Question about Whirlpool LER5636P Electric Dryer
The dryer will not turn on and is fairly new
The only sensor that does not have continuity is the one that requres four wires would this be the problem?
  • 979 Answers
Yes it could be. However, check under the top and locate the thermal switch located next or near the drum. It is the thermal overload switch. Bypass it and see if it comes on. If it does, it only costs about 15 dollars. You may want to check wiring in the back of the dryer and see that everything is tight. If it is fairly new, then would it be under warranty?
Posted on Feb 07, 2009
My performa dryer is leaving burn marks on clothes. The marks (pattern) is from the covered opening on the back of the dryer. Any idea what could cause this or how to fix it?
You have a bad sensor that is not sensing when to turn the heat off, it just heats full on the whole time, you can check sensor with the power off and a meter on continuity, the sensors are located on the heating tube that the coils are inside. the sensors should have shut your dryer down but maybe your sensor is stuck closed with would make it work and not tell the dryer when to turn off heat, or your wires are touching eachother where the sensor is located, so you accidently or defectively the wires are connected and not running through the sensor
check the wires and replace the sensors. there are a few sensors on my dryer, they are small devices that sit on the exhaust tube and the heating coil can, simply use your probes to check for continuity on the two lead wires to the sensor, and make sure the wires are seperated and not touching eachother where they plug in to the sensor, one may have gotten bent over and now you have a jumper. same as if you pull the wires off the sensor and touch them together. I have a bad sensor and touched my wires together and now my dryer works, but is dangerous, and needs monitored until you get a new sensor in place and hook up correctly
Jan 01, 2013 | Dryers
Going from thre prong to four prong what goes
Under the new Codes2_bing.gif...all dryers (and stoves/ovens) must now be 4 wire....having a seperate neutral and ground wire in NEW construction. In decades past, the neutral was allowed to serve as both - the neutral and ground - typically by means of a solid metal strap or wire strap that bonded that connection to the metal frame of the dryer. This sounds as if it is the case in your existing dryer...which was typical.
But...the old arrangement wasn't always reliable...and a seperate dedicated ground provides a greater safety path in the event of a fault inside the dryer (lowering the chance the user may get a shock when touching the frame of the dryer).
To modify your existing 3 prong dryer over to 4....you'll need to remove the 3 wire - disconnect the ground strap (or wire) that bonds the neutral to the frame of the dryer...and install your 4 wire so that you'll have (from left to right) one hot, one neutral, one hot connection...and connect the ground directly to he frame of the dryer (there is usually a green screw near the dryer connection block for this ground)
For more on this - with an illustration, see:
http://www.american-appliance.com/service_pages/electric_dryer_cord.htm
When done properly, you can test for correct wiring and connection with an ohm-meter (continuity check)...by checking for continuity from the ground prong on the plug to the frame of the dryer...you should see continuity. Then check for continuity from the neutral prong on the plug to the frame...you should NOT see continuity....nor should you see any continuity between the neutral connection at the wiring block to the metal frame.
The whole purpose of the Code change to the 4 wire is to seperate the two.
Hope this helps,....if you need more details, please follow-up.
May 02, 2010 | Speed Queen AES28AWF Electric Dryer
My dryer turns on but throughs out cold air
In most cases, a failure to heat is caused by a blown thermal fuse or high limit thermostat. Usually it is the fuse, but the fuse may be blown due to a defective thermostat. To find the location on yourspecific machine (and purchase the parts) try www.appliancepartspros.com To test the fuse, WITH THE MACHINEUNPLUGGED, put an ohmmeter or continuity tester across the fuse with it's wires unhooked. It should have continuity. If it is open, replace it. If the thermal fuse blows, it is fairly common to find the dryer vent partially blocked as well. Make sure it is clear. Thermal fuses are fairly cheap, but you don't want to have to replace it every other week.
Jan 03, 2010 | Washing Machines
Whirlpool TED5780JQ0
Hello there:
here are some helpfull ideas for you
  1. Examine the coils. If your dryer isn't producing any heat
  2. the terminal bracket that secures it may need to be replaced. Also check to see if the thermal fuse is blown, if both volt circuits are on and the thermostats are functional.
  3. Step Check the vent. If a load takes longer than one hour to dry clear the vent duct of any obstructions. Determine if the heating element is partially burned out .
  4. would get a new element anyway ok?
  5. I hope that this is very helpful for you
  6. best regards michael
Nov 18, 2009 | Whirlpool ET8CHEXSQ Dryer
The plugin on my dryer has the terminals going in a slant. the outlet in my house are straight. what should i do
You can purchase a dryer main power cord that fits the type outlet you have. Some cords are three wire and some are four wire. Here is some information on changing from a three wire to a four wire configuration or vice versa.These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the right/bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helped and best wishes.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a new 4 prong plug to replace a old 3 prong on dryer
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
Convert three pin plug to four pin
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Sep 06, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Jul 23, 2009 | Dryers
I had to change the three prong wire and replace with four prong
If you are converting from 3 to 4 prong service, that is fairly simple and should be done as follows:
If you purchased a pre-terminated cord that has a molded plug on one end and four wires with lugs on the other then that is what you have to attach to your dryer. Start by pulling the dryer out far enough to gain easy access to the back panel. Depending on the model, you will need to find the place where the cord feeds through the back and feed the new wire through that opening ( there should be some kind of cable clamp that guides and clamps that cable through the back panel). Once fed through, look for the terminal block on the back of your dryer. You will have at least 3 terminals that should be color coded red, black white or green) Start by installing the red to red, black to black and white to white ( or green) and then take the green wire end of the cord and look for a ground stud on the back of the dryer. There should be a terminal or sheet metal screw that you can attach that green wire to the dryer. The green wire is a safety ground that bonds the dryer to earth ground and provides a path to ground through the dryer chassis should you develop a short top ground. That path is provided to protect you so that you don't become the path from power to ground. Hope that helps...
Just remember to do all this wiring with the cord unplugged from the power source...
Regards,
Rick
Nov 23, 2008 | Maytag Dryers
Whirlpool LER5636P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
