Question about Hitachi 60V500 60" Rear Projection HDTV-Ready Television
Replacing the light lamp for the 60V500
How do I replace the light lamp for the 60V500?
  • rbonilla Mar 22, 2009
    I just install a brand new UX21517 Lamp Replacement in to myHitachi 60V500 60 in. Rear Projection HDTV-Ready Television and itdidn't work.
    I took it a part again and repeated the processone at a time three times and the TV turns on, it blinks several timesand then turns into the blinking red light and eventually it turns off.
    I hear a little repeated squike noise like a very soft and and then it turns off again, what can it be, can you help?.
    Thanks
    Scholar:
  • 150 Answers
Hi, pull off the plastic cover just below the bottom of the screen, remove the phillips screw from the lamp door cover then the screws from the lamp housing and pull straight out, do not touch the glass portion of the lamp with your fingers, the oil from your skin will shorten the life of the lamp,
when installing new lamp push into tunnel just far enough that it touches end of tunnel then snug with screws. DO NOT push in hard on lamp, re-install lamp door and front plastic cover and enjoy,
good luck, video tek
Posted on Feb 07, 2009
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    I am replacing a lamp in my tv that went out.I ordered the lamp and now I cannot get it to work. Can you help me?
    Tv turn on now?The tv now having alot of clicking sounds too?Yes,the board that call the Ballast board it is also dead.This Ballast board only job are to ignite the tv projection lamp.Must replace the Ballast board too.
    Mar 14, 2011 | Hitachi 60V500 60" Rear Projection...
    Want to install new lamp in hitachi 60v500. Need to know how
    Lamp replacement procedure in Hitachi 60v500 is written in its user manual in details and its easy.
    Click HERE to download user manual free copy, if you need it.
    Jun 28, 2010 | Televison & Video
    Tv won't come on.
    Ur tv lamp require replacement.The current projection lamp in ur tv,life span is over.
    May 19, 2010 | Hitachi 60V500 60" Rear Projection...
    THE LAMP LIGHT STAYED ON...WHEN THE TV IS OFF....WHEN I TURNED TV ON THERE IS NOTHIN THAT HAPPENS
    well normally the first thing to do is to check the lamp, if you already have replaced it. You might just need to re-set your lamp timer. take it back to 0.
    Apr 14, 2010 | Hitachi 60V500 60" Rear Projection...
    Tv not turning on
    Ur tv,projection lamp been use alot about 2 years or more?The lamp must replaced the lamp life span it over.
    Apr 05, 2010 | Hitachi 60V500 60" Rear Projection...
    Red circle and yellow tint in our white
    If you have RED color that starts from Center of the Screen,(no red color on sides ) 100 % your light engine is deffective..
    In order to solve this issue Replace Light Engine Control Board (also called Driver Board ) attached to light engine.
    Good Luck
    Do not forget to Rate!!
    Dals123
    Jan 03, 2009 | Hitachi 60V500 60" Rear Projection...
    My 60" lcd projection tv wont turn on sometimes and throws a lamp light, and if i watch tv for a while and turn it off it wont turn back on and throws the red lamp light
    The buzzing sound you most likely hear is the ballast trying to fire up the lamp. I would say replace the lamp and yes they can act up at will. If this is the first lamp replacement ever then you are doing good.
    Feb 01, 2007 | Hitachi 60V500 60" Rear Projection...
    Hitachi 60V500 60" Rear Projection HDTV-Ready Television Logo
    240 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
