Toshiba 32HL95 32 in. LCD TV/HD Combo Logo
Posted on Feb 07, 2009
Hooking up xbox 360 to tv
How do i hook up my xbox 360 to my toshiba tv?
thank you
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1111
Points
8
Put it on hd. the big plugin that say tv or hvd
I recently got a 51h83 toshiba tv. When i try to hook up my xbox 360 with the hd component cables in the back i get sound but no video. Please help.
WITH THE TOSHIBA 51H83TOSHIBA TV YOU CANT HOOK UP HD CABLES TO THAT SPECIFIC TV FROM YOUR XBOX 360 BECAUSE THE DEVICE ISNT EQUIPPED WITH THAT CAPABILITY
How do I hook up Xbox 360 to this TV? I have no clue where all the plugs go in the back
component leads from xbox to component in on tv
Xbox 360 Component HD AV Cable
http://support.xbox.com/en-AU/xbox-360/system/connect-xbox-360-console-tv
https://www.youtube.com/watch?v=JlE2zHSoQmE
Xbox 360
Match the colors of the cables with the cords and connect...
How should I hook up my xbox to the back of the television using the red, white, and yellow wires? It is hooked up but I am not getting any audio. Thank you.
First make sure your video cable is set to TV not HDTV
Then plug the 3 RCA cables into the color coded slots on the TV. Make sure you aren't using the red cable from the component RGB but are using the red cable for sound (next to the white one).
Then, if you still have no picture, start the console using the controllers Xbox button and hold "Y" and "RT" until the console restarts. this will reset the video settings on the 360 to default.
Follow this guide if you get confused:
http://support.xbox.com/en-us/pages/xbox-360/how-to/audio-video-devices/connect-xbox-360-console-tv.aspx
and for the video reset about halfway down the page:
http://support.xbox.com/en-us/Pages/xbox-360/troubleshoot/xbox-360-top-issues/tv-or-monitor-screen-is-blank-while-connected.aspx
1helpful
Xbox 360 is making audio but no video is hooked up to tv that worked just fine with reg. xbox?
are you sure that the yellow cord in hooked up into the yellow socket in your tv? it has yellow red and white all beside eachother!
2helpful
Audio set up to xbox 360
There would be a RED,YELLOW,WHITE input cables that you would hook up to the back, there should be a Video mode on you remote turn it to one of the input channels and you should be fine.. Thanks and please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Xbox360 hd hookup problem---1080i
Your component cable is probably switched to the HD setting. You have to switch it back in order to get video when hooked up to a regular TV.
1helpful
Sound but no picture
On some av cables for the Xbox 360 there is a switch on the cable itself where it plugs into the Xbox that must be in the correct position. I hope this helps you.
1helpful
No color on tv when xbox on
Try hooking the xbox up to another tv to see if you get color. If you do it isn't your xbox. If you dont then it's your video cables going bad. Hook a dvd player into the same spot you had the 360 in on your LCD see if you get color. If you dont then its your TV, if you do then it's your xbox video cables going bad.
No picture using component on Toshiba 32HL66
It may be a synch issue. Make sure your component input is set for the proper type of output. Your XBOX 360 is likely set to 1080i, but your DVD and PS2 are only 480i (or maybe 480p for the DVD if progressive scan). Sometimes component inputs are 'self adjusting' to the signal, but others require manual setting.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
