Question about D-Link DI-804HV - 4-Port Broadband VPN Router DI-804HV - 4-Port Broadband VPN Router [ DI-804HV ] (109528)
DI-804HV setup problem
I have a DI-804HV,and I would like to setup a PPTP VPN connection so I can connect to the DI-804HV using the Windows PPTP client. Right now for the testing purpose I have a network cable connected from my DI-804HV to my computer directly.
I have followed the following HOWTO: http://tiny.cc/fKFKq
when I try to connect to the DI-804HV I get a "Verifying username and password" after which it disconnects.
I have tried from many different computers, and I have even restored the DI-804HV to its factory defaults few times. But always the same.
Any ideas, on what could be wrong?
5 Suggested Answers
  • 196 Answers
SOURCE: Configuring the DI-804HV/DI-808HV
Step 1: Log into the web based configuration of the router by typing in the IP address of the router (default: 192.168.0.1) in your web browser. By default the username is admin and there is no password. Step 2: Click the VPN button on the left column, select the checkbox to Enable the VPN, and then in the box next to Max. number of tunnels, enter the maximum numbers of VPN tunnels that you would like to have connected. Step 3: In the space provided, enter the Tunnel Name for ID number 1, select IKE, and then click More. Step 4: In the Local Subnet and Local Netmask fields enter the network identifier for DI-804HV´s LAN and the corresponding subnet mask. Step 5: In the Remote Subnet and Remote Netmask fields enter the network identifier for the DI-804V´s LAN and the corresponding subnet mask. Step 6: In the Remote Gateway field enter the WAN IP address of the remote DI-804V and in the Preshared Key field, enter a key which must be exactly the same as the Preshared Key that is configured on the DI-804V. Step 7: Click Apply and then click on Select IKE Proposal... Step 8: Enter a name for proposal ID number 1 and select Group 2 from the DH Group drop-down menu. Step 9: Select 3DES as the Encryption Algorithm and SHA-1 as the Authentication Algorithm. Step 10: Enter a Lifetime value of 28800 and then select Sec. as the unit for the lifetime value. Step 11: Select 1 out of the Proposal ID drop-down menu and click Add To, which will add the proposal that was just configured to the IKE Proposal Index. Click Apply and then click Back. Step 12: Click on Select IPSec Proposal... Step 13: Enter a name for proposal ID number 1 and select None from the DH Group drop-down menu. Step 14: Select ESP as the Encapsulation Protocol. Step 15: Select 3DES as the Encryption Algorithm and MD5 as the Authentication Algorithm. Step 16: Enter a Lifetime value of 3600 and then select Sec. as the unit for the lifetime value. Step 17: Select 1 out of the Proposal ID dropdown menu and click Add To, which will add the proposal that was just configured to the IPSec Proposal Index. Click Apply and then click Restart. Configuring the DI-804V: Step 1: Access the router?s web configuration by entering the router?s IP address in your web browser. The default IP address is 192.168.0.1. Login using your password. The default username is admin and the password is blank. Help Accessing Web Management Step 2: Click on Basic Setup and then select Device IP Settings on the left. Step 3: Change the LAN IP address so that it is on a different subnet than the LAN of the DI-804HV (ie 192.168.1.1). Step 4: Click Next until you reach the Save & Restart screen. Click Save & Restart and then click Basic Setup once the unit has rebooted. Step 3: Click on VPN Settings. Step 4: Name your VPN connection and click ADD. Step 5: In Remote IP Network and Remote IP Netmask fields enter the network identifier and corresponding subnet mask of the DI-804HV´s LAN. Step 6: In the Remote Gateway IP field enter the WAN IP address of the DI-804HV and make sure that the Network Interface is set to WAN Ethernet. Step 7: Verify that Secure Association is set to IKE and that Perfect Forward Secure is Disabled. Step 8: Verify the Encryption Protocol is set to 3DES and enter in your Preshared Key. The Preshared Key needs to be identical to the one configured on the DI-804HV Step 9: Leave the Key Life and IKE Life Time values at their default levels and click SAVE. Step 10: Click Next and then click on Save & Restart Establishing a connection: Step 1: Open a command prompt (Start > Run and type CMD) and from a computer on the internal LAN of the DI-804HV, ping the IP address of a computer that is on the internal LAN of the DI-804V, or vice versa. Step 2: Once you begin to receive replies, the VPN connection has been established. Step 3: To view the Status of the VPN on the DI-804V, click on Device Status. Step 4: From the Device Status screen click on VPN Status. Step 5: When the VPN has been established, the Status will be Active.
Posted on Feb 16, 2006
XBRMann
  • 38 Answers
SOURCE: DLink DI-624s - can't get Cisco VPN Client to connect.
The "Virtual Server" setting is designed to give the general public access to a network resrouce (web/ftp/media server) on your internal network. If your the VPN concentrator is external to your network (meaning you'll have to use the internet to connect to it), then you won't need to define a virtual server on the DI-624.
You'll just need to enable the IPSEC and PPTP VPN Passthrough which it sounds like you've already done this. I've run into some ISP's that block VPN connections out of their network. If you have the ability, try to directly connect your laptop into your cable/DSL modem in place of your router and see if you can make a VPN connection, if not contact your ISP, if you can then verify you enabled the VPN passthroughs because your router is blocking them.
GIve it a shot and let us know your results.
