Question about Whirlpool Duet GHW9150P Front Load Washer
Spin cycle very loud,
Inner drum seems slightly loose .rub ,wear marks,onfront outer basket.spin cycle very loud.bang,clang......
  • 640 Answers
Spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
Posted on Feb 07, 2009
GE adora front load makes loud rattling sound in spin cycle. nothing in drum. sounds like a ball bearing
its the inner baskets bearings behind this basket as water gets past the rear seal into these bearings and ruins them,you need to dismantle the entire unit to remove the inner basket from the outer tub to replace these bearings
Oct 27, 2012 | GE WSXH208A Front Load Washer
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Drum seems off balance....
You likely have a corroded/broken spinner assembly on the back of the inner tub. If your washer is out of warranty it is usually cost-prohibitive to repair. We usually quote about $350-$400 parts and labor for it. If you can wiggle the inner basket relative to the outer, that confirms a broken spinner.
Apr 20, 2010 | Frigidaire GLTF1670A Front Load Washer
Washing machine makes a loud banging noise during cycle and when I check it the machine has changed position (unit is turned slightly sideways) How to correct
Hi
Does this happen every time???
If YES... then the machine is not balanced on the floor well.... the 4 stands on which the machine rests have adjustable screws... You will need to fasten or loosen the nuts that will adjust the height of the legs on which the machine rests.... all the 4 legs need to be firmly on the floor .... If one is too high then the machine rocks on its side...
If NO.. only sometimes...
You are overloading the machine with heavy clothes... distribute your wash clothes by weight...
Regards
Berry
Feb 04, 2010 | Washing Machines
Made a loud noise and drum stopped moving
the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
May 03, 2009 | Hotpoint WMA40 Front Load Washer
Not spinning properly
You will need to replace the inner basket and front outer tub assembly. Likely, the spider on the inner basket (drum bracket) has broken which is causing it to be loose and rubbing on the inside of the outer tub. This can be verified by checking for excessive play of the inner basket (hold the front of the inner basket and check for play by moving it up and down).
It's not a cheap repair unfortunately. Be sure to always use a small amount (2 tablespoons for a full load) of HE (high efficiency) detergent to prevent future build up which could cause corrosion of the tub spider.
Feb 01, 2009 | Whirlpool GHW9100L Front Load Washer
Front loader making loud noise with spin cycle
It may be something that was in the wash and fell thru the holes in the inner drum. Check all the plastic agitators and make sure they are all secure and an attach bolt has not backed out of one and rubbing the outer tub. It will wear a hole in it fast if it is.
Usually when the bearings go bad, it gets very loud on the spin cycle, like a loud roar and sometimes clothes will have rust or grease stains on them.
I just replaced my tub bearings on my Frigidare and spent about $60. They are all pretty much the same. On mine they only list the complete rear outer tub assembly with bearings, but you can knock the old bearings and seal out and match them up at a bearing supply house or you can buy online. Online seems much cheaper. If you buy bearings, make sure you get ones with a -2rs on the end of the part number. ex. 6308-2rs. They are sealed and hold up much better in water environment.
I would give it a try, the junk man doesn't care if it comes in pieces or one big piece.
There are a couple online articles that can probably help you. Do a google search for 'washer rear tub bearings"
Jan 29, 2009 | GE WPXH214A Front Load Washer
Loud spin cycle with SAMSUNG WD J1255 loose bolt???
How old is this machine? Almost all the time this noise its the main bearing. You have a inner and outer drum, the outer drum is suspended on shocks and the inner drum which is only supported by the spindle going thru the bearing on the rear of the outer drum. I have seen many of these wear out. Also I have seen the main bolt on the drum pulley shear off.
Oct 22, 2008 | Washing Machines
Noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
Feb 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,037 people viewed this question
Dan Webster
Dan Webster
Sal De
