Question about Maytag MSD2756G Side by Side Refrigerator
I have a Maytag side-by-side MSD2756GEB that quit cooling.
Everything in freezer thawed, and refrigerator side is no longer cold.  There is also a smell coming from behind fridge that is like something in compressor unit(?) has burned out.  Obviously, I need a repair man.  Any suggestions as to what may actually be the culprit that needs repair?
  • 700 Answers
Sounds like either the fan motor or the compressor. go ahead and open upo the bottom baclk panel and see if the fan is running or if the compressor is. could be just a burned wire.
Posted on Feb 07, 2009
Maytag side by side is freezing things in crisper...help
Posted on Feb 28, 2009
Freezer quit freezing ice cream Thur night, but everything else was fine, not everything is starting a slow thaw
either the ptc overload relay on the compressor is bad and the compressors not operating to cool the unit or the evaporator coil behind the freezers inside wall is iced up and cant let cold air out due to this blockagethen its a defrost heater/thermostat on the evaporator coil issue
Jul 02, 2011 | Kenmore Side by Side Refrigerator
Coils in my 2454 packed solid with ice. Thawed it out....worked fine for a couple of weeks. It quit staying cold so I dug behind the freezer to discover the coils again encased in ice. Thawed it...
your defrost heater around the coils is open and can no longer heat,or the adaptive defrost timer or defrost thermistor are defective located in the refrige control panel behind the temp controls and the thermistor is located on the defrost heater assy
May 02, 2010 | Maytag MSD2454G Side by Side Refrigerator
Freezeer and fridge quit working
It's possible that the Adaptive Defrost Control part number 61005988 has your compressor shut down. It is also possible the temperature control is defective. Jumping the 2 wires behind the control will answer that. And its also possible that the start capacitor, start relay and overload has failed on the compressor. I would like you to unplug and examine the ADC and also need to pull away from wall and remove the cover over the compressor so you can feel the top of compressor. Is it warm, cool or too hot to keep your hand there? Sea Breeze
Sep 19, 2009 | Maytag 22.6 cu. ft. Side-By-Side...
The refrigerator and the freezer is not working properly, the food is thawing in the freezer and the refrigerator is not staying cold. The compessor is running and blowing cool air. It just started...
Possible defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air.Since you've already replaced the motherboard Checkdefrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig and freezer not cooling. Everything is thawing
1/ refrigerant leak or
2/ Defective thermostat / sensor or
3/ Burnt out compressor
Apr 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag plus refrigetor not cooling model msd2756geb
after removing all of the freezer racks and shelf pull the 4 1/4 inch screws out at the bottom back panel of the freezer. pull the 2 panels off and slide them out strait down to the floor of the freezer. if your freezer coils are full of snow and ice then the fan cant pull any cold air up into the refrigerator.your problem is probably th defrost adaptive timer. if the heater ohms out at around 20 to 30 ohms it is ok. next ohm the 2 white wires at the plug this is checking the thermostat it shoud ohm out at aproximately 240 k ohms if those 2 things check out the problem is the adaptive defrost timer it is in the ceiling behind the temperature controls on yhe right side.
Oct 02, 2008 | Refrigerators
Refrigerator and freezer not cooling
you may need to refill the freeon gas charge
May 30, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Maytag S/S model # MSD2756GEB
di you see or hear the fan running fan might be stuck check that out no fan no circulating cold air you may have problem with the heating element what make frost free inside you should melt all the ice inside around the damper check if you see broken glass the little heating element if it not broken and listen for that important fan if it running check it uot thank for using fixya pierre
Feb 05, 2008 | Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
325 people viewed this question
Top Maytag Refrigerators Experts
isaac johny
isaac johny
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
