Question about Lenovo ThinkPad R60 with Wireless Wide Area Network (ThinkPad R60_WWAN_Standard_123N)
Charger My Lenovo Charger is working fine, the wire is broken, so i have just joined it via Tape. I am not a technical guys, don't know how to fix it. Lenovo Center suggests to purchase a new 1 rather than repairing...it just needs a repairing. Can anyone pls help
  • Lenovo Master
  • 19,396 Answers
A new charger costs $15/$40 , if you keep using the one sealed with tape you risk to damage the laptop.
Follow the good advice given by the customer support and get a new charger instead.
You can have the charger repaired for $60 or get a new one for $20:
IBM Lenovo Thinkpad R60 R61 90W New AC Power ...$21.95
Posted on Feb 07, 2009
Is the battery cover required for this to work. Mine has broken and I wondered if tape over the back will do.
As a temporary fix, which won't look good but works as a temp:
Cut a piece of thick cardboard, such as the corrugated type from a packaging carton.
Trim one edge perfectly straight.
Place straight edge against inside wall.
Mark width with sharp pencil or pen.
Cut parallel to first cut.
Repeat for length so you have a 'spacer' to press battery down.
Take duct tape, trim end 90' square, start sticking from one side of phone at back, keeping a bit of tension.
Continue to other side of phone.
Cut tape and rub down.
Duct tape comes in different colors, is very strong and sticks like crazy.
Dec 12, 2015 | HP iPAQ H2200 Pocket PC
I have a lenovo laptop computer. It will not charge. it has a shortage in the plug part of the computor or the cord has a shortage. can this be fix and how?
if you can find the short, cut the wire off by an inch on either side, now take wire strippers and strip the wires and join the two similar color wires with electrical tape make sure to do it one by one when your done test it then if all's good tape it up all nice
Feb 01, 2013 | Lenovo 3000 Computers & Internet
I have a technics SU-v500m2 amplifier connected via the aux input to my pc, i wish to link another amp to the same input, is this possible, and if so how?
Let's establish which is the IN and which is the OUT here. The PC is a Line Level source so its OUTPUT would feed one of the amp's Line Level INPUTs.
What's the second amp going to do in your scenario? Something other than the normal stereo channels; something multichannel (if your PC supports it); or just more speakers supported for the PC to feed?
An RCA Y-connector pair would share the stereo output of the PC with multiple Line Level destinations.
If a second amp with its own volume control is intended to share the same two channels with the SU-V500 it could also be slaved off the back of the SU-V500 wih an RCA patch pair exiting the Tape 1 or 2 REC(OUT) jacks. The second amp would receive full-volume audio from whatever source the SU-V500 is playing. Just don't activate the selected Tape monitor on the SU-V500 or you will cut off the source to both amps.
Sep 24, 2011 | Technics SUV500 2-Channel Amplifier
All the speakers including the sub do no have any sound coming off. The only speakers that have sound coming from them are the very last ones in the back seat. How can I fix this?
Check the wiring of the speaker that don't work, it might have been disconnected or the wires are cut.
Look at the wires inside the door panel, which the front speaker is located, the wires leading to it might have disconnected via door panel wire harness inlet. You could see the wires at or near the front door pillar hinges.
If the wire is cut off, strip the wire and join them together, wire color should be connected with the same color. After that insulate them by using electrical/plastic tape.
Your local technician can repair it.
Hope that helps you out.
Thanks for using Fixya!
Jul 10, 2011 | 2006 Nissan Sentra
Targus COMPACT laptop charger isn't working
Your battery sounds like its buggered. I would suggest buying a new battery
May 20, 2010 | Lenovo 3000 G530 Notebook
Bang and Olufsen 1980s Sound System. Broken input jacks for turntable. Broken Tape deck. Local repairers say they can't repair it because no spares
You will have to pay for the labor, if it's just truly broken RCA phono jacks, you can have them replaced by any ham radio guy or electronics guy with a soldering iron. It won't look perfect, but it will work just fine if it's only the jacks and not the switching circuitry. Radio Shack even carries (carried) single RCA chassis mount jacks to fix this.
Nov 10, 2009 | Audio Players & Recorders
My Samsung R40 will not charge. The cable/charger
it is called the AC power Wall Socket is that what u r talking about do u think u can replace it i think u should call some elec guy to fix it like maintenance guy it has nothing to do with ur notebook its just the pins inside the socket got loose and ur plug is unable to stand in there am i right pls vote if u find me helpful
Feb 22, 2009 | Samsung Computers & Internet
Brake lights problem
check the wiring in the boot ...open youer boot look at pass side you will see the wiring loom covered in a plastic case break into this to get to the wires and give the wires a pull my bet you have a few broken wires causing you all sorts of problems re join wires check fuses and cover wires in tape after repair should sort problem out
Feb 01, 2009 | 1996 BMW 318
Macbook pro network connection
Verizon, the ones who sent me the router, helped me fix the problem. The router/modem software has to be updated because the old software can't work with the new version of leopard. The technical support guy did all of the updating via a screen share, so your best bet is to call the company who sent you the router and get their help.
Jul 08, 2008 | Westell Wirespeed VersaLink...
Battery charger wires-Can they be fixed?
If you can clearly identify which wire is which, simply strip off a half inch or so from each broken end, twist together, then solder or simply wrap twist with electrical tape. repeat till all wires are connected then tape into a single bundle. Zaak
Aug 03, 2006 | Toshiba Satellite A45-S250 Notebook
Lenovo ThinkPad R60 with Wireless Wide Area Network (ThinkPad R60_WWAN_Standard_123N) Logo
167 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
