Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Trying to set up wireless router to satellite phone/internet
I need to set the router but when I conect the network lead to the router I loose signal therefore I cannot alter any details, I have a setup disk with the router but cannot use it as I need to connect laptop to router to modem by cat5 cables but as soon as i do I loose connection to internet, I am just left with local area conection and cannot get back onto VPM
Modem is a Hughesnet HN7740S
  • 3 Answers
I've never worked with a 7740, but i've installed hundreds of hn7000's and hn9000's. the issue is usually that the router and modem are defaulting to the same ip address. if your router supports has a web-based config utility (as most do) try cat-5'ing to the router with your computer while the router is NOT connected to the modem. log into the router and set it's ip address to something OTHER THAN (i use for my customers) reboot the router and reconnect it to the modem. the ip conflict should now be resolved.
Posted on Jul 21, 2009
Cant grt xbox360 wireless adapter conected to wireless router on pc down stairs
I assume the wireless router is configured correctly and the PC can connect to the wireless router and the Internet.
The problem could be that the signal is too weak upstairs for the XBox especially if you have a concrete floor between the XBox and the wireless router. Try moving the wireless router around to increase signal strength to the CBox.
The other problem could be the XBox is not configured correctly.
Follow these instructions to configure the XBox.
  1. In the Xbox Dashboard, go to My Xbox and open System Settings.
  2. Select Network Settings, Configure Network.
  3. On the Basic Settings tab, select your wireless settings.
  4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
  5. If your network has wireless security, enter your WEP or WPA key.
  6. Try to connect to Xbox LIVE again.
Dec 23, 2009 | Microsoft Wireless Network Adapter Xbox...
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
Bad wireless network conection?????
It could be because of a few issues. The signal from the wireless router could be too weak, try moving closer to the source of your wireless access. The wireless adapter could be faulty. There could be something in the area that is interfering with the signal (another device running on a similar frequency).
Mar 24, 2009 | Toshiba Satellite M35X-S109 Notebook
Looks like conected but i cant get internet
Router might not be set up with the modem. Your router broadcast wireless signal when it is powered on, so even if it is not connected to a modem(where you get your internet from)you will have a local connection. That's normal. You need to set up the router. Call linksys technical support, if they cannot help try
Feb 24, 2009 | Linksys Wireless-G Broadband Router
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
I am getting internet signal if I plug in the cord from the wireless router to the laptop. The laptop says we have signal and we are connected to our home network but then we cannot use the internet. It is...
You have set up some kind of security on your router, you have to do the same on your laptop.
Se it as a key that have to fit the lock in order to open the dor.
When you access the router, USE A CABLE, do NOT access the router with a wireless conection.
Vote :-)
Nov 30, 2008 | Microsoft MN-700 Wireless Router (p5308j)
Hallo , I have a Toshiba Satellite L300D-10Q and a Netgear wireless router from Virgin 54 Mbps do i need a card to go into the laptop to get on to the inter net thank you.
Compliancy : Wi-Fi®
Network Support : 802.11b/g
Wireless Technology : Wireless LAN
That is the internal wireless so no you dont you need any thing to set up a wireless connection
You need to set up your wireless network
Or you should have got an ethernet cable with the router usually small yellow, blue or blue. plug this cable into one of the ports on the back of your router then the other end of cable to the ethernet port on side (i think) of laptop anc conect phone line from main box to router. You dont need no software just switch on router wait a couple of minutes till all lights on router turn green and click on your internet explorer done!
Nov 11, 2008 | Toshiba Computers & Internet
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
433 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
