Question about Husqvarna Husky 165
Timing on a Huskylock 535D surger
I need to have the timing adjusted on my Huskylock overlock 535D surger machine. The upper looper broke and I replaced it, now the timing is off and the upper needles are breaking. Help
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
The eyes of the needles must line up with lower looper as they pass (timing) the distance between the needle and the looper must be exact. No distance between them and not touching. yep, that tight. they shouldnt move the needle even the slightest amount as they pass each other, yet no space between them.
Kent
Posted on Mar 19, 2009
Brother overlock 1034d is not chaining. The upper looper is not passing far enough left to catch the left needle. Makes a "crunchy" sounds some times too.
First re-thread the machine starting with the upper looper(3), then lower looper(4), then the needles(2,1). If that doesn't fix it, it may be a matter of loosening the needle tension. Lastly slowly turn the handwheel and see where the loopers cross. The upper looper should come in just behind the scarf of the lower looper without any contact on the forward motion. Otherwise Your needlebar height could be off. Timing a serger is a very precise process and making adjustments could throw it out even further.
Dec 02, 2016 | Brother 1034D Mechanical Sewing Machine
How do you adjust the timing on a serger? I have a White Speedylock 1634.
There are a lot of web sites & videos dealing with timing. Just search for "serger timing" or "overlocker timing."
Jul 28, 2016 | Sewing Machines
Huskylock 535d
You may need to take it for service. However, since it is an older machine, it may be difficult or impossible to repair.
Oct 31, 2017 | Sewing Machines
Adjusting tension on overlocker
overlockers and sergers are annoying in that every time you change materials and threads they must be re-tensioned.
Get a scrap piece of material. Thread your machine correctly according to the instructions in your manual. If no manual most sergers are threaded, upper looper, lower looper then needles from right to left. Make sure you thread with the presser foot UP.
You want to balance the stitches Begin by adjusting the looper dials, you want them to meet right at the cut edge. Then adjust your needles. Keep doing test seams until you have them balanced. If you are a novice... try threading with each thread point having it's own color. That will help you identify which thread is giving you fits.
Have fun.
Oct 15, 2012 | Janome MyLock 634D Mechanical Sewing...
Loopers jamming
Overlockers require precision timing. Take it in and have it cleaned, adjusted and timed.
Sep 06, 2012 | Sewing Machines
Correct threading for 4 th. Juki ind. overlocker
Overlockers and or Sergers are ALWAYS threaded the same way. Upper looper, Lower looper, right needle, left needle. If you have a model number for your Juki we might be able to find you more information.
The best way to figure out tension problems is to thread each thread in a different color so you can determine which thread is giving you problems.
These machines can be frustrating and EVERY time the thread breaks you MUST start the threading problem from the beginning... upper looper, lower looper, right needle left needle.
Aug 31, 2012 | Sewing Machines
Trouble with my Huskylock 680D overlocker Tensions
You need to re-thread the serger.
Refer to the manual or open the front of the serger to see if the threading diagram is there.
With most sergers, you begin with raising the presser foot, then set the tensions to zero.
Begin the threading with the upper looper (curved looper), then the lower looper and the needles last.
Pull the thread under the presser foot and to the left side of the serger.
Set the tensions back to normal 4 - 5 usually.
Lower the presser foot and hold onto the threas tails as you stitch a chain. If the chain of the four threads is ok, you are ready to serge fabric.
Feb 21, 2010 | Husqvarna Sewing Machines
Hi , my husqvarna 936 will not sew a coverstitch although the overlock works perfectly , is this a timing issue with the looper? can i solve the problem myself? if so how do you line up the looper with the...
No brilliant idea how to fix this yourself, sorry Frances - but I would phone the repair shop right away and tell them what has happened. They need to correct this for you free of charge - they returned to you a machine that was not in working order.
Oct 11, 2009 | Husqvarna Huskylock Computerized 936
Sewing Machines Logo
663 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
