Question about Zanussi ZBF360 Electric Single Oven
Fan not working
Oven working but not the fan
  • 32 Answers
Hi, its likely that the fan motor isn't working. (most times is just build up of grease) If you're good with DIY, remove the inside panel that covers the element and the fan, undo he nut CLOCKWISE, pull the oven out, remove the the back cover, remove wiring from fan motor, clean the motor with WD40, and give it a few turns to see if turns freely. Reserve the process.
Cheers
Posted on Feb 12, 2009
Oven and works but fan not working bush ad66tb
The fan could be greasy and "stuck", you'd have to take it out to check.
Unfortunately replacement fans are quite expensive:
Bush AD66TB Fan Motor 230V 23W Cl
Jul 15, 2016 | Ovens
Oven fan not working
If you select the function on the selector switch which turns both the fan forced fan and the oven element on at the same time and the fan does not work, but the oven element does then the fan forced fan is faulty and requires replqcement.
Feb 25, 2011 | Stoves 720EF Electric Double Oven
ZBF360X Electric Single Oven: fan oven working but no heat...
If the main oven fan is working but no heat it is most probably the ring element which is around the fan blade inside the oven.Check it is the element before you go and replace because there could also be an issue with the thermostat.Hope this helps.
Good Luck,
May 07, 2010 | Zanussi ZBF360X Electric Single Oven
Hotpoint BD35 oven fan not working
The air you can hear blowing will be from the exterior cooling fan, and nothing to do with the main oven.
You need to check to seeif you have got a feed to the oven fan and element, the supply comes from the oven thermostat on the control panel.
Hope this helps.
Jan 15, 2010 | Ovens
Smeg fan assisted oven not heating up , top oven works fine but main bottom oven doesnt heat up at all but fan working fine many thanks
So long as fan is working o/k, then all you need to do is replace the oven element at rear of oven
Please rate my solution.
Thanks
Nov 10, 2009 | Ovens
Candy F254/3X single fan oven, grill works, oven doesn't.
If fan is working o/k, then you need to fit a new oven element
Please`rate my solution.
Thanks.
Aug 24, 2009 | Candy F248P Electric Single Oven
Noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven not heating up
Hi.
If the fan is working o/k, then in all probability the fan oven element has failed.
A common problem with fan assisted ovens.
It is a fairly easy job to replace same
Nov 13, 2008 | Baumatic B180 Electric Single Oven
Smeg electric oven
your neighbour is probably right. fan should work but if the element has disintegrated, bits of the element could be jamming the fan. take the rear panel off inside the oven and check
Jun 01, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Zanussi ZBF360 Electric Single Oven Logo
262 people viewed this question
Top Zanussi Ovens Experts
ashburton
marley mcelhinney
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