Posted on Apr 27, 2008
  • 5 Answers
SOURCE: using DI-804hv, I can connected to vpn but not to LAN
First set up an static IP address on your computer with a range 192.168.3.x, once you connect to the DI go to >> LAN Settings and change there the DI IP to be in your range of 192.168.2.x.
If you use win XP here is a link how to set up a static IP with your computer:
http://www.hotcomm.com/FAQ/FAQ_staticIPXP.asp
Regards,
Adnan
Posted on Jan 31, 2009
redhaze89
  • 854 Answers
SOURCE: How to Site to Site VPN between DI 804HV and DI
you can try to do port forwarding by logging in to router GUI setup page and manage this port
Service Name Start Port End Port Server IP address
VPN1 47 47 192.168.1.x
VPN2 50 51 192.168.1.x
VPN3 500 500 192.168.1.x
VPN4 1723 1723 192.168.1.x
Posted on Jul 13, 2009
I am running vista and using the dlink di-808hv router. i have set up a pptp connection. when i use ms vpn to connect, it connects but only limited connectivity. can you help?
Peer to peer tunneling protocal is what pptp is if its connecting a limited connectivity that means some of the ports are stull being blocked thus needing for you to use your machine in a demilierized zone so this will open all avilable ports to your VPN software. Also keep in mind not all ISP's will support PPTP so you may have to use a softvpn software. Thanks i hope this helps
Sep 01, 2009 | D-Link DI-808HV Router (280006OB)
Tip
How to setup VPN on a D-link Router.
Ok to Setup you VPN follow the instructions below. You can configure DI-804HV, DI-808HV, and DI-824VUP+ by web management interface. Type 192.168.0.1 (The LAN IP is 192.168.0.1 by default) in the browser, and then input user name: admin (there is no password by default) to pass authentication of web management interface. Then finish the configurations as showed below on Gateway A and Gateway B. Configurations of Gateway A 􀂾 Model: DI-804HV (DI-808HV, or DI-824VUP+) 􀂾 Firmware version: v1.40 (You can download the latest firmware on D-Link’s website.) 􀂾 WAN IP Address: 14.15.16.17 (Static IP) 􀂾 LAN IP Address: 10.5.6.1 (Subnet Mask: 255.255.255.0) 􀂾 VPN Configurations: 􀂄 Enable VPN function on Gateway A. 􀂄 Tunnel Name: toGatewayB 􀂄 VPN Method: IKE (Main mode) 􀂄 Local Subnet: 10.5.6.0 􀂄 Local Netmask: 255.255.255.0 􀂄 Remote Subnet: 172.23.9.0 􀂄 Remote Netmask: 255.255.255.0 􀂄 Remote Gateway: 22.23.24.25 􀂄 Pre-share Key: hr5xb8416aa9r6 􀂄 IKE Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 28800 􀀹 Life Time Unit: Second 􀂄 IPSec Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encapsulation Protocol: ESP 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 3600 􀀹 Life Time Unit: Second 4. Verify the VPN connection Before you start to establish VPN connection between Gateway A and Gateway B, please make sure the Internet connection between Gateway A and Gateway B is workable. You can use “Ping Test” tool on Gateway A (or Gateway B), and input the IP address of Gateway B (or Gateway A) to see if there is any response from its peer device. Connect a PC (called PC_A) to the LAN port of Gateway A, and connect another PC (called PC_B) to the LAN port of Gateway B. Start to “Ping” PC_B on PC_A, then Gateway A will start to establish IPSec connection with Gateway B. If you can get “Ping” responses from PC_B on PC_A, then it means the tunnel has been established successfully. You can also check the “VPN Status” page with web management interface to verify the status of VPN connections. Figure 1: VPN status of Gateway A after IPSec connection has been established. Figure 2: VPN status of Gateway B after IPSec connection has been established.
Hope this helps
Here it is in PDF.http://www.vpnc.org/InteropProfiles/D-Link-DI.pdf
on Feb 11, 2010 | Computers & Internet
How to Site to Site VPN between DI 804HV and DI 804HV.
Jul 13, 2009 | D-Link Express EtherNetwork DI-804HV...
Using DI-804hv, I can connected to vpn but not to LAN
Regards,
Adnan
Jan 23, 2009 | D-Link DI-804HV - 4-Port Broadband VPN...
Vpn client
This router has built is VPN software that allows VPN from anywhere in the world. There would be no need for a software based VPN
Jan 15, 2009 | D-Link DI-804HV - 4-Port Broadband VPN...
D Link DI 804HV is Server OS Windows 2k 2003 necessary? Or ca
The D Link DI 804HV is a standalone router/vpn it can work with any OS (Windows xp, vista, me, linux, mac...)
Regards,
Adnan
Dec 30, 2008 | D-Link DI-804HV - 4-Port Broadband VPN...
Apr 26, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Dec 31, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
D-Link Vpn Router model DI-804HV
Can you tell me the setup with your router? It should be Internet->Modem->Router->Computer If that's setup properly (the wires in the right spots) then go to the gateway IP of the router...it might be something like "192.168.0.100 "so you put that in your internet browser. The default user is "admin" with no password. Make sure to run the "Wizard" while on that page and after that go to the "Status" page and check to see if the WAN connection is connected properly.
Aug 28, 2007 | D-Link DI-804HV - 4-Port Broadband VPN...
Feb 16, 2006 | D-Link Express EtherNetwork DI-804HV...
Computers & Internet Logo
159 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
