Question about Nintendo 64 Console
Is my n64 broken?
Im not sure weather my n64 is broken or not. The power works and and the red light is on BUT the av cable cant conect to the TV. I have tried the same cable on my gamecube and it worked fine. HELP!
  • Anonymous Feb 07, 2009
    so do i help
  • 52 Answers
You might have a dead N64 bro. Alot of quality games on that system too.
You can usually find them on Ebay for fairly cheap
Posted on Feb 11, 2009
  • 291 Answers
Well it might be a power supply issue or and a laser assembly failure then.
Posted on Sep 29, 2011
When turning on my N64, the power light turns on and I have a standard AV cable hooked up, but the video will not come through on the TV.
Step 1:
So you've eliminated the possibility of bad cables. Now you need to eliminate the TV and the Nintendo 64 itself.
Step 2:
For the TV, you can try another TV or make sure that you have the TV set on the right input.
Step 3:
If you can't make it work on an additional TV and you have made absolutely sure that the TV is setup correctly, then you may be looking at a broken Nintendo 64.
Jan 23, 2013 | Nintendo 64 Console
Nintendo 64 has power but does not work
Bring the console in to Gamestop or Rock30 Games and have them hook it up to their setup and see if it works. They buy sell and trade n64 games and will have a n64 system already set up at the store. Just switch your console and cables with theirs until you find out what is not working for you.
Jul 27, 2012 | Nintendo 64 Console
"no signal" with N64 and sanyo tv. I have a sanyo
Well I think that you need a blue plug for it to work instead of
the tradditional N64 av cables.
Oct 09, 2011 | Nintendo 64 Console
My Tv doesn't display the N64 game. No sounds come out also.
What you need to do is, first check the tv av input is working, use a dvd player or any other device with the red, white and yellow plugs.
If it works, the problem may be the nintendo AV cable, they are cheap and worth the few bucks to re live all those nostalgic game moments. If replaceing the AV cable doesnt work, check all the solder joints around the AV socket on the N64 main board. I hope this helps. Good luck.
Aug 07, 2010 | Nintendo 64 Console
Which cables do I need to connect my Nintendo64 to my TV? And where do I put them? The tv is an emerson model: ewl20s5 c
the only cord you need to plug into you tv just to play is the input plug (the one that splits into 3 plugs; one yellow, one white, one red).
you also obviously need to plug the nintendo 64 into the wall for power.
this goes for most, if not all video game systems, as long as your not trying to go on the internet
Nov 23, 2009 | Nintendo 64 Console
N64 AV port loose, does not work
push in harder if does not work blow out socket alternatively, contact nintendo
Jul 14, 2009 | Nintendo 64 Console
N64 turns on but nothing shows up on the TV
I have the same problem and from what I've read elsewhere on the net, it seems to be easily amendable by one of two solutions.
- You can re-tune a channel on your TV (not one of the main ones) and it will find the frequency for your N64 to run on
- If you had a gamecube the yellow, red and white output cables that came with that are (apparently) compatible with both the N64 and SNES and that way you wont have to tune your TV.
Unfortunately for me, I did not have a GC and my TV will not re-tune due to the button on the controller not working! Good luck.
Feb 11, 2009 | Nintendo 64 Console
N 64 does nothing
Well its a power supply failure symptom for this to happen now.
Apr 26, 2008 | Nintendo 64 Console
Broken wires
Sounds like uve got a component hookup, make sure the box has it too...should be labeled component, if not, and u only see yellow, white, and red, then uve only got composite hook up (AV) and u cant hook up all 3 cords to it. If it was working before... It was rigged in a way to make it work, I'd have to kno the brand of the TV, as well as the model that you've provided.
Dec 25, 2007 | Toshiba CX36H60 TV
Nintendo 64 Console Logo
900 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
