Question about Acer Computers & Internet
How do i reset the cable from motherboard to monitor on my laptop
I saw on yahoo that this may fix my black screen problem where i hear my computer running but only get a black scrren. i hooked laptop to tv and still just black screen. If itmakes a diference a have an everex computer..
  • 1 more comment
  • Kevin bed Feb 08, 2009
    can you give me basic instructions on how to do that?
    The computer will not start in safe mode as the screen is all black to even try to change the mode its starting in. The laptop is a year and a half old. I hooked the the computer up to my tv and the screen is still al black, so if it was just the screen i should have been ok when it was hooked to the tv
  • DEKR
    DEKR May 11, 2010
    PLEASE GIVE ME MORE INFORMATION
  • 13 Answers
I fixed this problem just days ago. My problem was with the drivers. And I used another computer and network to help out.
Start the laptop.
Hold windows key and press 'u'. (this will start windows narrator)
Plug in some earphones so you can hear what he is saying.
hit windows key to open start menu.
'p'
right arrow
find 'accessories'
'system tools'
'system restore'
check the 'restore my computer to an earlier time'
then next
tab until he starts saying a very long number (this is the calender)
click left a few times then onto the next page. This will restore windows and any drivers you may have screwed around with. Getting the date right is a bit of guesswork.
If you want more precise you can connect the laptop to a network and install a remote PC program (i use Radmin Viewer/Server - free download from www.download.com) this way you'll be able to see the laptops display on the other PC.
Posted on Apr 07, 2009
    Genius:
  • Acer Master
  • 1,102 Answers
Have you tried getting on in safemode
how old is the laptop
if you hear it running but the screen is black your screen is probably gone
Posted on Feb 08, 2009
  • DEKR
    DEKR Feb 08, 2009
    if laptop is old probably screen
    or video
    have you added new memory or updated os
    i need more info
    Problem Solver:
  • 4 Answers
Maybe your video card is not working try to change your video card if its working so it means your video card doesn't work. if its built-in video card try to check some cables from motherboard! thanks...
My screen is black
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Jan 20, 2013 | HP Compaq Presario CQ50-210US Notebook
Screen wont come on, on my Toshiba laptop computer
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps.
Jan 15, 2013 | Toshiba Computers & Internet
HP laptop screen is black
Jan 08, 2013 | HP VM114UA notebook
No LCD Display on Dell Vostro 1700 - 17"
It sounds like you have been pretty thorough trying to resolve the lcd problem
Dec 13, 2012 | Dell Vostro 1700 Notebook
Acer laptop switched on light up on switch but no screen display
A blacked-out screen doesn't necessarily indicate a broken monitor. If the computer has run out of charge or is in hibernation or sleep mode,
Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases. Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop. Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Wedge the edge of the keyboard bezel off of the top cover. Work your way along the edge of the keyboard bezel to loosen it. Pull the bezel off the laptop.
hope this helps
Hope this helps
Nov 24, 2012 | MSI P45 Neo3-FR (MS-7514-010) Motherboard
What should i do to boot my hp mini 2133
Does it seem like it booted all the way except the screen is black? Do you hear fans running, the hard drive spinning?
What is a hard reset? Exactly what did you do?
Apr 25, 2012 | HP 2133-1 Mini-Note PC
HP Pavillion Entertainment computer (laptop)
now u put out to another monitor by cable if u see screen in there ur lcd have problem, if black too it from ur motherboard , checking
Jan 14, 2010 | Computers & Internet
Screen remains black while computer is running. in other words, the screen isn't responding or lighting up when i turn on the computer, but i can hear the computer running, so i know it's operating.
check the cable between the pc and monitor. if you have a video card with 2 connectors make sure the cable is in the right spot.
check with another monitor or check the monitor with a laptop to see if the monitor is dead
make sure the monitor is on ac power and powered on (it happened so don't laugh)
Aug 19, 2009 | Computers & Internet
Vostro 1000 black screen an i can hear it running, but can see..
A blank screen with evidence that the motherboard is working (the Capital "A" green light is probably the CAPS LOCK on your computer's keyboard) initially points to an output or video problem. One quick way to see if that is the case is if you connect the computer to an alternate screen. Do so with the "sick" computer powered off at first. After being sure the connections are snug, be sure that the test monitor is powered on and then turn on your "sick" Dell. If the test monitor runs as your laptop's monitor ran when it was healthy then you know there is a cabling/backlight/inverter/screen problem. Some of these can be solved very easily, some more expensively as replacement may be required.
On some laptops pressing down firmly on the keyboard may seat a screen cable to motherboard connection. That often works on IBM Thinkpads with screens that fade in and out due to a poorly seated screen cable connection to the motherboard.
So let's see how the test to a known working screen goes.
Apr 18, 2009 | Dell Vostro 1000 Notebook
My wifes Acer monitor suddenly went black
When you turn on the monitor, and if you see the power light blink i really doubt that the monitor is at fault. If it failed at all, it would likely fail completely.
Sorry to be bearer of bad news, However, there is no shortcut to reset the monitor.If you open the monitor you would find nothing than a circuit board with long string of capacitors and diodes.
However, before we jump to the conclusion that, monitor is at fault.There might be 2 more reasons.I have seen in the past that sometimes, motherboard fails while you are working on PC and sometimes Window Crash.
Lets work bacwards.
Restart PC. Press f8. If you did'nt get any screen, more likely either motherboard is corrupted or monitor is at fault.
If you do see screen, might be settings, any other colour, Load Windows again as your windows might have crashed.
Motherboard - I have seen many people throwing their monitors thinking that it's their monitor who is at fault. However, in the end its motherboard.
Try to attach your monitor with some other CPU.If that works, motherboard is corrupted.You need to repair or replace that.
Unless. Monitor.
If you honestly ask me its much better to purchase new monitor.If you want to repair that, it might cost you some bucks And once repaired, the issue would always be there ( Though not for some time ).
If you still want to fix that, tell me the model number, so that we can work together to fix that.
Thanks for using Fixya.
Mar 25, 2009 | Acer AL1913b 19 in. Flat Panel LCD Monitor
Computers & Internet Logo
294 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
