Question about Canon PIXMA MP160 All-In-One InkJet Printer
Have to clean black ink evrytime I print a page, otherwise black
After cleaning it only prints about 2 pages of black before the ink does not flow. I put in a new cartridge about 2 weeks ago. It was doing the same thing withthe old cartridge.
Remove all the cartridges and pour 2/3 drops of carbon tetra cloride [ctc] on the nozzles leave it for some time and switch on and off twice the printer
Posted on Feb 07, 2009
EPSON SERIES L200 PRINTER DOES NOT PRINT BLACK COLOR
To everybody having issues with black not printing on the L200, I just got off the phone with Epson, and these steps solved it for me:
1.- Open the ink containers (lay flat and open carefully to avoid ink spillage).
2.- Run the Clean maintenance procedure from the Epson control panel
3.- Try printing a page with black features (still with the ink containers open)
3.- If it still won't print, try the Full Clean (it uses more ink, but in my case it was necessary)
4.- Try printing a page again (at this point it worked for me).
5.- Close the ink containers and put back on the side of the printer.
According to the Epson representative, this is the most common cause for printing issues with the L200 because the initial ink load creates a high vacuum and then the ink can't flow.
May 23, 2012 | Canon PIXMA Office Equipment & Supplies
I had fully-refilled the ink into the CISS tank of my printer (CANON IP1980) however, the only colors that went out were magenta and yellow only. no black or cyan. the ink from the CISS tank did flow into...
You could try a head cleaning or a deep cleaning. You can find them in your printer properties under maintenance. After a few cleanings, try a test page. Keep cleaning and trying a test page until it prints like it should. If it never prints black and/or cyan, the print head is either seriously plugged or damaged.
Aug 23, 2011 | Office Equipment & Supplies
I have installed new cartridges the colour prints perfect but the black is blurred with lies through it. i also found a small t shaped rubber piece about about 4mm x 6mm in the paper tray could this be the...
this rubber piece can be actually locket from printer rollers, but, returning to your smudgy printing
1. remove cartridges from the printer
2. check if there is bit of paper stuck anywhere in paper path, if so, remove
3. check if rollers on paper path are clean
4. touch bottom of the cartridge with absorbent tissue to check if ink is flowing through, if yes then insert cartridges back and print test page.
5. if cartridge do not allow inkflow, check what solvent is used (water, isopropyl alcohol or methylated spirit - this which do not cause precipitation is correct solvent), soak absorbent paper (tissue) with proper solvent and whipe head of the cartridge with it, 6. put drop of the solvent on golden knobs inside seats of the cartridges of the printer, allow it to soak in, wipe off with lint free tissue and put another drop of solvent in. allow soak in,
7. install cartridges back, print test page, it should start printing very weak and improving as it goes through the page (solvent will be printed first)
8. create "strip page" one line yellow, white space, one line cyan, white, magenta, white, black - print that page, this print will clean printheads and establish good inkflow.
all ink printers must print at least one page per week as to keep heads free of gum and ink in flow.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Canon MF5750--copies come out with black streak (smear) from top to bottom of pages when printing. Changed cartridge and cleaned window.
run twenty blank pages through the printer by printing just a period (.) on a document. Otherwise the sheet should be blank. This is a way of cleaning the toner or inkjet ink from the printer. By the time the twentyth page is printed, the page should be clean. If not, you may have to get the printer serviced. The canon service number is 1-800-423-2366 option 1.
Jan 28, 2010 | Office Equipment & Supplies
Kodak Easyshare 5300 printer will not print black
Print a self test diagnostic page to check the status of the black ink and print heads.
To print the self-test diagnostic page
Control panel: Press (Configuration Page button), or press and hold the (Cancel button) for 3 seconds.
For models that support networks: Press (Configuration Page button).
If these are all showing OK then clean the printheads
To clean the printheads
If printed characters are incomplete, or dots or lines are missing from printouts, ink nozzles might be clogged and you might need to clean the printheads.
NOTE: Cleaning uses ink, so clean the printheads only when necessary.
The cleaning process takes up to 3.5 minutes. Some noise might be generated in the process.
Control panel: Press and hold (Power button), press (Cancel button) two times, press (Resume button) one time, and release (Power button).
If this fails then replace the black cartridge and run a clean cycle again and then a self test diagnostic then try printing again.
Sep 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I put a new ink cartrige and printer prints low coulour tone.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark Color JetPrinter 5700 InkJet
Changed ink cartrigde and printer no longer printing.
microsoft logo is in colour and so its printing while everything else on test page is black so its not printing. the problem is common.you need to do automatic deep cleaning for the ink flow to start once you install new cartridges.go to printer maintanance option and click the option deep cleaning .it will pull out the ink in printer head and it will start working.sometimes also requires cleaning twice. thanks and do not forget to accept the solution.
Apr 03, 2009 | Canon BubbleJet i560 InkJet Printer
Hp 3550 printer color cartridge printing but black not printing
Perform print head cleaning and also try to take a test page and ensure that ink is properly injected out of nozzle.
If this doesnot work take out the cartridge and clean the contact and reinsert the cartridge .
Jan 30, 2009 | HP DeskJet 3550 InkJet Printer
HP K550 Prints Solid Gray Boxes Around Items
Hi drglass1 -
13,000 copies - that's awesome! although you've surely fixed this problem by now, for future refs or someone else searching for an answer... you might find this ref hp support helpful. happy printing!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00458018&lc=en&dlc=en&cc=us&lang=en&rule=35557&product=501369
Step 4: Clean the printheads
If the print quality is still bad, clean the printheads:
1. Make sure the printer is loaded with unused white paper.
2. Open the printer Toolbox and select the Printer Services tab.
3. Click Clean Printheads . A Clean Printheads window opens. Click Level 1 Clean .
4. Examine the page that prints for print defects.
a. If there are no defects, click Exit . Stop troubleshooting here .
b. If there are defects on the page, click Level 2 Clean . 5. Examine the page that prints for print defects.
b. If there are defects on the page, click Level 3 Clean . Note that Level 3 cleaning uses a lot of ink – it is not recommended if the cartridges are low on ink. - JW50
Sep 17, 2008 | HP OfficeJet Pro k550 Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
