and VERY FRAGILE!! Easily broken if you do not clean the correctly. Take it to a vcr/video camera tech for a clean and service of the tape path.
Posted on Jan 29, 2008
Grubhead
  • 4678 Answers
SOURCE: The tape recorder records well but does not run at standard speed
You don't say if it has developed this fault or if you have recently purchased it.
However the likely causes are that an electrical fault is causing a reduced voltage to the motor. Or if you have just got the machine somebody has adjusted the speed of the machine.
Some decks have one motor for both decks. On the base of the motor might be a slot. Inside will be a 'pot' that will adjust the speed. You will need a small screwdriver flat head type, to adjust, the playback speed.
Sometimes the speed adjust pot will be on the PC board. If your lucky the board will be marked! If not follow the leads of the motor to the board.
Sometimes the person who repaired the deck fits the wrong motor! I had one where they had fitted a 9 volt instead of a 12 volt motor. The motor at top speed could still not get up to what it needed to be!
Posted on Apr 07, 2009
SOURCE: play back on Sanyo mr-929 reel-to-reel tape recorder is backwards
I also have an MR-929. The information that you need is in the 'Stereophonic 4 track stereo''. As stereo is only two tracks, there is another 2 tracks in addition to the one you are listening to. Wind the entire reel to the empty spool, and then play that. As you have to physically turn the reel over to do so, you should then hear the other tracks (or track, if recorded in mono).
I use my 929 to play my parents recording of my family from the late 60s, which were recorded on a valve (tube) Ferguson machine, which had a green "magic eye" level indicator, which as a child I found fascinating!
Howie
Posted on Apr 15, 2009
Grubhead
  • 4678 Answers
SOURCE: My AKAI GX 636 records but can't hear anything on playback
Trace the wires from the head to the amp section. Put your finger on where they join (during playback) and see if you can get a buzz. If you can't on either channel, look for something that might be common to both channels. Either a switch, or a pre-amp IC, as being the cause of the fault.
Posted on Aug 06, 2009
How can I use a hand held stereo microphone to record via a Denon F101 tape deck
You really need to include all brand and model number info for this question.
Feb 03, 2015 | Denon Audio Players & Recorders
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
Playback options
If I were you I would get that side repaired for the following reasons 1) the wear on the record head is the same on the B whether you record or play 2) the gap is a compromise if it is a record/play head and for play back only the quality is better albeit only seen on instruments . 3) Cassette machines will be very dear and scarce as the factories appeared to have stopped making them. If you have the quantity as I have then if your record side's head is more of value as you cannot record on the head 4) Is your recording side a "3 head " unit giving you "off the tape" recording capability.5) You loose the ability to do trick recording by adding voice with music
This is the reasons for the time being If it is the unit in your pic then it was a very expensive unit
May 25, 2013 | Denon Audio Players & Recorders
Was given an Ampex AG-440 tape deck that stopped recording after sitting for about six months. Any ideas? (I lost the Manual) Everything else works fine. When put into record mode all lights are lit...
try cleaning the record head, Most people only clean the play back heads on tape players, the record head is just off to one side of the main playback heads , you can use a Qtip and rubbing alcohol to do the cleaning
May 21, 2011 | Audio Players & Recorders
Hi, My TASCAM DA-20 mkII DAT recorder is holding onto a tape. It will play the tape and there are no error messages, but the tape will not eject. How do I get the tape out without breaking the DAT...
A Technician usually has to get a tape out of a machine when this happens. In radio when I was Chief Engineer for several stations in Chicago I would send my defective decks to Russ at New Jersey Factory Service in Emerson NJ. He knows how to fix these units.
New Jersey Factory Service, Inc.
16 Chestnut Avenue Suite 103 B
Emerson,New Jersey 07630
201-967-0060
Fax 201-967-0062
Mon- Thurs 8-4 Closed Fri Sat by appt.
Dec 31, 2010 | Tascam Audio Players & Recorders
How do I dub casette to casette? I lost the manual.
There should be a DUB button. After you push the DUB button, you will have another button that will allow you to select Dub form 1-2 or 2-1. If not there will only be one deck that will play while the other records and plays. Put the tape to be coppied in the play deck and the blank tape in the record deck push record and it should work.
Dec 11, 2009 | Denon DRW-585 Single Cassette Deck
Cannot get dual cassette deck to record, denon DRW-660
check the drive belts inside the unit could be broken or slipping. farr64
Apr 29, 2009 | Audio Players & Recorders
Denon DRM 740 tape does not play
Just bought a unit from a thrift store. Found same problem; FF & RW OK, but play engages then stops. Also noticed buzzing noise when power turned on. Opened unit, found broken capstan drive belt. FF & RW driven from different motor. Buzz was drive motor running freely with no load - when power is on, capstan is driven all the time for fast play/record start. Replaced with rubber band, and it works --- now looking for replacement belt.
Apr 12, 2007 | Denon DRM-740 Single Dual Cassette Deck
441 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
