Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Bosch wff 1401 faulty programmer?
It will only fill on no:10 if you select another setting after it has filled it's fine, drains, spins, the lot. Any ideas gratefully received.
5 Suggested Answers
textonor
  • 130 Answers
SOURCE: Bosch washing machine
With no clothes in the washer start a program. The washe level is below the door glass. the rinse level comes up 3 cm on the glass. The washer is designed to be water efficent. If you are not getting water this high, look at the pressure switch hose, maybe it is restricted and causing the pressure to be held in the washer.
Posted on Jan 23, 2008
SOURCE: bosch classixx 1200 express
Not a programme error but carbon brushes on motor.Fixed by local engineer.
Posted on Aug 31, 2008
SOURCE: I have a Bosch WFF 1401. I removed the drawer as I
There can be 2 reasons. The centre section dispenses the fabric softener in the last rinse. It works on a syphon effect.
If it is not assembled correctly the water flows over the side to avoid a flood and leaves the middle section full at the end. Make sure the inner pipe is inside the outer pipe and that both are completely clear of softener residue. As you have just reassembled it this is the most likely cause.
The second reason is the water inlet can become blocked therefore not creating sufficient flow to create a syphon effect. It gets blocked with black gunk and needs to be cleaned with pipe cleaners or a long cable tie. There are 4 rectangular holes above the centre section, near the front. They can be seen easily if you take the drawer out.
Hope this helps
Nick
Posted on Jul 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: bosch axxis washer fills door locks then nothing
The timer/controller is faulty.
Replacement is the only fix.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2009
FitzOriginal
  • 842 Answers
SOURCE: WFF 1401. The drum is not turning during wash or
99% probability that the drive belt has come off. Can you hear the motor whizzing when it should be turning the drum, but the drum doesn't move? If so then it will certainly be the belt off.... If you can't hear the motor then the motor its self may be shot. Most machines allow you to remove the back. If the belt IS off, then fit it to the MOTOR first, then slip it over the edge of the large wheel on the back of the drum and turn the wheel by hand to ease the belt back onto the wheel.
Now the question: Why did it come off? Your happiest hope is that you had a very heavy and uneven load in when it came off and that the load shook the machine so violently that it caused the belt to come off. This is good, don't overload the machine and it won't happen again. If this isn't the case, and it happens again, hope the belt is worn out and stretched (Hate to say it, but this is quite unlikely. Take it to the place where you can buy a new belt, measure your belt against a new one to find out). LAstly, sadly most likely and most expensive is the possibility that the belt came off because the rear bearing in the drum is worn out and allowed the drum to run out of line so the belt fell off. To test for this, open the front loading door of the machine and slip your fingers onto the drum while your thumb rests on the outer casing of the machine. Lift and squeeze the drum with your fingers, pulling it towards your thumb. The drum should rock back and forth on its springs, this is normal. If you hear a little clunk and you can see the inner drum moving while the outer drum (where the rubber gasket is fixed to the drum) stays stationary in relation to the inner drum moving up and down, you probably have a shot rear bearing. For most machines, this fault is not an ameture fix and its time to call in the repair man. Be prepared for the news that (more than 50% of the time) this problem is more expensive to fix that the machine is worth if it is getting on in years. If this is the case, weigh up the cost of the repair to an old out of warranty machine, against putting the cash toward a new machine that will give you the peace of mind of a warranty if thisgs go wrong
Posted on Oct 09, 2009
How to replace timer bosch wff 1401
Is there a code that pops up on your panel and if so what is the code?
More than likely it's in your panel but, it should pop a code.
Aug 27, 2014 | Bosch Washing Machines
I have a bosch clasixx 1400 washing machine and it is not spinning but is going through all the programmes and i have also changeed the carbon brushers, what is wrong?
Make sure the filter is clean, this is located at the bottom front right of washer, unscrew anti-clockwise to remove and clean.
Mar 09, 2010 | Washing Machines
Bosch wff 1401 not emptying water therfor not able to spin the pump goes round but water does not empty if i drain the water the machine will spin
If you have not already done so, then check and clean filter located at bottom front right of washer behind drop down cover.
If it still does not empty, then it is either blocked between the pump and tge waste outlet, or the pump itself could be faulty.
Jan 25, 2010 | Bosch Washing Machines
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Bosch classixx 1200 express
Aug 30, 2008 | Bosch Classixx WFC 2465 Front Load Washer
IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Mar 24, 2008 | Maytag Performa PAV2200
Jan 19, 2008 | Washing Machines
Washing machine - Bosch WFF 1401 - spinning problem
Bosch WFF 1401 This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Dec 29, 2007 | Washing Machines
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
151 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
