Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Hear the motor running, no water in dishwasher
11 year old Maytag Jetclean QuietPlus. Problem: I can hear the dishwasher running but there isn't any water at all. Must note I have had a leak for weeks - a small amount of water (1-2" diameter) on the floor below my dishwasher. No problem I would just swipe it up with a cloth. I decided to take the lower panel off a couple of days ago to be sure there wasn't any water leaking underneath. Everything is fine but I left the panel off to keep an eye on it for a couple of days. Our kitten did get underneath - is it possible a wire or something was loosened?
I thought I would fix this myself - but hubby took a look, wiggled a few wires and said 'there's your problem'. The water valve would not open because a connecting wire was loose. It was the kitten after all - I'd better pop that panel back on.
Posted on Feb 08, 2009
Maytag will not start, has power and control panel running fine
Do you ever clean it with a dishwasher cleaning agent and run it on any wash mode?
Mar 08, 2017 | Maytag MDB9600A Jetclean II Built-in...
Does not woork
Has the water drained by the time the dishwasher powers off?
The clicking sound is probably the (failed) pump motor and will require a service call or replacement of the unit.
Mar 27, 2009 | Maytag MDB9600A Jetclean II Built-in...
MAYTAG DISHWASHER LEAKS WATER AROUND THE TOP OF THE MOTOR
There is a sump gasket that has almost certainly worn out and will need replacing. This is not a simple task. Good Luck!
Mar 21, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
White build-up
this is scale build up you should run a descaler through your unit if you cannot find any viniger works just let it sit in overnight
Dec 10, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag dishwasher jet clean eq plus water not filling with water
My Maytag Jetclean Flexiload is 4 years old. Upon choosing a program the timer counts down but little action is heard. Near the end of the cycle an Error message comes up. The dishes are stiil uncleaned.
Apr 23, 2008 | Dishwashers
Quiet Series 100
It sound like a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if pump spins when it should force the water up into the sprayer arms. In case it doesn't spin you should replace the pump. Good luck !
Sep 11, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
173 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
