Question about Hamilton Beach BrewStation 47214 Coffee Maker
I have Brew Station 47665. My coffee tank leaks.
I believe it has something to do with the O ring on the bottom of it. It is a slow drip, but I left some coffee in it the other day and it leaked all over my counter and floor. Can I order a new tank or just new ring and metal plate?
  • trader923 Feb 23, 2009
    I have the same problem. I suspected the gasket that surrounds the hot plate in the coffee tank, but then I removed the hot plate from the tank and found hairline cracks that extend to the hot plate from the screw holes. Tried gluing them (superglue), and it fixed it for a couple of days, and is now leaking again. Going to try some cvpc cement. Best to replace the tank, but good luck getting hold of them
  • Hwizzer Mar 12, 2009
    I need to purchase a 3" + seal for the for bottom of the coffee bowl. Have the very same problem on two different units.
Contact 1800-815-8900 give model no. &serial no. under brewmaker bottom they have replacement part & info
47214 brewstation
Posted on Feb 27, 2009
  • Doug Hogan
    Doug Hogan Jul 23, 2012
    the 800 number is out of order....
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
Hamilton beach brewstation will not brew
Can you define will not brew? Do you mean no water transfers from the holding tank to the brew carafe? Does coffee not heat up?
Apr 11, 2013 | Hamilton Beach BrewStation 47665
How do I change a filter?
Your Use and Care Manual can be found here:
http://useandcares.hamiltonbeach.com/files/840156002.pdf
See illustrated instructions on page 7 for how to change the water filter.
Mar 08, 2011 | Hamilton Beach BrewStation 47665
We are trying to set up the hamiliton beach brew station 6 cup but do not have the manual. can you walk me threw it please?
Sure Thing :)
1) Open the lid
2) Take out the filter basket.
3) Take out the Coffee Tank and fill it with water to the appropriate mark at the back of it. (Should be a stepped type marker)
4) Pour the water from the Coffee Tank into the Water Reservoir in the coffee maker it's self. (This should be on the left side of the metal warming plate.
5) Place the Coffee Tank back on the brew station.
6) Place the Filter Basket back in the coffee maker
7) Add a coffee Filter and 5 Tablespoons of coffee
8) Close the lid
9) Press the Brew/Start button (The top left one)
Jan 08, 2011 | Hamilton Beach Microwave Ovens
Dispenser not working
You don't say exactly what the problem is with your Brew Station but I know I bought the model 47214 and had to return it twice. It kept stopping and starting numerous times during the brew cycle. I retuned both to Walmart and they exchanged them with no receipt and no charge each time. I think I had 60 or 90 days to excahnge them. Anyway, the last one I took back was at the same time that the model 47665 was on sale. (the next better model) So I upgranded for the same price. I recently had a problem with the dispensing tank of my current Brew Station, model #47655. The coffee ran right thru onto the counter and floor. I called Hamilton Beach customer service at 1-800-851-8900 and explained the problem. They informed me that the little tiny plastic piece that held the small gasket (looks like a water hose gasket) in place had broken off and could not be fixed. I would need a whole new tank. My brew station is about 8 months old with no receipt. HB then informed me that the whole new tank could and would be sent to me for the cost of shipping of $5.00. YUP!!! FIVE DOLLARS gets me a whole new tank!!!!! I love Hamilton Beach. They truly do stand behind their products. Have your husband call them at 1-800-851-8900 and explain the problem. They will do everything possible to remedy the problem at nominal cost to you. Good Luck. Katherine
Jun 21, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Tank leaks
Call Hamilton Beach customer support at 1-800-851-8900. You need a whole new tank. For $5.00 shipping, they will send you a new one. They did me. The gasket that prevents this fell out of my model 47665 brew station. The tiny part that held it in broke and I called them to ask how to fix it. It can't be fixed but for five bucks, they sent me a whole new tank PROBLEM SOLVED!!!! I love hamilton beach. 1-800-851-8900 customer service. Good Luck to ya Katherine
Jun 10, 2009 | Hamilton Beach BrewStation 47224 Coffee...
I have a new Z5 (less than 300 cups) that began dispensing a slow and reduced volume of coffee and also began leaking approx 3 oz of water into the tray after just 2-3 cups of coffee. I have meticulously...
If the grounds are really wet and not looks like a round firm cake, you need to use coarser grist on the grinder. The water in the drip tray is coming from the brew unit. The o-rings are not holding the pressure inside because the sieve is clogged. It could also be that the o-ring are dirty, then the brew unit needs to be disassembled and cleaned.
A good way to controll if the grist is too fine, is to watch if the coffee is just dripping from the outlet. Then try adjusting the grinder until the coffee flows evenly. You can also hear if the pump works harder during brewing.
Apr 26, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Cln
hi b1johansen,
 cln refers to "Clean"....
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100%satisfied.
Apr 17, 2009 | Hamilton Beach BrewStation 47665
Hamilton Beach Brew Station 47665
Here is the link to the manual - for those with leaks, call Hamilton Beach:
-Tha Mp3 Doctor
Nov 10, 2008 | Hamilton Beach BrewStation 47665
Tank leaks
Try Tightening the screws on the bottom. Will help for awhile.
We had to do that. I am on my third brew station.
Apr 04, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Hamilton Beach BrewStation 47214 Coffee Maker Logo
1,199 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
jason
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
