Question about Kenmore 22422 Top Load Washer
Kenmore model #11092581200 doesn't always spin
The washer is capable of spinning, but "chooses" not to most of the time. I have to manually turn the dial to another "spin" option on a different cycle to get it to work. Now I am down to just one spin option left that works on the whole dial. I'm thinking soon that one won't work either...
  • fanoonan Feb 22, 2009
    kenmore washer, 70 series doesn't always spin. After noticing it wasn't spinning' I tried all other settings since my wife said it only spun on certain cycles. Initially, no luck. Sure enough, it began to spin in cycles, just minutes before, it didn't. I suspect some overloading has been going on. What to do?
  • 32 Answers
The timer needs to pause the motor after the water is drained from the tub to lock the spin cam in the transmission. The timer may be bad and not pausing the motor but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Kenmore Washing Machine Parts:
Posted on Feb 07, 2009
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
Mar 30, 2013 | Washing Machines
Washer doesn't spin in spin cycle
What is the model number of your unit?
Oct 31, 2012 | Kenmore Washing Machines
I have an kenmore elite =sm9711174. the spin cycle does not always start. i have to manually spin a couple times then it starts, but now does not spin fast. only slow. do i need a new belt?
this washer does not have a belt. The motor is a direct drive. it should give you a error code at time if it is unable to spin. some codes are F-51, F-dl, and UL. from the sounds of it the main board may need to be replaced part#W10189966.
Sep 02, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
When washer spins it makes a loud banging noise, washer is a front load kenmore
Thanks for choosing FixYa and welcome. Anytime loud noises are heard, it can almost always be traced back to the drive motor. That is what controls the spinning. Check that and the spin bearing. One of these two are probably your problem. Make sure the washer is level though. Check the suspension.
Apr 30, 2011 | Kenmore Washing Machines
No spin cycle
This is usually caused by the pressure switch. Here is a link with the other possible problems. To check the pressure switch follow the link to the video.
Jul 16, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series washer wont spin or drain at end of cycle
Apr 17, 2009 | Washing Machines
Kenmore model #11092581200 spin cycle doesn't always work
It appears your timer has failed in this instance.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 07, 2009 | Kenmore 22422 Top Load Washer
Spins slowly in stackable washer dryer
sounds like your spin brake is not releasing when the spin starts
Jan 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
102 people viewed this question
Sal De
 Brian Main
Brian Main
