Question about Hoover Washing Machines
Washing machine wont go into full spin
My washing machine will not go into full spin mode it will spin at the lower spin speed but will not go into 1400 spin mode i have cleaned the filter at the bottom of the machine
  • silver top May 11, 2010
    hi from uk if machine is completing cycle except for 1400 spin? if your machine is 2yrs old +? may i suggest that this is more than likely the motor brushes are worn low resulting in being unable to cope with demand for 1400 revs not an uncommon fault and happens on lots of models however the cost of these brushes cost £5--£6 pounds here in uk and easy d i y to replace if you wish to save $$$$s on call out and repair cost ? if you are diy minded? hope this helps and inspires you ?
Hoover soft wave 1400 not spinning but trying to
stuartknox1@hotmail.co.uk
Posted on Oct 11, 2011
Was advised could be bushes so replased them works a treat thanks
Posted on Feb 08, 2009
GE GFWN1100LWW. Can the high speed spin work on the lower wash cycles?
From my experience, the lower wash cycles are set to only do certain things. For example: the Delicate won't do a high speed spin, even though a high speed spin wouldn't really be destructive to delicates, but would force more water out of them! I usually just run a "Drain/Spin" after the Delicate cycle.
Nov 27, 2015 | GE Washing Machines
My machine wont run, i replaced the drain pump and thermostat sensor.
Depending on your model pushing soil level and spin speed at the same time then hitting the power button will start it in diagnostic mode from here out pushing start will check its features, door lock, low spin, high spin, pre wash, wash, bleach, softener, rinse, drain, spin...ext
Jun 01, 2014 | LG WM2688HWM TROMM SteamWasher
Electrolux washing machine wont spin all the way
Not a solution, but I wonder if it thinks you've either selected no spin or it thinks the machine isn't drained and so won't spin or it thinks the load is unbalanced. You seem to have done everything logical so far.
Also look at all all connectors
Logic seems to dictate that if the motor/motor drive functionality and other diagnostics don't show any problems (although I must admit if it were possible I'd like to try another motor control board just to convince me it wasn't implicated) then it must be a logic/ sensor problem and maybe diagnostic mode doesn't check all sensors in the same way as would happen in normal use? Sorry I can't be of more help. (The motor brushes are probably ok but I'd check them anyway while you are in there) Do let us know if you find anything.
Apr 16, 2014 | Electrolux EIFLW55HIW Front Load Washer...
Neff washing machine wont spin ~ drum rotates but not at speed
how old is machine if machine is bout 5 years will need motor brushes they need t be changed every 5,6 yrs, if its quite new will be ure motor pcb if its not rampin up to full on spin
Feb 03, 2010 | Washing Machines
Wont spin cycle at full speed
Burning smell is a slipping belt. These are tricky to get apart and diagnose but find the reason the belt is slipping and replacing it will solve your problem. Could be clutch, bearing or gearcase related.
Eric
Dec 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
Wont finish a small load. Gets to 4 minutes and
With a small load, the machine will have a difficult, if not impossible job of balancing the load. A bigger load will help. Another thing you can do is to use a low spin speed. If you wish to spin it out faster, just turn the machine back on after it has finished a cycle on the low spin speed and just push the spin speed button without selecting a cycle. You can touch the spin speed button until it shows the next higher spin speed, then push the start button and the machine will not fill with any water, it will just pump and spin. (about 14 minutes) This generally works, because you have spun most of the water out at a lower spin speed, and now the washer is able to reach the next higher spin speed as the load is not as unbalanced as it was before the low speed spin.
Nov 17, 2009 | LG WM0642H Front Load
Hoover AM1100 Washing machine, wont final spin.
The noise, is it a grinding noisy like worn bearings?
put the washer on drain only - is the pump working ok, take the filter out to see if it is turning ok, does that make a strange noise?
If the pump is fine, its back to that noise, it could be be a faulty tacho on the motor ( regulates the spin speed) or motor bearings - has the motor spindle a lot of play on it?
Let me know how you get on and good look!
Nov 09, 2009 | Washing Machines
Spin cycle slow unless hose lowered
you will have to take the hoses off the pump and clean the pump out its probably got sand in it
Apr 23, 2009 | Washing Machines
Kenmore front loader washer
you need to replace the speed control unit (board) in the lower right corner in the back of the washer it is faulty
Jan 24, 2008 | Kenmore 44102 Front Load Washer
Washing Machines Logo
751 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
