How do I change the belt on a hoover sweeper model U4263-930?
Undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Remove the bottom plate with screw driver in slots as shown. Then gently pull loose the upper cover from the remaining bottom plate by pulling at the edge working your way around the unit. It just snaps on. You need to have the upper arm unlocked from the upright storage position. Hoover belt number 38528-27-W4 for replacement.
SOURCE: How to change a Hoover Elite sweeper belt
on the bottom there should be a few screws take them out and a cover should come off the belt is right there. hope this helps
SOURCE: hoover elite belt change model number U4245
real simple you have to articulate the belt a little sideways and the belt should slide right between the pulley and the plastic.
Hope this helps.
