Fan stays on for hours. It is extremely loud. New issue.
SOURCE: GE Profile JTP56 Electric Double Oven: Turn on Fan?
Fan is automatically controled by a thermostat.
Please don't bother rating, as anything but a Fix-Ya lowers my scorel. Thanks.
SOURCE: Breaker sizw
In most cases look on the model number tag, the one with the serial number on it and in most cases it will tell you what amperage breaker you should run it off of. It could be a 30 amp 40 amp or 50 amp 220 breaker.
SOURCE: COOLING FAN DOES NOT STOP AFTER HOURS
Hi I am Vortash the cooling fan must be controlled by a thermostat , it appears that it has a problem on it and is not shutting off .
They are usually normally open contact switches that are on the top or the side of the oven ,they heat up close the connection and turn the fan on . yours sounds as if it is sticking . Other ovens are controlled by a rheostat a long tubed thermostat that goes to a main control consul on the oven , it controls the fan and responds to what the stat tells it .
It may be this controller is not turning the fan off afterwards , my suggestion is that unless you are electrically trained you get the help of a service engineer to check your oven out .... regards Vortash
SOURCE: fan noise
It is a cooling fan, and, yes it can be replaced.
Please rate my solution.
Thanks.
SOURCE: GE Profile JKP54GOT1BB Oven won't stay on - starts
This is a common failure mode that we repair on these controllers. Here is a link to a short article that may be related to your situation.
www.fixyourboard.com/techzone/ovens/f1_error/f1_error.html
Best Regards,
Bruce
