Question about Nokia N95 Cellular Phone
Application installer for China nokia n95 8gb mobile phone
I want to connect to Pc Suite to install Symbion or Java Compatible
Applications, like Quickoffice on my China Nokia N95 8Gb Mobile
But I cannot connect with Pc Suite, Is the any other application for this
purpose.
  • eg6_sjk Apr 16, 2009
    my n95 8gb problem :
    -cannot connect with pc
    -my blutooth can receive other device but cannot read the file
    -file manager cannot read n cannot format
  • 3 Answers
Your Nokia N95 8GB might be a fake.
to find this out Remove the back cover and check the battery.
If there are misspelled words or the Battery Number is not BL-6F that is the first clue.
Then Remove the Battery and look for the product sticker.
Look for the following Words
N95-2  Product Code  IMEI  Made in Finland  and look for a barcode.
Refer to the above link to see how a N95's IMEI Sticker Should look like.
If it does not look like that ..... your phone is fake and that is why PC suite will not install the Applications
Posted on Feb 09, 2009
How can i put a themes in my nokia n95 8gb?
Hi
Before installing any software go to
Menu> App.Manager> Options> Settings> Software Installation
In Software Installation make it ALL. This change is important, otherwise you will get an Error message Certificate Error. Contact the application supplier while installing most freeware
Also, if you see that some old themes are giving the Expired Certificate error, simply change the date of your phone to year either 2005 or 2006 or 2007 (check all as each theme has a different expiry) before installing the theme. After installation you can change back to today's date.
Now, here is the way to install themes and other applications in your Nokia . I use the USB Cable to do the installations.
1. First install the Nokia PC Suite software on your computer from the CD which you recieved with your Nokia
2. After Nokia PC Suite is installed in your PC, connect the Nokia to the PC with the USB cable which was provided in the box.
3. When the USB cable is connected, Nokia PC Suite will recognise that a phone is connected. You will then see an option on your phone?s screen asking if you want to connect via PC Suite or Data Transfer. Choose PC Suite.
4. Now, simply download the .sis or .java files (themes & applications) to your computer and Right Click on it with your mouse. You will see an option saying Install With Nokia Application Installer
5. Click Yes on the PC, and then Yes & Continue on the Phone when you see the prompts.
6. The phone will then ask you if you want to Install the Theme or Application in the Phone Memory or Memory Card.
I strongly recommend Installing themes in the Phone Memory! This helps in avoiding complications later on when Uninstalling.
When I first bought the Nokia N95, I made a mistake which a lot of new S60 3rd Edition users make, that is, I installed the Themes in the Memory Card instead of the Phone Memory. This was a huge mistake!
There is a bug in the Operating System of all S60 3rd Edition phones, due to which, if the theme is installed in the Memory Card, it cannot be deleted or removed, as it then does not show up in the Application Manager.
Ever since that mistake, I have made sure to always install themes and softwares in the Phone Memory, instead of the memory card. Yes, it eats up space on the phone, but it's worth it, as then it is easily removed as well.
And that's it, the theme or application is now installed!
Thanks for using Fixya.
Mar 14, 2011 | Nokia N95 Cellular Phone
My nokia 3310c when dowloading applications, after reaching 100% download it shows a message application error.
It means the application installer not compatible with your phone. i.e. the application file is .sisx for Symbian S60v3 which is not compatible with your device. Or the file is broken or outdated.
When you download any application software, make sure its compatible with your phone. Your device can only install JAVA application so you can download application with .jar extension. And choose application with proper size for your screen (128x160 pixels), if its too big, it wouldn't able to be installed too.
Hope this help and if helpful RATE please.
Feb 03, 2011 | Nokia 3110 Cellular Phone
My nokia 3230 having hanging problem..wat is da problem
Might a chance of virus infaction. Please scan your mobile by updated mobile anti-virus. If not done then i suggest you please format the phone & install the updated version. Thanks.
Mar 02, 2010 | Nokia 3230 Cellular Phone
How to install java in mobile
Hi! I don't know mobile configuration, so check your manual regarding java application with respect to compatibility of mobile concerned. if it is compatible with java, then try to load respective java configuration. These can be done by having an insight into service web and also java application service web! and Have fine.
Dec 18, 2009 | Handmark Software MobileLists (950142) for...
I want to install "GO BIBLE" software into LG kc910 renior mobile
My brother does the same thing with his phone. To get it to install you probably need to turn off the certificate check settings!
Go into menu > tools > settings > applications > app.manager
Turn software installation to "all "and online certificate check to "off",
This should allow you to use any app that hasn't been digitally signed.
If you still can't get it to work, it might not be able to work with your phone. But you also might want to call your phone company for the best results.
Mar 19, 2009 | LG KC910 Renoir Cell Phone
Fm application for my mobile
hi,
connect the phone to your pc with nokia PC suite installed in your PC.
then go to install applications and then install your application
thanks you
Feb 08, 2009 | Nokia 7610
SOftware for China N95
SORRY GUYS, china phone does not support java nor .sis application, thats why you can't install any apps to it
Apr 23, 2008 | Nokia N95 Cellular Phone
N95 China mobile Phone
Were can i get the Nokia PC Suite 6.85 for N95? because my N95 china phone can't connect to my pc. the error is MT6227. Can you help me to this problem??? pls reply to me thanks
Dec 16, 2007 | Nokia N95 Cellular Phone
Applications in nokia 6230
Dear friend , No applications will be supported by N6230. Regds Hema.
Sep 22, 2007 | Nokia 6230
Nokia N95 Cellular Phone Logo
906 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
