Question about Bernina Virtuosa 150
Knee pedal does not work
When i try to use knee pedal ,all it does it lifts the hook.
You must be talking about the free hand system that does exactly what the other guy just said: it lifts the presser foot so you can maneuver your fabric with both hands. You still need to plug in your foot controller for the floor.
Posted on Feb 24, 2009
  • 202 Answers
I think what you mean is that it lifts the foot. That is what its supposed to do. Some of the older ones it could be used for a speed control (30-40 years ago).The knee BAR is there to lift the foot for you so you can turn fabric etc. without having to reach behind and lift it. It acts as a third hand. You must have a foot control which plugs into the small hole on the right side of the machine.
Hope I helped.
Posted on Feb 11, 2009
Can I use a knee lift with my Janome DXL603
In the Specifications section, this indicates a knee lift is not available:
Janome DXL 603 sewing machine computerised 60 pre programmed stitches...
For a knee lift, there would need to be an access hole at the lower right front to install a knee lift. Looks like there is not one on this machine.
Mar 01, 2017 | Janome Sewing Machines
My riccar 555su machine starts sewing as soon as I plug in. Foot pedal is stationed inside cabinet by knee, but I'm not controlling it.
The pedal is stuck in the ON position. Unplug the sewing machine and try to open up the pedal to inspect it. Or try pressing the pedal a few time to loosen up the pedal movement. Good luck!.
Oct 24, 2016 | Riccar Sewing Machines
How do I tilt my machine back to access the oil pan? The knee lifter bar is in the way and hit when I try to tilt my machine.
I don't know if you were the person that I was just writing to or not. I didn't think about the knee lift. I generally sew on a Juki DDL-5800 and we don't have the knee lift problem. I have an older walking foot with the knee lift. You might try what works with that one. Grab the front of the knee lift, push it towards the back and at the same time pull it up and left. There is a metal peg at the back of the shaft that will release and let you pull the knee lift out so that you can push the machine back. If that doesn't work, see if you can contact me and I can call someone else to find out.
Shirley :)
Mar 20, 2016 | Juki DNU-1541S Industrial Walking Foot...
Problem with knee lift
are you sure it is in all the way and it is far enough away from your table so it is not catching on anything ?hope this helps
Oct 16, 2014 | Janome Memory Craft 9000 Computerized...
Juki ddl 555 knee lifter is not lifting the foot. How can I fix it?
I imagine that it is the mechanical knee lift that you actually lift with your knee? Sometimes the screw that holds the knee lift rod comes loose a little and starts to slide in the holder. Sit on the floor where you can see the underneath of your table and use a wrench or vise grip to loosen the bracket that holds your knee lift bar with the pad on it. Move the bar to the left and retighten the screw and I think you will be ok. Sometimes if there is too much oil in your pan or you have moved the machine and some of the oil spilled out, a little oil gets out of the pan onto the bar and makes it start to slip. If that doesn't work we'll try something else.
Jun 13, 2014 | Juki MO-644D Mechanical Sewing Machine
How can I fix the knee lift that is very hard to push
how much srping tension do u have on presser ft. is the tension knob on top of machine screwed all the way down., never necessary by the way. next your arm attached to the knee lifter may be bent and not contacting the lifter bar for presser ft. get under machine and move knee lift with hand to see where contact is being made. bend accordingly. also the link from knee lift bar to link inside the back of the machine may be broken. u have to take off the back panel with all its screws. watch the gasket. you can replace the bar yourself since this will not intefer with the machine timing etc.
Jun 13, 2014 | Juki Sewing Machines
Pressure foot will not lift up
do u have an automatic machine meaning ft is lifted by pressing ft pedal a certain dirtection. otherwise tilt machine and push knee lever. there should be a flat oval piece on top of lever rod. does it rise straight? it needs to contact the push rod on the machine presser ft. see if the line up by lowering the machine slightly. if not bend rod to aglin. your knee lift may need adjustment too and maybe the presser ft screw located by removing the rubber plug on side of machine or take off the plate by removing 3 screws. careful with gasket cause machine will leak if u tear gasket.. presser ft screw is easy to find. lower ft and tighten. make sure that the needle is centered in foot slot when adjusting presser ft screw. otherwise thread will break when needle hits side of presser ft. a very common problem that many do know about and someday i will charge the site. 35 years with juki and still going strong.
Apr 22, 2014 | Juki DDL-8700
I have a juki DDL-8700, I've recently been having problems with it. When I use the knee lift for the pressure foot, the tension does not go back to normal. The machine could be work fine the when I use the...
Check the tension unit, when you use your knee press a pin should open the tension discs then return to normal, check for any fluff in the discs as well
Oct 15, 2013 | Juki DDL-8700
I got a 1950 sewing machine set in a table with a knee control for the pedal. The light comes on, but I am not sure how to make the knee pedal work. There is a lever and I have moved it, but nothing...
Have you tried getting a copy of the owners manual? You can usually download one for $10 at www.sewingmanuals.com or go through Sears. I remember having a machine with a knee control and it seems to me that you only had to pick your stitch length and press the knee control to make it sew. Mine was a straight stitch only Singer. Do some research online with your model number, google it and see what you find. Good luck
Nov 10, 2010 | Kenmore Sewing Machines
Sewing Machines Logo
170 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
