When trying to print any document using Lexmark X4580, I'm unable to print due to this message - 'Unsupported Cartridge', indicating that the installed cartridges are incompatible with the printer? I'm confused - the cartridges installed are BOTH Lexmark, that is 2 colour and 3 black. Any suggestion as to the problem?
  • 11 more comments
  • rob_mck Feb 07, 2009
    Just tried cleaning contacts of print cartridge and printer but still have problem. Any other ideas?
    Tried replacing cartridges and turning printer off - still no good. Any more?
    Tried all suggestions to no avail, message on printer settings diplay is right cartridge incorrect and left cartridge incorrect. Both are official Lexmark so how can this be ?!
    No physical connections between computer and printer, it's wireless. However, have done just about everything being suggested (including chacking that the 'tape' in removed from cartridge, it is) and still have problem. Now what?
    Yes correct cartridges. Any more?
    No return and ready keys, and no diagnostics mode so no self test. Any more ideas
    thanks hari86, done all of that - no good
    Thanks HPC - no, done all that and still got problem
    Hi DIPU007............tried all that - nothing.
    Seems I'm out of options unless someone can tell me otherwise?
    thanks askmee, no go. tried everything now so what else?
    Yep Amardeep46, I'm inclined to agree.
    Thanks everyone - another for the scrapheap!
    blueextc3221, thanks for pointing out something that I told you in initial post - do you guys read anything?
    I've obviously wasted my time - thanks a bunch !!!
    Thanks for the 'help'!
    Unfortunately you don't seem to be able to 'FixYa'
  • 19,396 Answers
when you get "unsupported cartridge" and you are using original cartridges, or cartridges you know they are good, that means that the problem is a dirty contact inside the ink carriage.
Clean the metal plate contacts inside the ink carriage with cotton and isopropyl alcohol, that usually fix the problem.
Posted on Feb 08, 2009
  • 4,806 Answers
Hi there
Remove power from the printer, remove the cartridges, and clean the contacts on the cartridge rack with cotton wool or a cue-tip, make sure all the ink residue is cleared before putting the cartridges back in, if you have to reinstall the printers software and see if you can print a test page.
If this does not work the printer has malfunctioned.
Good luck and thanks for using Fixya!!
Posted on Feb 07, 2009
    Genius:
  • 2,920 Answers
I would go buy a new printer they are under 40.00 and you know brand new will work for you....i bought one 2 weeks ago and have been using it almost every day and it works perfect
  • 728 Answers
Even though the cartridge says that it is from Lexmark, it still has different models that it could be for a whole bunch of different Lexmark models. Check to make sure the model numbers match. It should tell you which models the cartridge fits on the side of the cartridge box.
  • 15,935 Answers
Was the printer purchased @ Circuit City?
If so, they have proprietary rights to the cartridges and must be replaced with THEIR items.
Hurry to the closest store near you and stock up!! As they are filing for bankruptcy. You can get them for 30-40% off right now!!
You NEED the number 2 and 3 cartridge.
See THIS LINK for proof.
Thank you for using FixYa - a FixYa rating is appreciated.
  • 4 more comments
  • blueextc3221
    blueextc3221 Feb 07, 2009
    Circuit City in US and Dixon Store Group in Europe.
    Direct from LexMark website -
    What you will see
    When a cartridge is inserted, an Unsupported Cartridge error message is displayed on the printer operator panel.
    Affected printers
    This issue affects printers sold exclusively in the Dixon Store Group (DSG) in Europe and in Circuit City in the U.S. NOTE: The cartridges for these printers are sold exclusively in these stores or on their websites.
    Explanation
    The printers listed in the table below are compatible with a #2 cartridge (in single cartridge printers) or a combination of #2 and #3 cartridges (in two-cartridge printers). They do not support the standard color 28A 35, and Mono 29A 34 ink cartridges. If the standard color 28A 35 or Mono 29A 34 ink cartridges are used in these printers, they will fail to print and the printer will post an Unsupported Cartridge error message.
    Solution
    Lexmark recommends using either a #2 cartridge for single-cartridge printers or a combination of #2 and #3 cartridges in two-cartridge printers.
    Cartridge compatibility chart
    NOTE: These printers are sold exclusively in the Dixon Store Group (DSG) in Europe and in Circuit City in the U.S. The cartridges for these printers are sold exclusively in these stores or on their websites.
  • blueextc3221
    Exclusivity is your problem!!
    I would suggest replacing the printer - as CC is now going out of business... and replacements will be hard to come by.
    There is no workable fix to your priter besides using the #2 and #3 as I described above.
    Thanks for using FixYa - a FixYa rating is appreciated!!
  • blueextc3221
    Your initial question -
    So the obvious question then remains.... have you tried the Lexmark Cartridge #28 and #29??
    If you are replacing the cartridge with an exact replacement of what was in the printer, Im afraid the printer's circutry has failed.
    The end result is still the same - there is no end-user fix that can be done. It must be taken in for servicing.
