Question about Neff B1428 Nostalgic Single circotherm Oven
How to replacement hinges on a neff 1438
I have the replacement parts, I have unscrewed all obvious screws but still can't seem to dislodge the back panel ready for installation of the new hinges?
  • Neff Master
  • 3,463 Answers
You wiil probably get all the info you need if you type in your browser bar the address below
Make sure you get it right
Or you can type in your browser bar youtube.com, and in the search box, type in fitting oven door hinge.
http://www.youtube.com/results?search_type=&search_query=fitting
Please leave a fixya rating for my solution.
thanks.
Posted on Feb 08, 2009
Hinge receivers for u1661
I had this EXACT same problem and the hinge receivers WERE THE PROBLEM!
Easy fix. All you need is a Phillips head screw driver (cross head that is) and about 30 minutes.
1. First off remove the oven door.
2. pull out over so that you can easily access the rear
3. Disconnect oven from the electricity (make sure the mains power is OFF before you do this)
4. Remove the back panel by unscrewing all the screws
5. turn oven over onto its side and remove the bottom panel (more screws)
6. You can now get to the receiver - its held inplace by 1 screw just inside the oven door above the receiver (and maybe another 1 on the side, but i cant remember).
7. Undo screw(s),slide out receiver, replace and put back together in the reverse order.
Honestly, it is very easy (I did it with no help, idea and 1 have 10 sausages for fingers).
Sep 07, 2012 | Neff U1661 Double circotherm super...
Lamp Holder
It has to be reinforced
Jul 25, 2012 | Neff Ovens
How do I sepate the inside from the outside of a neff oven Bl641 door
Remove the oven door by flipping the hinge catches into their alternative position and lift the door out of the hinge slots (note it is somewhat heavy). Lie the door, outside face down and press down on the glass with both hands until it slides off the mounting pins at the base of the door body. Replacement is an exact reversal.
Feb 18, 2012 | Neff B1641 Single circotherm super...
The door to my Neff oven is not closing so heat is escaping from the top - please help
You need new hinges use linkhttp://www.neff-eshop.com/eshop/neff/gb/prodlg.htm?Maktx=b1644&eshoptype=A
click on the spares listing for your model (you will need the full Enr from the oven rating plate) and order the hinges (always replace as a pair). Hinges are on page 3 parts list in position 0319 and 0320 (these are not the parts numbers, you need to highlight these positions numbers on the breakdown from your specific model to get the correct part number (six digit part number) You may find that although the position number are different for the left and right the actual part numbers are the same. You can add the items to the basket and order directly from Neff.Hope this helps
Sep 02, 2011 | Neff B1644 Electric Single Oven
I have a Neff U1420 double oven and the hinges on the main oven do not close the door fully. I have read that it is possible to correct this problem by putting washers under the screw of the hinges but I...
Hi.
If the door does not close properly then the fault is a faliure in the door hinge springs. Sorry but using washers will not cure the problem..
The only way is to replace the two door hinges. You may NOT need to replace the hinge backs.
If you would like to email me the full model number (numbers after U1420) then i can source the part numbers for you.
regards
Aardvark Repairs
aardvark.repairs.btinternet.com
Nov 17, 2009 | Ovens
Neff FD7903 Oven Drop down front door no longer fully closes & is getting worse - are the hinges adjustable?
I'm afraid not.
"Drooping" doors are very common on Neff ovens - I've had to replace a couple of sets - and seem very sensitive to things being placed on the door whilst in the open position, e.g. roasting tins whilst basting a bird/joint.
Replacement hinges are available - just Google your model number and the sponsored results will include several companies who can supply them - not cheap, but much less than a replacement oven.
Nov 15, 2009 | Ovens
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
I need to take off a fan from a neff oven,how do i remove the fan?
Remove inner rear panel of oven.
Unscrew nut clockwise that secures the fan blade to the motor, undo screws that secure the motor. and replace same. You may have to remove main back panel to access fan motor screws and terminals.
please leave a fixya rating for my solution.
Thanks.
Jan 25, 2009 | Neff U1421 Double circotherm Electric Oven
Neff Oven Door Removed Incorrectly
you need to lock the hinges to get the door back.
it needs some strength
lay door flat on floor
force hinge against the spring until right back and put the locking arm over. i use my feet for this!
Nov 29, 2008 | Neff B1421 Electric Single Oven
Neff oven u1420
Hinges not fitted properly,or possibly wrong hinges
Nov 03, 2008 | Neff U1661 Double circotherm super...
Neff B1428 Nostalgic Single circotherm Oven Logo
158 people viewed this question
Top Neff Ovens Experts
bosch5
paulcarew
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
