Question about Orion STV2763 27" TV
Remote doesn't work
The remote doesn't work for my Orion. How will I be able to scan digital channels with the converter box without it?
I have lose my remote and I have parental code lock n Iam using my cable remote, but can not key my code n cable remote to deleted parental off.Please help me
Posted on Feb 13, 2009
Attach tv converter box
Everything is digital now. You will need a digital converter box. You will connect an antenna to it, and then connect the box to your tv. The box will come with it's own remote. Your tv will be set to channel 3 or 4 (depending on the converter box you get), and you will control the stations with the remote that came with the converter. You can get them at any electronics store.
Jan 09, 2014 | Jensen J53-BWR 5 in. Portable Television
Have had digital installed and cannot get tv to work through digital. Any advice?
Hello
Thei Orion model Tv is not equipped with a digital tuner inside. There is only an analogue tuner fitted and only analogue channels can be received by this set. To get digital channels, you have to buy one settop box, which can convert digital signals to analogue signals. In short, a Digital to Analogue Converter should be bought, if you want to get digital channels. OK.
Dec 23, 2011 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
I need to know how to access menu or run channel scan on rca dta 800b1l converter box without the remote
There is not a way, unless you get a universal remote, scan for the code to control the box, and then get into the menu.
Dec 18, 2011 | RCA (DTA800B1) Video Converter
Magnavox converter box codes
There are no available codes for these, if you are using an universal remote, use the scan function. Typically when scanning you hold down setup on the remote, press SAT/Cable, then power. If it doesn't shut off the box, you press Channel up, and power again. Repeat the Ch. Up and power to keep going to the next code. When you do find the correct code the converter box will power off when you hit power. Press Enter on the remote to store that code for SAT/Cable. Enjoy
Dec 18, 2011 | Magnavox (TB100MG9) Video Converter
When I got the remote control and started the channel setup, it only picked up Digital channels, and I don't know how to have all of the other cable channels show up. The channel numbers come up like...
This is a newer TV. It doesn't have an analog tuner. You will have to buy the analog to digital converter box and re-scan your channels, or switch to a digital cable/dish provider.
Aug 26, 2011 | Televison & Video
I have an Orion 19"
You usually need the original remote. The trouble with universal remotes is that they generally control only the basic functions of a TV (power, volume, channel) but not much else. Without the original, you often lose other functions. You can try the front panel buttons if yours has them. On some sets the on-screen menus allow you to access caption settings.
But are you sure the captions are coming from the TV? Sure, the TV is displaying them, but if you have a satellite receiver, cable box or digital set-top box, the captions may be coming from that device. This is likely to be true if the captions just mysteriously started and you don't have or aren't using the TV original remote. These devices often don't allow a TV's built-in caption decoder to work properly, so they provide captions themselves. You may have turned captions on using that device's remote. Check the menu for caption controls.
Jul 10, 2011 | Orion1934 19" TV
I have an older Sanyo (approximately 8 years old) and my remote control is damaged (only the buttons/controls on the right side are working, volume turns up but not down, most of the left keys do nothing)....
If you are feeding the signal from your digital converter into the TV antenna input, I would input the converters signal to the TVs video input instead. I am assuming your converter has a video output signal and left & right audio so you will need cables for your audio also. If your converter has only rf output for the TV tuner input it is generally on either channel 3 or 4 and there may be a switch to set this. It is possible that when the TV scanned for channels the converter was off and it did not find a signal on 3 or 4. If you can get the TV to re-scan, be sure the converter is turned on and on an active channel. All your channel selection should be via the converter after that and the TV simply stays on 3 or 4. I would suggest looking in to getting the original remote. Try partstore.com and see if they have one for your model.
Nov 18, 2009 | Sanyo DS27930 27" TV
I have a 13' Orion tv, model #TV1326BW with rabbit ear antenna. I have connected everything correctly to the converter box for digital signals. I can pick up all stations except the local CBS affliciate....
I have the same TV & cannot get into the TV menu to program the cable... it was bought secondhand without the original remote. There are no buttons anywhere on the TV itself to bring up the menu & the universal remote's menu option doesn't do it, either... how do I set the channels?
Aug 04, 2009 | Televison & Video
Orion STV2763 27" TV Logo
154 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
