Question about Dell 5650 Computer Speakers
My Dell 5650 Woofer isn't working.
I've had trouble with one set of speakers not working, after some connection issues think I have that right. The PC was jammed against the desk bending the jacks. Consequently pulling out the jacks things were misplaced. Ins to outs, etc. I still have nothing on my woofer output. I'm not sure if something else needs plugged into my sound card. I have a PC connector that is vacant there. I do have a problem with one set of speakers...the volume is loud as soon as it is turned on. In my settings the speaker volumes are set the same and at the 5.1 surround sound option.
  • banditbonnie Feb 07, 2009
    Since I downloaded the manual, I discovered the back doesn't look the same on the woofer. I must have gotten the wrong equipment number. I do want to thank you for the prompt response.
  • 217 Answers
Please download the manual for Dell 5650 and check the placemat details if anything is missing.
http://support.dell.com/support/edocs/acc/p62507/
And update me if that helped.
Posted on Feb 07, 2009
Altec Lansing ACS400 (Desk top stereo/Dolby Digital speaker & Sub, circa 1995) [right speaker] does not work; how can I fix it?
realistically, I would say they've had their time, and it would not be worth repairing. it could be more than just the speaker that blew, parts for desktop speaker systems are almost nonexistant unless you know you're way around jury-rigging electronics. Plus, there are quite a few new sets out there that would be superior to what the ACS400 puts out, for decent pricings.
I myself am a big advocate of the Logitech THX-certified product lines- they have excellent bass, crystal clear sound, and are great value for the money.
Mar 23, 2012 | Audio Players & Recorders
How conect one subwofeer 12
The sub woofer can be connected by bridging one side of the right channel to the other side of the left channel. Usually this will be marked on the speaker connection terminal and use will not have any trouble to locate. If not use the + ve of the right and the - ve of the left to connect to the sub woofer. turn it on and check . If you find the phase different- with less bass- reverse the connection and try. this will work fine. Good day
Aug 11, 2010 | DHD NTX-2004 Car Audio Amplifier
Having speakers to work on vizo desk top . all in on desktop!
You need to remove the unknows first. Try the speakers on another device. You could try a walkman, another computer or anything with an 1/8th" Stereo jack. Prove that the speakers work or get a pair of headphones to check out your PC. If you are using the green jack on the back try the headphone jack on the front. If the front works and the back doesn't check the sound card options / set up. Some have an icon by the time in the bottom right corner others will need to be found under the sound effects manager or the sounds and audio devices icon. I suspect if you get this far something has been turned off in the software.
May 11, 2010 | Sony VAIO VGC-RB34G PC Desktop
Go to control panel>hardware and sound>Sound...Then make sure the speakers are set as your default device.
hope this helps
Mar 19, 2010 | Sony VAIO VGC-RB34G PC Desktop
Install cd for monsoon
What makes you think you need special drivers for your Monsoon speakers? Do other speakers work properly when hooked up to your PC? Borrow a pair from somebody else if you don't have any other speakers you can try, and check. If they don't work either, Monsoon drivers are not your problem. I'm not saying nobody ever needs drivers for speakers to work with a computer, but normally, drivers for the speakers are not the issue if you're not getting sound through them.
The sound card driver and sound settings in BIOS, sound settings in Windows and for the sound card, and physical issues about the way the speakers are hooked up or whether the speakers themselves are functional are much more common sources of trouble than drivers for the speakers.
Start your troubleshooting process with this webpage:
http://www.computerhope.com/issues/ch000034.htm
If that one doesn't seem to address your issue, try websearching for other options with a phrase such as: troubleshoot no sound PC speakers.
May 31, 2009 | Audio Players & Recorders
No sound from one speaker
if you have used the same cable to plug it in a different port, then i would say it is not the cable. it's more of a port issue or it's just that the sound card does not send a signal to that channel anymore. try using your unit on other sound systems and see if you get the same result. or you can set your pc to run on 2 channel mode only to test if the two speakers (L front and L rear, in this example) can produce the sound on the left channel (you do the same for the right, obvioulsy). if that still exibits the same symptoms, then it is definitely a port issue.
hope that helps :)
Oct 09, 2008 | Logitech X-540 Computer Speakers
Sound only in 1 Speaker Instead of Two
not sure if this will help, go to your control panel and then to your sound and audio devices, on the volume tab check to see if both speakers are set to high on the speaker volume option
hope it helps
Jun 13, 2008 | Philips Dynamic Edge 4.1 PSC604 Sound Card
Center speaker hookup to a MARANTZ mdl 2238
Hi tliguyanadig
You can hook up the speaker "between" left and right outputs. Just connect the center speaker between left +ve and right +ve outputs respectively. It will give a spacial effect that some like and some dont:) Try it and see for yourself. Your marantz amp will handle the load OK. It is rated 38 watts into 8 ohms, but there is not alot of load presented by this sort of setup. Let me know what you think.
regards
Graeme
Apr 03, 2008 | Audio Players & Recorders
-mate JAM Pocket PC Problem
Try putting in earphones and check. Sometimes the contact inside the earphone jack jams against each other and then the phone thinks there are earphones plugged in thus bypassing the speaker.
Oct 27, 2007 | i-mate JAM Pocket PC
Hi
Looking at the manual http://www.alteclansing.com/downloads/EUR/VS2121%20manual.pdf page 3 of the pdf says Connect the lime green 3.5mm stereo cable (hardwired into the right satellite) to the lime green input labeled ?FRONT? on your sound card. So your right speaker should have a cable with a green end that plugs into your standard audio out jack If you have multiple outputs and don't know which you are set up for, then turn the speakers on and up, put a long song on, and plug that green wire into every jack on the PC! If you've got no other issues you'll hear something! Good Luck
Aug 28, 2007 | Altec Lansing VS2121 Computer Speakers
Dell 5650 Computer Speakers Logo
210 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