    Try you previous cartridges again and see if the same message appears.
    Unfortunately FiXya removes all "comments" from your post when we choose the "reply" button. So if some comments I have made are already suggested, it is because I cannot see them until I submit this suggestion.
  • blueextc3221
    even if your question is not answered correctly - please be sure to rate ALL experts suggestions, as even ones posted with no relevance may recieve credit for the answer given if left unrated.
    Thank you.
  • blueextc3221
    if the original cartridges work, look into getting them refilled.
  • blueextc3221
    you've wasted YOUR time?
  • 129 Answers
I can see from the above posts that you have tried all possible solutions available. But it seems nothing worked. So I believe you may need to get a technician have a look at the printer. Without having a look at the system and checking various options, I dont think it will be possible for us to identify the problems.
    Master:
  • 416 Answers
One cartridge or cartridge/printer chip might be defective it is common
Do you have any old ones left. If yes try to put them one by one, first replace black and try to print, if no error black cartridge defective and so on. It might also happened if you use non-lexmark cartrides in this case you will need to push reset button to clear the message on the screen
Recommmended cartriges are here
http://www.lexmark.com/lexmark/product/home/549/0,6970,204816596_653399443_1285561893_en,00.html?tabId=7
Also there is phone for LEXMARK tech support
1-800-332-4120
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569481_0_en,00.html
AS A VERY LAST SOLUTION YOU CAN PUT TAPE OVER PRINTER SENSOR BUT IF FOR SURE VOID THE WARRANTY AND NOT RECOMMENDED
Good Luck
    President:
  • 2,110 Answers
Try tricking it, take out the cartridge, turn it off then back on without the cartridge, it's going to ask for it put it it and close it.
Also, try cleaning the contacts ( shiny copper on the toner.
  • Sibananda Jena
    Sibananda Jena Feb 07, 2009
    the cartridge has a chip, change it and see.
  • 258 Answers
Could be a p[roblem with the installed drivers for the printer
Go into printers and faxes and
try downloading and installing the latest drivers from here
http://www.siliconguide.com/drivers/device/193/
Also a good idea to make sure all windows updates have been downloaded and installed
Open Internet Explorer --> Tools Windows updates
If you cannot see tools tap the <ALT> key on the keyboard
thanks HPC
    Sergeant:
    Champion:
  • 289 Answers
Hi..the solution for this problem is the following.
there r three steps.one is replace the catridge again
and try a print,other one is clean the catridge and its
printing device,third one is re-install the printer software
again.
check it out..
thank u..
  • Hariharanath V Feb 09, 2009
    hi..the best solution to this problem is by
    giving the printer to the service.
    try this out..
    thanks..
  • 217 Answers
Please hceck for the compatible catridges on the following link
http://www.lexmarkstore.com/store/lexmark/DisplayProductFinderPage
please make sure you select the correct model of your printer and see if you have bought the same catridges
  • 916 Answers
If you are sure you got the right cartridges please remove them and make sure the tape is not on the electrical contacts. Once done reinsert them and make sure they are in place correctly. if this does not solve the problem unplug all the connections to the printer and then wait 60 seconds and plug it back in and see if the problem is still there. Please post the results once you have done these steps.
    President:
  • 1,990 Answers
Welcome to Fixya! Tryremoving the Cartridges and Cleaning them with Q-Tips and Alcohol and clean the Printer Cart. Connectors also. Then go into the Settings and click on the Options for new Cart. and Check-These are New- If this does not work then you may need new Cartridges. Please Rate My Response! Thanks!
  • Travis Humphries
    Travis Humphries Feb 07, 2009
    Try Uninstalling and Reinstalling your Printers Software.
  • 679 Answers
Take off cartridge and clear all the parts of your printer.
also clean the cartridge head.
and let me know for further assistance.
Thanks
  • 1 more comment
  • rockfixya
    rockfixya Feb 07, 2009
    Take out the cartridge, turn the printer off then back on without the cartridge, it's going to ask for it put it it and close it.
    Also, try cleaning the contacts on cartridge head.
    Thanks for using FixYa.
  • rockfixya
  • rockfixya
    The cartridge usually has a chip attached to it - which the printer reads to see if the cartridge is genuine or not. The chip contains information such as the number of pages printed, the serial number and how much ink is remaining.
    If the printer detects in incorrect chip or that the chip is not present then you will get the "Unsupported Cartridge" message.
    There are ways of getting around this problem but they usually involve modifying the printer is some way. Sometimes its as simple as putting tape over the sensor and other times more drastic measures are required. It will depend upon what printer model you are using. Any modifications you make will likely invalidate any warranty you may have.
    The other point to make about refills is that they are cheap because they are made of cheap materials. You will probably reduce the lifetime of your printer if you do use refills. Poor quality ink will block the jets/heads and cause your printer to produce poor quality prints.
    You need to weigh up the pro's and con's as to whether you want to risk the cost of having to buy a new printer against the cost you will save on refill
    Brigadier General:
  • 3,614 Answers
replace again the cartridge.
unplug the printer for a while, and let see.
