Question about Bosch 24 in. SGS56E02 Exxcel Built-in Dishwasher
Bosch Exxcel Auto Option won't go into drying cycle..
We've had our Bosch SGS56E02 for a couple of years, and it's worked very well up to now.
Over the past week, though, it's run through a cycle perfectly adequately until it's time for the drying phase.
What's happening is that it finishes the 'Rinse' and then whirrs away, with the 'Rinse' light on when it should be drying.
It seems to be draining OK during the course of the main wash, and the dishes are actually being cleaned (which is a relief!)
Having surfed around to find out what might have caused this, we've cleared out the filters and made sure there are no blockages. I've also had the front off, and looked at the main board to see if there are any obviously burned out bits (it's a 356001806, by the way).
I've checked the waste outlet - no obvious blockages.
So.. I guess the question is: has the drying circuit blown up, or has the electronic control system thing gone wonky, or is there something else a bit wrong? Hope someone can help :)
  • Anonymous Mar 31, 2009
    I have the same problem. It either finishes rinsing or won't dry or stops before the final rinse. The timer normally show 1 minute or a couple of minutes left and just keeps on going.
silly girl
  • 513 Answers
SOURCE: Bosch Dishwaher shy56a
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Posted on Mar 26, 2006
  • 25 Answers
SOURCE: Bosch Exxcel Auto Option/Detergent tablet does not dissolve?
It seem that your DW drain it's water by syphon action. Check if the drain hose is properly installed as a U shape; otherwise the DW can drain itself at any time, leaving the soap undissolved .
Posted on Nov 16, 2007
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
ginko
  • 19396 Answers
SOURCE: my bosch exxcel dishwasher will not drain after wash cycle
That is because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Posted on Feb 07, 2009
SOURCE: My Bosch Dishwasher doesn't clean
my dishes smell like wet dog? what could be the problem?
Posted on Jun 16, 2009
Does the Bosch Exxcel 7 1200 Express have a child lock function?
try the manufactures website for free manual download
Dec 08, 2013 | Bosch Washing Machines
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Oct 20, 2012 | Bosch Washing Machines
The machine does not heat up
Bosch dishwashers do not have a heated dry option, the water is heated with a inline water heater but it does not have a heating element to dry the dishes. Make sure that you use jet dry and that you open the door when it is done, after an hour or so the dishes will be dry. This is a common issue with the Bosch dishwasher, but not a problem with the unit
Jan 05, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Planning to start re-using a Bosch Excell Auto that has not been used for 2 years. Any tips before getting started?
Put some towels down infront of it!! When these sit for a long time with no use then seals dry out and they leak often. If no leaks run 2 cups of white vinagar to clean out build up
Nov 09, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
I have a Bosch Exxcel 1400 S Express which blew
There is no internal fuse in the washer to replace.
If you have replaced the fuse, make sure that is is a good one.
If you are satisfied that you have power to the washer, then I'm afraid it sounds quite serious.
Trust this helps.
Dec 04, 2009 | Bosch Washing Machines
Bosch dishwasher model: SGS56E02 will not complete a cycle.
Hi, The dishwasher must get to 70c to advance thru the heating cycle.. check to see if the heater is coming on( lots of steam coming out when you open the door )..not getting hot then you could have a heater problem. if you are getting hot then you have a Thermo ... the thermo holds the the dishwasher until the temp reaches 70c before it will let it go into the next cycle...the thermo is under the dishwasher at the right side, white with two wires .. it screws into the tub...hope it helps it not let me know and I can help you more...
Sep 27, 2009 | Bosch Dishwashers
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is sironsheik@hotmail.com
Apr 01, 2009 | Bosch Exxcel WFX 145S Front Load Washer
Nov 16, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Open Questions:
Bosch 24 in. SGS56E02 Exxcel Built-in Dishwasher Logo
198 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
