Question about Hotpoint RFA80 Bottom Freezer Refrigerator
Fridge freezer not working Hotpoint RFA17
It just quit cooling anything....sounds like water running inside....
  • angie3005 May 11, 2010
    is this expensive to fix....i'm gutted as it has only just passed its waranty
  • Anonymous Mar 26, 2014
    thermostat
    President:
  • 1,902 Answers
It is one of two things. Either your compressor went bad or the relay that connects to the compressor is bad. Those are the only two reason why it would not cool at all. You can try to unplug it and plug is back and and see what happens it might shock it back
Posted on Feb 07, 2009
I have a 1995 geo metro that quit on me. Something popped then the engine quit. It won't crank now. I have water coming out of the overflow.put water back in it but when I tried to crank it without th
Your assumption would be probable! Sounds like the cooling system is being pressurised from the engine which is normally caused by blown head gasket! Is the water mixing with the oil?
Nov 01, 2014 | 1995 Geo Metro
My suzuki 2005 s83 boulevard oil looks like chocolate milk.Bike has only 8000 miles.Rode and checked oil the other day was fine.I only rode 1 mile, not that hard.Checked oil today...looks bad
Sounds like water / oil emulsification. Is your bike water cooled or air cooled? If it's water cooled then you may have a gasket leak. If it's air cooled then you may not be riding the bike enough to get a good temp up inside the engine which would drive off the condensation inside the crank case / sump thereby leading to the emulsification. You say you rode an easy mile - certainly that's not enough to get the temp up enough to drive off the water. Was the bike running ok? Was it accelerating and braking ok? If so then try a cautious longer run and keep an eye on your levels. If in doubt consult a bike shop.
Jul 13, 2014 | Motorcycles
I have a Frigidaire GSI 26, ffor the last couple of days it has been making a buzzing sound that lasts about thirty seconds to a minute, today the freezer quit working. the compressor is hot, as is th
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Duo Therm dripping water in camper when shut off. My Dometic Duo Therm Ducted AC drips quite a bit of water when shut off after running for several hours on hot humid days. The condensate lines are open....
Remove the filter at ceiling and run the AC on cool etc, and see if you can feel cool air leaking across to return air inlet where the divider between cold and return is. Check along all edges, etc for any cool air . Careful of wiring, but you should be able to get hand in there and feel especially around the edges where it should be sealed tight. Quite often a leak in that area causes cold air to enter return air and causes excessive condensation. Another thing to check is look way up inside opening for return air, with a flashlight and see if any dirt/dust on coils and fins of evaporator, and if so, needs to be cleaned off with a vacuum, and brush attachment. Let me know what you find.
Jul 10, 2010 | Dometic Rooftop RV Air Conditioner
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Cold water never quits trying to cool water. runs
Hello, this is going to be a bad thermostat. This is located behind the grill in the back. It has 2 electrical wires and a metal wire that goes to the tank, you should replace it. Hope this helps! Mike
Oct 30, 2009 | Hamilton Beach Water Cooler with Storage...
Water trinkling sound
This is normal sound, it is just a condensation buildup inside the machine that is dripping into drip pin than drips outside.
Aug 01, 2009 | Haier ESA306 Air Conditioner
Silent pc
Really depends on your price-range, and to what extent you are looking for "results", to simply make your PC a 'silent', a less expensive one, (ave.$80USD), should work, such as many "COOLMASTER" ones, I have one of these #201(?), and it has the 5"1/4" drivebay LCD panel, works quite well, keeps my Prescott (read "pres-HOT":) (3.0GHZ), down around 70o (versus ave. of about 120o, that ran for about $90 a year ago.
On the other hand, you could Never go wrong with a 'full-blown' "KOOLANCE" system/case. . such as "external water pump & container", although, these range in the 100'sUSD, many time $500+. .
Either way, Water Cooling, IMHO, is the best. .
Keep in mind that a lot of PC's 'noise' actually comes from the Hardrives, although, depending upon your case/setup, this may or may not bother you.
Also, a Good "Sound Dampening" case, or even just the "sound dampening "harddrive covers" work well.. try a Google search for MANY reviews, and product info; simply use;
"water cooling cpu", is a great start.
Let me know if there is anything else about these that you may be wondering, I have had mine running "practically" 95% of the time over an entire 2 years, only requiring a "refill" of coolant about* every 6 months or so. . Evaporation is slightly due to the extreme heat in the room in which my PC is located also tho.
You may also find many opinions on using TEC (Thermal Electric Cooling" devices, enabling you to actually Drop the CPU's to Sub-Zero temps.. but that is usually only preferred tby the 'extreme' Overclockers'. .at any rate.. Good Luck!
Dec 17, 2007 | Thermaltake Liquid Cooling System Water...
Hotpoint RFA80 Bottom Freezer Refrigerator Logo
331 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
