Question about Panasonic KX-TG5632 Phone
Panasonic handset, KX-TG5632 buttons won't work
The handset from our base unit is fully charged and the display works fine. But, none of the buttons work, so it can't be used to make a call. If it is on the base and a call comes in, we can pick it up to answer okay, but have to hang it up again to disconnect. Any ideas? Thanks.
  • tomcar80 Feb 08, 2009
    I have the same problem. Display on handset works but buttons do not.
After trying all possible solutions (unplugging, replugging unit; switching batteries and, my idea of smacking the handset with my hand), I bought a new phone. :-)
Posted on Feb 08, 2009
Have a Panasonic KX-TG1061C with 3 handsets. Handsets work perfectly. None of corded base unit buttons work.
to turn off night mode http://www.manualslib.com/manual/793900/Panasonic-Kx-Tg1061c.html?page=25
do not think night mode would cause your problem.
check dialing mode #120
TONE ?
When you unplugged the base unit did you pull out the ac adapter for about 30 seconds to reset the base unit ?
Jan 04, 2015 | Panasonic Lands Phones
Phone says no link to base reconnect to mainbase ac addapter
The instructions worked after the additional KX-TGA402N handset was fully charged and I kept pressing the menu/ok button of the additional handset to advance from initial settings to the handset registration mode.
How do register an optional accessory handset to my existing main base...
Feb 08, 2013 | Panasonic KX-TGA402N 3 Pack KX TGA402N 3...
Hi, suddenly I loss my connection of telephone KX-TG 5632to the base from the handy , I need the way to register it from the base, thanks for your cooperation
1 Handset: {MENU} i {0}{0} 2 Base unit: Press and hold {LOCATOR/ INTERCOM} until the CHARGE indicator flashes. L After the CHARGE indicator starts flashing, the rest of the procedure must be completed within 1 minute. 3 Handset: Press {OK}, then wait until the handset beeps.
Jun 12, 2011 | Panasonic KX-TG5632 Phone
I purchased replacement handsets for my older panasonic cordless phone and would like to know how to reprogram them. My base unit has an answering machine but not a locater button. Thanks, Ann-Marie...
Follow these steps to register new handset.
1. On your Handset: Press Menu -> [0] [0] (menu then zero zero)
2. On your Base:
- Press and hold [Locator/Intercom] until the CHARGE indicator flashes.
The following must be completed within a minute.
3. On your Handset:
- Press [OK], then wait until the handset beeps.
That's it.
Hope this helps.
May 06, 2011 | Panasonic KX-TG5632 Phone
Cannot get a dial tone or hear caller on one of the handsets, but can hear it ring and the caller can hear me. The other handset is fine.
try unpluggjng base unit from power supply and then let handset unit reset to relocate the base unit.
Feb 11, 2010 | Panasonic KX-TG5632 Phone
I have the below-mentioned problem with my Panasonic Cordless model KX-TG3531BX No link to base. Move closer to base, try again. Please contact me on 9879590311 or email me at ritu_vpatel@yahoo.com
place all handsets in the base unit for about 1 minute each. This links the handsets to the base. Sometimes the handsets lose their link to the base unit. If this doesn't work try to call Panasonic tech support for further information, the phones could be defective as well.
Aug 30, 2009 | Panasonic KX-TG5632 Phone
Top row of buttons don't work
Well, I found the solution. I traded batteries from one the working handset to the non-working one, and the problem was corrected. Thus I need a new battery.
Jan 15, 2009 | Panasonic KX-TG5632 Phone
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
minute.
3 Handset:
Press {OK}, then wait until a beep
sounds.
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
Adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
http://www.panaxonic.com/RegisterYourHandset.
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Oct 27, 2008 | Panasonic KX-TG5422M Cordless Phone
Installing a new base unit
You will need to press the page/locator button and hold it down until the charge light flashes. Once you do this, go to the handset and push OK. It should register as handset 4. Hope that helps. CG
May 17, 2008 | Panasonic KX-TG5632 Phone
Panasonic KX-TG5632 Phone Logo
300 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
