Question about Canon PIXMA iP4000 InkJet Photo Printer
Paper won't go in straight
I have a Canon Pixma MP470. The paper won't feed in straight. Is there a way to straighten it?
Thank you.
  • ddowney Mar 31, 2009
    Paper will not go in straight-paper gets crushed. do I need to use heavier paper?
    Sergeant:
  • 366 Answers
Check paper quality (wight, adsorbed humidity etc,) change it and reduce humidity where you store anf use it.
Posted on Feb 09, 2009
How to fix Canon Pixma MP470 printer that does not feed paper properly to print from Windows PC
Open up the printer and see if there is a small piece of paper that is interfering with the paper path. You may have to use a flashlight to see it.
Sep 10, 2014 | Canon PIXMA MP470 All-in-One Printer
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Double printing on pixma mp470
Double printing or double feed??. Double printing means document printed in 2 copies. Double feed means printer feed double paper in one moment. For double printing,please check number of copy of document in printing preference properties.
Double feed occurs when pickup roller fails to pick the paper correctly. It's usually caused by shaft of paper pick up roller which is broken. You should replace drive assembly (include pick up roller) in this case
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
Canon Pixma MP470, paper feed not straight
Hi Dave
First thing to check is that the left hand paper guide (as you look at the printer from the front) is up tight against the edge of the paper stack in the feeder. I've seen many printers where (over the course of day to day use) the paper guide has progressively moved itself to the left so that the paper is not held at all. The pick-up for the paper is at the bottom right hand corner and if the guide is loose the paper can skew as it goes in - and then it only gets worse.
Another possibility (and this has just happened to me) is that the long piece of sponge that runs the length of the platen (you'll only see it if you open the top and shine a light in) has come adrift slightly. Mine actually came completely out after 2 or three skewed/crumpled sheets. I washed it, dried it out with kitchen towel and then carefully refitted it. Now the printer is running like a demon.
Let us know what your outcome is.
Dec 06, 2009 | Canon PIXMA MP470 All-in-One Printer
Canon MP470: paper stuck
Unfortunately you need to disassembly the hole printer to solve the problem.In most case the object who block the paper is under the withe rollers and you can't see it from above.
Oct 12, 2009 | Canon PIXMA MP470 All-in-One Printer
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Paper feed not straight, causing jambing
You need to look inside the slot where the paper is loaded with a flashlight and small mirror. Usually the only reason that happens is when something has fallen in where the paper goes. I usually find pins, paper clips, candy wrappers, or jewelry dropped inside. A paper clip straightened out can help remove the objects.
Oct 02, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My MP470 Pixma won't feed paper, it pulls right
Based on instructions from your website I pushed a letter sized piece of thin cardboard backwards through the paper feed rollers then shook the printer while holding it upside down. A Q tip fell out, problem solved.
Jul 19, 2009 | Canon PIXMA MP470 All-in-One Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
181 people viewed this question
old marine
old marine
Corne Viljoen
