Question about Hitachi 50CX29B 50" Rear Projection Television
No Volume from the set
The tv set was hooked to an external surround sound system. Once I removed the surround sound system, I have no volume on the set. I can't remember how I switch the volume back.
    Genius:
  • 2,920 Answers
You will need to go under the settings for your tv and find the volume control and reset it to internal dpeakers and take it off of external.
Posted on Feb 07, 2009
Just purchased a 52 inch flat plasma tv. Problem with the volume. When volume is fully extended, the volume is still low and definitely unsatisfactory. Would like to know if there is an adjustment that I...
The sound on the plasmas is not very high compare to other TVs like the rear projection and the CRTs types.
If you add an amplifier or surround sound to get better audio, if you notice in the stores most of these TV are hook up to suround systems.
Mar 15, 2008 | Audio Players & Recorders
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
I was wondering if there's a way to change audio out from variable to fixed cause I want the volume out only from my surround sound not from the tv I heard If I switch from variable to fixed the problem...
No variable audio out means that whatever the volume is at on the TV it will output that level from the TV. So if you have your surround sound on and if you change the volume on your TV it will also make your surround sound louder with out having to turn up that volume on your surround sound, but if you have your volume muted then so will the audio out. So if it is a fixed audio out then no matter what level you have the TV set to it will output the same level. If you just want audio to go to your surround sound then just hook the video cables up to your TV and the audio to your surround sound. I would guess that you are using Red and White cables... If you are that only gives you left and right audio. Not surround sound, so you would want to run optical, HDMI, digital coax, or the analog 6 channel audio cables.
Sep 09, 2010 | Televison & Video
We have a picture but no sound, it is hooked up to our surround system and the dvd and radio work and we have sound coming out of the speakers but no tv sound....help
Try switching the external/internal speaker switch on the back of the tv to internal. This way you should at least get sound (from the TV not the sound system) when you change the volume of the TV itself.
Explain your set up if you need more help. By that I mean what do you have hooked to the TV and sound system, Satellite or digital cable box DVD ?
Make a note of where all the inputs to the sound system come from.
Dec 04, 2009 | RCA P56830BL 56" Rear Projection...
CAN I PLAY THE DVD PLAYER WITH SOUND THROUGH MY TV WITHOUT HAVING THE SPEAKERS CONNECTED?
You can set up your tv in this way. Hook up your dvd player directly to your tv and then hook up your surround sound reciever from the audio out jacks from the back of your tv. This should allow you to use either your tv volume or the surround sound feature. Hope this helps
Oct 21, 2009 | Samsung HT-Q40 System
No volume
Things to check,
1. are you using an external cable/satellite box.
if the answer is yes , verify if you have the audio out of the reciver connected to a surround sound system
If you do have it connected to a surround sound system , verify the surround sound systems volume is up and on the correct source input on the surround sound system
2. if you do not have a external cable/satellite box and and or your not using a surround sound system, and the cable line is connected directly to the television via a coax cable.. then verify that in the audio settings configuration of the telivision you have not accidentally disabled the internal speakers, some tvs have this option , please consult your manual.
Sep 24, 2009 | Philips Magnavox 27MS343S 27" TV
Volume does not work.
Good day.
You are possibly right. Audio circuit might got affected. I would like to suggest likewise that you check also if the speaker is busted, the audio IC and if it receives supply from the flyback.
chris
Jan 29, 2008 | Sharp 27K-S100 TV
FLM 3232 television low volume
I hooked my tv up and there is no sound coming from the tv. I do not have surround sound just the tv. How do I make it work I need volume please
Oct 15, 2007 | Polaroid FLM-3232 Television
Surround sound not working through ordinary tv
Try connecting the red and white audio cords to your system from your cable box/satellite receiver instead of your tv. Worked for me.
Oct 01, 2007 | Audio Players & Recorders
Hitachi 50CX29B 50" Rear Projection Television Logo
89 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
