Question about Philips Magnavox DVD/VCR Dual Player
MAGNAVOX ZV420MW8 DVD RECORDER CONNECTION TO COX CABLE BOX.
TRYING TO CONNECT VCR/DVD RECORDER TO OLDER MAGNAVOX TV THRU MOTOROLA DIGITAL CABLE BOX. MANUAL IS GREEK TO ME. I DON'T SEE ANY INSTRUCTIONS FOR CONNECTING THIS VCR/DVD TO THE COX DIGITAL CABLE BOX. PLEASE HELP!!!!!
THANKS!!!!! mary
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
In most configurations, it would be:
Cable IN > Motorola Cable Box > A/V IN of VCR/DVD Recorder > Magnavox TV.
Perhaps it would be clearer if you could post back the brand/model of the VCR/DVD or preferably what available connectors are present at the rear of the Motorola, VCR/DVD and the Magnavox. Below is an example of how the wiring could be possibly done albeit for different brands.
Should you be interested in such a connection diagram specifically for your equipment, pls post back as requested. Good luck and thank you for using FixYa.
Posted on Feb 07, 2009
    Genius:
  • 2,920 Answers
The easiest way is to run the cable from the cable box to the back of the dvd to where it says IN then you need to run another cable from the dvd player from where it says OUT to the back of the tv. that shouled get you up and going
  • 679 Answers
If you want to connect a DVD player and a cable box to a TV that has only one composite video/stereo audio input use a AV (Audio Video).
here is your pictures for more help>>
http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/cable_vcr_tv.pdf
Thanks for using FixYa
  • Philips Master
  • 19,396 Answers
Let me know if tv has scart socket or only coax round socket for aerial input.
  • Ginko
    Ginko Feb 07, 2009
    The best solution would be replacing the cable box with a newer one that has digital output instead of coax.
    Your magnavox has Coax input. You can connect cable box using this input if you have no alternative.
    Using Coax (aerial) input you will also need to tune the receiver box as a channel on DVD.
    As output from the Magnavox to TV you need to buy an adapter from component cabls on DVD to SCART on TV, here is the connector:
    4m ( 13ft ) Atlona High-quality Scart ...
  • 744 Answers
Hi.. actually the two pins are available from VCR player.. take the output pins from VCR port and connect it to the digital cable box.. The 2 output pins from VCR are yellow and red in colour.. So try to connect as with same colours corresponding to that digital box.. after connecting it connect the output port from digital box to ur TV....
thank u
rate me!!
Dvd/vcr recorder magnavox model mwr20v6, i got probelm hooking up my dvd/vcr recorder to my cable converterbox an tv , because i broke the antenne/ out socket on the back of the unit, how can i get it to...
Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well..
Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
** in order to listen and watch your
magnavox DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected ) (audio will come thru Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on
magnavox
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has different type of Audio out jacks )
** to "iRCA nput or "Optic Cable input"
of your
magnavox (whichever you want ,based on the necessary cables on your hand )
There you go..Tv/Cable box video and sound are both on the
magnavox for recording..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 15, 2011 | Televison & Video
Got cox Digital cable box today, cox can not tell me how to hook up to box to make it rec/play. Info I read old cox papers from 2002 says I need a vcr controller, Cox does not know what that is and it...
For a standard VCR which is what most people have, all you need to do is connect a yellow RCA cable for video from the yellow output jack on the cable box rear panel to the VCR's yellow video input jack on its rear panel. Next connect a white RCA audio cable from the cable box white RCA output jack to the VCRs white RCA audio input jack. You can record a cable show by selecting the LINE input on the VCR and selecting the TV show on the cable box.
Now for playback, connect the VCR to your TV. Connect a yellow video cable from the VCR's yellow output jack to the TV's yellow video input jack. Same for the white audio connection. Select on the TV, the source input for the VCR. Its not complicated and you should not need any other devices for a standard setup with a digital cable box and vcr.
Aug 25, 2010 | Toshiba Televison & Video
How do i connect my magnavox zv420mw8 to my cable boxconverterand modulator
the cable from the wall is to the cable box in....(do have monitor) cable box out to tv coax in...dvd / vcr & audio outs to tv ins....and tv outs back to dvd vcr audio in....tv is on ch 3 for cable...look for your dvd /vcr or aux ch when want to look a dvd or vcr...now set the dvd to ch 3 settings and cable broadcast...your cable box will determine what you record....note HBO may not record on DVD, but will on VCR tape
May 15, 2010 | Philips Magnavox DVD/VCR Dual Player
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
NO AUDIO ON MAGNAVOX ZV420MW8 RECORDING SECTION
Are you using AV cables (Red, Yellow, White).
One of your AV cable connections may loose or disconnected.
I hope this solution is helpful. Please remember to rate this solution.
Feb 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Usually a cable box has a RF (antenna connect) IN (from the external signal) OUT (cable going to the TV_RF in)
Usually one has to place TV_channel on 3 or 6 (my TV ch. 60).
EXTERNAL signal goes in CABLE box RF_in, CABLE box RF_out to the TV (RF_in).
In order to connect DVD/VCR, [IN LINE with cable & TV] just connect the RF_out from CABLE BOX into the RF_in of the DVD/VCR, RF_out of DVD/VCR to the TV RF_in.
Jul 24, 2008 | Philips Magnavox DVD/VCR Dual Player
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Jul 17, 2008 | Philips Magnavox DVD/VCR Dual Player
Magnavox ZV420MW8
This recorder only records inline. This means that there is no channel on recorder. It records whatever your satellite or cable box is showing. You'll have to change the channel on that.
I don't know that this will work for timed recording. You'll have to make sure that your cable/satellite is on and set to the proper channel before you leave. This wont work if you're recording multiple shows on different channels while you're gone. In that case you may need a different recorder.
Mar 16, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox DVD/VCR Dual Player Logo
288 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