  • micromaster
    micromaster Feb 07, 2009
    • do uninstalling of the printer driver on the pc.
    • power off the printer
    • remove all connection.
    • restart your PC and
    • put back again the printer connections to the pc, let your computer detect your installed printer.
    Master:
  • 848 Answers
Hi
remove the cartridge and clean the contacts ......insert it once again ...thats it it will work.....
  • gopinath pasupathy Feb 07, 2009
    Reset your printer
    You will firstly need to switch off your printer. Then simultaneously press the RETURN and READY keys while switching the printer on. This will take you to the Diagnostics Mode. The display unit will show the message 'Performing self test'. Choose 'Maintenance count'. Reset the count to make it zero. Then select the RETURN key and go back Diagnostics Mode. Then you can reset the printer to go back to the normal mode.
    Its time for you to upgrade print head...you are facing hardware problem.....print head is not working properly.....
Unsupported ink cartridge message
Try uninstalling all of the software and reinstalling a fresh copy and see if it still does it. If so, I would contact the folks at Lexmark.
Jul 25, 2017 | Lexmark X3350 All-In-One InkJet Printer
Brand new lexmark printer, toner and cartridges installed, but get error 32 unsupported black cartridge error -tried updating drivers on lexmark site -tried taking cartridge out and reinstaling...
You could find the root cause by performing different steps. One of the easiest methods is that you need to make sure that the plastic protective tape which is usually used on the new black cartridge is off. Usually the user makes this mistake. This mistake might occurs due to absent-mindedness. The reason could also be some distractions which happen while loading the new black ink cartridge.
Nov 17, 2010 | Lexmark C546DTN COLOR LASER PRINTER ...
I have a lexmark 2580, I keep getting 'unsupported cartridge' message, and one of the lights on the printer is constantly blinking. I have brand new lexmark cartidges installed.
Problem Unsupported Cartridge; Error: "Unsupported cartridge"; Incompatible cartridge error; Incompatible cartridge in the printer; Cartridge not recognized Solution What you will see
Affected printers
Explanation
Solution
Item Printer #2 Color Cartridge #3 Mono Cartridge #31 Photo Cartridge 1 Lexmark Z738 Yes ... ... 2 Lexmark Z1380 Yes Yes Yes 3 Lexmark Z1480 Yes Yes ... 4 Lexmark X2480 Yes ... ... 5 Lexmark X2580 Yes Yes Yes 6 Lexmark X3480 Yes ... ... 7 Lexmark X3580 Yes Yes Yes 8 Lexmark X4580 Yes Yes Yes
Nov 07, 2010 | Office Equipment & Supplies
Unable to uninstall Lexmark x4580 printer
use the software named "Revo Uninstaller"
it will completely uninstall the printer and its driver.
Dec 22, 2009 | Lexmark X2550 All-In-One Printer
I have a Lexmark x5470 & I get an error unsupported cartridge
Ink cartriges have chips in them, if the printer does so many prints without getting the "I've had a new Original Cart fitted" it will stop untill,you give it one, regardless if there ink or not
Im afraid it doesn't care that you only need to use the colour cartridge, it is designed to cost you money and make money for lexmark not refillers.
Welcome to our modern world, manufactures make the ink hard to recycle by incorperation of expensive chips that makes refillers, unable to make a easy dollar, because if that want to make cartridges that work they must also fit the expensive chip.
All empty cartridges have a little ink left in them because getting air in ink lines is not a thing we want.
Nov 07, 2009 | Lexmark X4270 All-In-One InkJet Printer
Unsupported cartridge message
I was having this problem with a Z730. The printer was finally working again after removing and inserting ink cartridge like 40-50 times. No pun intended. After installing cartridge try turning off printer and then back on.
Aug 19, 2008 | Lexmark X2470 All-In-One InkJet Printer
Unsupported cartridges on lexmark x4580
As a temp solution I put some saliva on the pcb on the cartridge. Strange I know but it worked for me !
Jul 20, 2008 | Office Equipment & Supplies
Lexmart x4580 all in one printer
Hi I have a Lexmark x4580 all in one WI FI dos not connect to my netgear it finds it and I put in all the right passwords just will not connect
Dec 04, 2007 | Lexmark X8350 All-In-One InkJet Printer
Right cartridge incorrect
This solution (RESET the BRICK - solution 1 above) worked for me!
I had a brand new out of the box Lexmark X4580 and after one or two prints I was suddenly getting a "Left Cartridge Incorrect" error showing on the Printer Control Panel and the printer would now all me to print anything.
After about an hour of trying this and that (cartridges in, out and shalen all about!) ; no avail, I tried this and hey presto, it worked.
When I removed the "Brick" power supply I left it until the Green LED had faded right out though, I dont know if that was significant or not. Fingers crossed all is sorted now!
Mar 14, 2007 | Lexmark X7170 All-In-One InkJet Printer
jasbo
jasbo
