Luxman L100U Have Right channel out. unit will play right channel if I switch/cross preamp jumpers l to r r to l. I can then hear output using balance control on right side. unit had 2 bad 5amp fuses on power supply. I rplaced them and this is where I am at. I need troubleshooting dissection points. I also have a blurry schematic. Thanks, Ray
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Based on your post, probable fault would be in the right channel pre-amp section since the right amp would work also/still with the switching of the the pre-amp jumpers, hence none of the amps would be faulty.
The 2 5A fuses could be for the +/- supply while the right channel pre-amp could have a faulty transistor, a limiting resistor, regulator/diode. Perhaps you can post the schematic.
Good luck and thank you for using FixYa.
Posted on Feb 07, 2009
  • 679 Answers
tell me that you change the right amp. fuse.
or change to some low amp's.
Thanks
  • 19,396 Answers
Ensure that you do not have just a faulty speaker, swap speakers connection first.
  • Ginko
    Ginko Feb 07, 2009
    If by using balance you can hear the sound on the right channel, and by swapping channels on preamp section you can hear sound then the problem is either preamp or controls.
    Start testing the balance control, that is the most likely cause for the problem.
    If the balance is ok, then the preamp circuit for the right channel has a blown component or a lose contact (broken solder joingt usually), that is the reason why it works when you swap channels.
Preamp intermittent channel
Getting the connections right is a problem. One thing I find helps is the THX DVD discs that certain movies have on them. They have a sound set up to get it right. It makes a tone for each channel so you can hear which channel is working. It should help you set up the system right and determine if any channel has a fault on it.
Feb 08, 2014 | Adcom GTP-870HD 7.1-Channel Amplifier
How can a PMP 2000 be patched so that both internal amps are used to power the monitors, and the mains are sent from the mainpre-out to another power amp, while using one internal eq for the mains, and the...
No you can't quite do this since the EQ's are right before the power amps in the signal flow. The monitor output would drive two 8 ohm speakers daisy chained at roughly 300 watts RMS... I can't imagine needing more than that for a venue that is within the capabilities of this unit.
You can drive both power amps by the monitor output by setting the mon/main function on the switch and using a short TRS cable jumper between MONITOR PREAMP OUT and the RIGHT POWER AMP INPUT jack. Drive your mains from the LEFT PREAMP OUT. The EQ's will ONLY affect the monitors. Use an external EQ if you need to EQ the mains with this connnection. Use TRS balanced cables to the main amp and CONNECT all interconnected equipment to the SAME power source or receptacle, even if it means running an extension to the mixer.
Apr 05, 2011 | Behringer PMP2000 800 Watt 10 Channel...
I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Aug 10, 2009 | Yamaha RX-V2600 Receiver
Left side output
Sounds like there is a short somewhere on the left channel inside the amp. not easy to fix without seeing the unit.
Jun 16, 2009 | Crown CE2000 2-Channel Amplifier
Blown output drivers
The transistors are 2SK405 and 2SJ115.
I fix Luxman if you dont mind sending to Vermont.
Cheers ( I hope that helps)
Feb 14, 2009 | Alpine Audio Players & Recorders
No output in Right channel on my Adcom preamp GTP-450
Hi...
Have you tried swapping speakers to see if the trouble moves to the other speaker?
It could be a dirty selector switch .
It could be a broken solder contact on the input or output RCA jacks
Feb 07, 2009 | Adcom GTP-760 Amplifier
How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Dec 16, 2008 | Marantz PM7200 2-Channel Amplifier
No right channel output
Feed the amp with the left channel preamp to the right channel input on amp and check output. If you get output from amp then pre amp nedds to be checked out if still no output then amp is suspect. Randy
Feb 16, 2007 | Bryston BP-25 Amplifier
119 people viewed this question
 Grubhead
Grubhead
